Your trucks computer system and you...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NHOwl, Feb 16, 2016.
  1. Feb 16, 2016 at 5:03 PM
    NHOwl
    NHOwl [OP] Well-Known Member
    I don't even own my Tacoma yet, but I used to program LSx engines for years so I wanted to share a few things:
    The engine, transmission, and emissions system on your truck is electronically controlled. Each of these devices has some sort of base programming so that when you buy the car or your battery dies- your vehicle will still operate, but it then takes awhile to optimize itself/learn your specific usage habits.
    For example many folks have posted about using ECT or sport mode for their transmission all the time...that's fine...but realize you're essentially overriding the learning process. Likewise regarding the engine: it isn't so much the engine mechanically breaking in so much as it learning your driving style and typical environmental conditions.
    Case in point: when I watch ignition timing on the LSx series engines the base map would be set to a certain amount of advance...but that could be a little aggressive depending on where you lived (temperature, fuel quality, etc)...the computer would sense pre-detonation and the timing would get cut back aggressively by a default amount to prevent ANY possible issue. Eventually, however, the computer would learn "wait when the intake charge is this temperature I'm always doing an emergency retard of the timing...lets see if I can reduce the advance a little and what happens". Eventually reaching a new base that did not require the retard and therefore had a greater overall level of performance.
    In short: bear with it and drive normally, many of the issues you may have will go away as your vehicles computer learns itself and you. My Saab is awful the first few days it's cold outside in the morning...then it finally learns and is good for the rest of the season.
    I also really simplifies my example...fuel trims and in the case of the Toyota valve timing and play a huge role as well...but I'm sure you get the point.
  2. Feb 16, 2016 at 5:32 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Good post. I have found that most problems seem to go away after I ignore them.
  3. Feb 16, 2016 at 5:33 PM
    NHOwl
    Haha. I should specify "obviously this does not mean ignore mechanical problems or anything that is clearly not right".
  4. Feb 16, 2016 at 5:34 PM
    mrbadwrench
    Cleveland Ohio area
    :p
  5. Feb 16, 2016 at 5:51 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Never touched the ECT button for first 1000 miles, lived through a little hurt, but now has a complete different feeling. Very much like my 2nd Gen off the line.
  6. Feb 16, 2016 at 7:42 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    You program engines? Really, as in change the fuel map or trims? and your suggesting to let the motor learn about me and everything will be alright, what are you talking about...? OP.
  7. Feb 16, 2016 at 8:38 PM
    Dirtbag51
    Dirtbag51 Well-Known Member
    Az
    2016 Tacoma TRD
    Ha ha......that is the same philosophy my kids have.....
  8. Feb 16, 2016 at 8:43 PM
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    Seems like you're knowledgeable so will this still happen to some aspects of the engine/powertrain/tranny with a manual transmission?
    Howen likes this.
  9. Feb 16, 2016 at 8:48 PM
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Also, what do you recommend fuel wise?
  10. Feb 16, 2016 at 8:51 PM
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
    Will the computer lose its' "learned Memory" if the battery is disconnected and have to learn all over again?
  11. Feb 17, 2016 at 3:20 AM
    NHOwl
    Not suggesting "everything" will be alright- a shitty base map will always be a shitty base map (hence why I used to program LSx engines and there was still value in programming a stock vehicle). But as the various modification tables fill out the vehicle should definitely run better than the day you bought it.
  12. Feb 17, 2016 at 3:27 AM
    NHOwl
    Whatever the manual recommends unless you have a good reason to do otherwise (modifications, perhaps certain extreme weather conditions...maybe)
    Clearwater Bill likes this.
  13. Feb 17, 2016 at 3:30 AM
    NHOwl
    No idea on the Tacoma. The LSx would lose its long term trims when the battery was disconnected as they were stored in volatile memory- but that's not this vehicle.
  14. Feb 17, 2016 at 7:14 AM
    arkywally
    David
    2016 DCSB TRDOR
    There are some other threads on this out there how it seems to be consensus that after x amount of miles the AT would "seem" to have better shift points and not feel so bogged down at lower speeds. Not sure why this is, except to guess that there may be some type of adaptive drive algorithm that works off a number of conditions and values that the ECU compiles. If that aint the case I would fall back on the old addage of break in time on the motor and drive train makes the ride more enjoyable than that first 200 mile experience.
  15. Feb 17, 2016 at 7:42 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I don't feel like mine has really changed at all.
  16. Feb 17, 2016 at 8:31 AM
    arkywally
    David
    2016 DCSB TRDOR
    The drive for me has been adapted in my right foot, the first 200 miles or so I used the eggshell approach on the gas. After I got used to the 3.5l atkinson cycle motor with VVT-iW and D4-S stuff its liking riding a new horse. Although there are times I have to use ECT to satisfy my RPM urge with out flooring it...I have no regrets and am enjoying my new mount.
    CusterFan and smugly like this.
  17. Feb 17, 2016 at 8:49 AM
    smitty99
    Scottsdale
    Man every time I drive my gal's 2016 4Runner I'm reminded how gutless my 2016 Tacoma feels on the front end of the powerband. As long as I don't drive her runner, I get used to the "neutered" feeling.....
  18. Feb 17, 2016 at 9:00 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I am still looking a my tranny with my head shifted to the side because of how it keep aggressively shifting when on the freeway @ 70, but I have noticed a difference overall in the truck demeanor in the plus. The exhaust is also starting to sound much throatier now.
  19. Feb 17, 2016 at 9:01 AM
    smugly
    Doug
    or higher, If you tow. I would not suggest using 87, imo
  20. Feb 17, 2016 at 9:04 AM
    Jtac15
    Jtac15 Well-Known Member
    Long island
    2022 Trd OR
    Wow thanks for the informative post
    CusterFan likes this.
