Your trucks computer system and you...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NHOwl, Feb 16, 2016.
  1. Feb 17, 2016 at 9:40 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    There has already been several threats on this conversation. This is where the mapping comes into play with everything else that it's reading
  2. Feb 17, 2016 at 9:58 AM
    smugly
    Doug
    Do you have documented info to support this, OP chime in if you have anything to add to this please.
  3. Feb 17, 2016 at 10:12 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    :duel:
    smugly and Jtac15 like this.
  4. Feb 17, 2016 at 10:25 AM
    smugly
    Doug
    The test that you're basing your knowledge on is 16 years old FYI motors and motor technology has come a long way 16 years. A slower burning fuel will always produce more efficiency, especially in a motor like the atkinson's Motor . And yes there is plenty of documentation already on this,in this decade.!
  5. Feb 17, 2016 at 10:36 AM
    NHOwl
    NHOwl [OP] Well-Known Member
    I know nothing about the exact engine control Toyota uses so I can't be sure but I am 99% sure it has no way to optimize itself for different grades of fuel. The reason behind this is because if your vehicle were to adapt to say 93 octane fuel and then you went to 87- it could cause engine damage before the computer learned otherwise.
    Saabs and Trionic were a different story- they actually use spark plug ionization as a primary sensor input and can therefore adjust engine parameters on a per revolution basis and therefore you do see the vehicle adding timing, boost, etc with higher octane fuels (to a limit of course) the flip side is if you suddenly give it different fuel it adjusts immediately. The down side is you must use the right plugs, they must be gapped correctly, and every so often you get to spend $400 on a new ignition cassette...not to mention a host of other quirks and concerns.
    Does this mean you will never see a benefit from higher octane fuel in a Tacoma? Of course not- extreme conditions are definitely real but rare and your vehicle should operate just as optimally 99.9% of the time without it.
    sadmrhappy and Clearwater Bill like this.
  6. Feb 17, 2016 at 10:38 AM
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    Seems like you're knowledgeable so will this still happen to some aspects of the engine/powertrain/tranny with a manual transmission?
  7. Feb 17, 2016 at 10:50 AM
    NHOwl
    Of course, just one less electronic controlled item (transmission)- so the learning will all be engine related.
    YotaLife406[QUOTED] likes this.
  8. Feb 17, 2016 at 11:33 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Maybe this philosophy of learning could be applied at the manufacturing and design level?
    friendlywithbears likes this.
  9. Feb 17, 2016 at 11:49 AM
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
    No doubt! Once those exhaust bearings get broken in, the thing sounds like a beast! :)
  10. Feb 17, 2016 at 4:48 PM
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Is this option available for those with M/T? Please explain.
  11. Feb 17, 2016 at 6:07 PM
    NHOwl
    Wow you just introduced a lot of variables. E-10 is more likely to absorb water because of the alcohol which then can degrade performance...so it depends. As for E-0 90 and 93 the performance should be no different in a vehicle that is not designed to take advantage of the higher knock resistance under most circumstances.
  12. Feb 17, 2016 at 6:08 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    These always become arguments about the benefits, or lack of, of higher octane fuel
    will it ever end?
  13. Feb 17, 2016 at 6:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. M/T is 'Moon Transfer' isn't it?
  14. Feb 17, 2016 at 6:11 PM
    NHOwl
    I thought it was mega torque from reading about how much better it is...
  15. Feb 17, 2016 at 6:15 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    You're bringing apples to a discussion on oranges.
    Before you try to make fruit salad, no e10 will ever perform as well as any e0, even in the same grade.
    As a side note e anything should be discarded for the general public. It takes more energy to grow and process than fuel it offsets. And that's your tax dollars at work, with no substantial benefit towards any of the original stated goals of the e project.
    smugly likes this.
  16. Feb 17, 2016 at 6:16 PM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Rook player?
    Howen likes this.
  17. Feb 17, 2016 at 6:35 PM
    #37
    smugly
    Doug
    Well, is guess your right rock lobster, The delicate and minuet details of this argument will never end.
  18. Feb 17, 2016 at 6:46 PM
    #38
    Howen
    Thanks, Clearwater. I was born in Tampa actually. So I get this. I just wanted to help those who are not as familiar with the beach.
  19. Feb 17, 2016 at 6:46 PM
    #39
    bdunna
    bdunna Well-Known Member
    2005 tundra access cab
    Always go with recommended octane level. Ethanol will not reduce performance, but will reduce economy (fuel mileage).
  20. Feb 17, 2016 at 7:13 PM
    #40
    angry john
    angry john Well-Known Member
    john
    2016 DC OR V-6
    I would buy and run any E-0 fuel before any with ethanol. If I could get that in 87 great. If I had to go 89 I would. Don't know if I would spring for premium unless I was storing the truck for a deployment. Ethanol sucks for storage reasons.
