Your suggestions for replacement for thin, narrow, double-sided adhesive tape in outside mirror assy
Discussion in '1st Gen. Tacomas (1995-2004)' started by jnossoff, Sep 29, 2024.
  1. Sep 29, 2024 at 4:38 PM
    jnossoff
    jnossoff [OP] 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
  2. Sep 30, 2024 at 10:32 AM
    HoneyBadger153
    HoneyBadger153 Well-Known Member
    Lowcountry, SC
    2002 Lunar Mist Tacoma SR5 4WD
    ARB, Hella FF75, SoftTopper, Power Limited Seats, OME Suspension, Heated Mirrors
    I tried both 3M and Permatex black weatherstrip adhesive - that stuff is MESSY and I didn't like the final outcome where some sections squirted out. Home improvement stores sell window weatherstrip adhesive rolls that might work for this. They're wide, so you'd have to do some custom cutting but if I were to redo mine that's what I'd try first.
    That or maybe a thin bead of silicone?
    jnossoff[OP] likes this.
  3. Sep 30, 2024 at 4:25 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  4. Sep 30, 2024 at 5:03 PM
    jnossoff
    Joel
    Albuquerque NM
    Thank you @nzbrock and @HoneyBadger153
    I ended up using 3M Scotch 924 ATG Tape: 1/2 in. x 36 yds. (Clear Adhesive on Tan Liner).
    "3M Scotch 924 ATG Tape is a permanent unsupported acrylic adhesive transfer film (pressure-sensitive adhesive pre-applied to a special release liner)" I did not use the recommended 3M Scotch ATG 700 Adhesive Applicator
    I have used this adhesive for adhering posters, art, photos, etc., to backings. It is essentially double-sided tape adhesive.
    I cannot tell you how well this will stand up over time. It is not VHB - Very High Bond.
  5. Sep 30, 2024 at 5:06 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Go to your local hardware store and look for double-sided carpet tap (Flooring Dept). It's thin, tenacious, and is useful for anything you want to bond semi-permanently. You can consider 3M Super Seamstick as well. This tape is used for binding vinyl and fabric prior to machine sewing. The stuff is very thin, but sticks well.
  6. Sep 30, 2024 at 5:18 PM
    jnossoff
    Joel
    Albuquerque NM
    Thank you, @NC Gazzer. I have used the double-sided carpet tape, and it is thin, but much too wide, and would have to be cut down. For future use, I will look at 3M Super Seamstick.
