Your switch panel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by troublemaker, Oct 27, 2014.
  1. Nov 18, 2014 at 11:24 AM
    #81
    Tao Zero
    Tao Zero Well-Known Member
    Count me in too. No pull handles or switch guide, just the plate. I am going the sPod route. Thanks
  2. Nov 18, 2014 at 11:27 AM
    #82
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Ok guys unless shipping to me gets crazy for some reason here is the final pricing.
    [Edit: We need 10 to be able to get this pricing.]
    $20 for the panel with the black pull handles.
    $30 for the panel, pull handles, and switch holder
    Add $1.25 for each switch blank cover.
    Here's a pic of the raw panel. It's the only one I have before I painted it.
  3. Nov 18, 2014 at 11:29 AM
    #83
    Iggy
    Northern CA
    Check out the build
    I'll check to see if that can be done. We are running a batch so I may only be able to get holes or no holes.
  4. Nov 18, 2014 at 11:32 AM
    #84
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Count me in!
  5. Nov 18, 2014 at 11:34 AM
    #85
    4myTaco
    4myTaco SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    In for one also, let me know when they are ready!
  6. Nov 18, 2014 at 11:37 AM
    #86
    Iggy
    Northern CA
    Check out the build
    I'll start a new thread so I don't clutter this one.
  7. Nov 18, 2014 at 11:38 AM
    #87
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    I'm down with this GB idea. Love the look you achieved.
  8. Nov 18, 2014 at 11:50 AM
    #88
    Iggy
    Northern CA
    Check out the build
  9. Nov 18, 2014 at 11:56 AM
    #89
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Some really nice setups in here! I went cheap and easy
  10. Nov 18, 2014 at 4:42 PM
    #90
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
  11. Nov 18, 2014 at 4:45 PM
    #91
    la0d0g
    running for the hills
    For crawling not hauling
    Looks clean. Nice install!
  12. Nov 18, 2014 at 4:59 PM
    #92
    krob32
    Kelly
    Thanks
  13. Nov 18, 2014 at 5:02 PM
    #93
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Wish I had seen that GB before I put my CB in...I could have used the metal cutting abilities!
    My switch/CB setup.
  14. Nov 18, 2014 at 6:28 PM
    #94
    Tao Zero
    What are the dimensions of the cutout? Thanks
  15. Nov 18, 2014 at 6:48 PM
    #95
    ThomasMore66
    Dallas/Fort Worth & Durango
    I really like that. Holds 6 switches?
  16. Nov 18, 2014 at 6:49 PM
    #96
    ThomasMore66
    Found the post stating 6. I'm in.
  17. Nov 18, 2014 at 6:58 PM
    #97
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    Count me in for the panel with pull handles.....
  18. Nov 18, 2014 at 9:31 PM
    #98
    ThomasMore66
    Screw a cb, CW McCall.
  19. Nov 19, 2014 at 1:08 AM
    #99
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  20. Nov 19, 2014 at 1:15 AM
    #100
    tunernewb92
    tunernewb92 Well-Known Member
    Brian
    Houston, TX
    2010 DCSB MGM OR
    Bills 5100 Front and Rear OME 885 Front Sway Delete 33" MTZ TRD FJ Wheels (Plasti - Black) Pioneer 10" Sub Kicker DS series component and speakers Alpine 5 way Amp Pioneer Double Din ImMrYo Mirror Bracket Escort 8100 Radar hung from mirror Waiting at house for install: TRD skid plate Retrofit Waiting on: BruteForce sliders BruteForce front bumper 2x3 6 led spot lights
    I'm down that looks slick man.
