Your switch panel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by troublemaker, Oct 27, 2014.
  1. Oct 31, 2014 at 5:19 AM
    #61
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm still ready go overhead too. Just like to see options.
  2. Oct 31, 2014 at 5:41 AM
    #62
    Large
    Large Red
  3. Oct 31, 2014 at 5:48 AM
    #63
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I'm sure I could Google it, but where would one find this kit?
  4. Oct 31, 2014 at 5:50 AM
    #64
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Harbor Freight ;)
  5. Oct 31, 2014 at 7:27 AM
    #65
    la0d0g
    running for the hills
    For crawling not hauling
  6. Oct 31, 2014 at 7:27 AM
    #66
    geekhouse23
  7. Oct 31, 2014 at 9:29 AM
    #67
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Yah the dash requires some shaving inside to fit these switches there. But its not alot. You could alwayd return to stock
  8. Oct 31, 2014 at 9:47 AM
    #68
    mikecoscia
    mikecoscia Well-Known Member
    New Jersey
    2015 TRD Pro
    Count me in!
  9. Nov 1, 2014 at 11:28 AM
    #69
    Tao Zero
    Tao Zero Well-Known Member
    For those of you who have switches already wired... Where in the firewall can you run bundled wire through. I am trying to plan everything out and want to run all the wiring at once to aux fuse block in the engine bay. I haven't done all my homework yet, but with a 6 switch panel will I just be running 6 wires through the firewall? Thanks
  10. Nov 1, 2014 at 12:12 PM
    #70
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    If you plan on running 6 relays yes only 6 switches if not a bunch more
    Edit: 6 relays=6 wires threw the firewall
  11. Nov 1, 2014 at 12:13 PM
    #71
    ThomasMore66
    Some run through the steering wheel boot. There is a little nub you cut off and pill the wire through. That didn't work for me. There are a bunch of rubber plugs on the fire wall and I ran through one of those. Turned out to be very easy.
  12. Nov 1, 2014 at 2:13 PM
    #72
    Tao Zero
    Awesome! Thanks
  13. Nov 1, 2014 at 5:47 PM
    #73
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  14. Nov 16, 2014 at 5:41 PM
    #74
    Tao Zero
    Any update on this?
  15. Nov 16, 2014 at 5:54 PM
    #75
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Sorry for the lack of updates. I emailed the shop that originally made this for me to get a quote and haven't heard back. I'll call Monday and get an update.
  16. Nov 18, 2014 at 11:11 AM
    #76
    Iggy
    Northern CA
    Check out the build
    Ok guys, I got a quote back and putting everything together.
    So far it's $20 a panel with the pull handles. I'm looking to include the switch guide as well so that will add to the price if everyone wants those as well. Shipping is extra too, but I don't think it will be more than $5.50 if stays small.
    What do you all think?
  17. Nov 18, 2014 at 11:11 AM
    #77
    geekhouse23
    1. geekhouse23
  18. Nov 18, 2014 at 11:13 AM
    #78
    mikecoscia
    New Jersey
    2015 TRD Pro
    Count me in for one!
  19. Nov 18, 2014 at 11:23 AM
    #79
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
  20. Nov 18, 2014 at 11:24 AM
    #80
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
