Your unique mod on the 1st Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Oct 14, 2010.
  1. Nov 9, 2021 at 11:51 AM
    #2021
    MatosTaco
    MatosTaco Well-Known Member
    96 Toyota Tacoma
    Coilovers, sway bars, wheels, tires, extended studs, intake, head and taillights, seats, short shifter,
    Thank you, I appreciate that! As I improve through practice, I should be able to make them for less. I have 10 of these steering wheels in the garage to train with, so I will keep you posted!
    DashMaple and unstpible like this.
  2. Nov 9, 2021 at 6:50 PM
    #2022
    reallifeonhold
    reallifeonhold Well-Known Member
    Travis
    2004 4WD 5MT
    Thanks, my goal was to make it look as OEM as possible. Hit me up if you're still interested when you're ready to do the install.
  3. Nov 10, 2021 at 4:42 PM
    #2023
    MatosTaco
    96 Toyota Tacoma
    Here is another unique mod I started a couple days ago. Hopefully, someone else can benefit from this idea. Since I shaved the holes for the windshield washers off my hood, I was looking for a new way to mount them. I noticed my Camaro has them mounted to the cowl cover, so I decided to try that. My old washers were in bad shape and I lost one, so I ordered some washers intended for the 2005+ Tacomas. I read on here that those have a better spray pattern and that was attractive vs just buying the older style ones with the dual streams.
    Here are the ones I bought
    [​IMG]20211101_200215 by Jose, on Flickr
    I had to design and 3D print some adapters in order to mount them to the cowl (the adapters fit pressed into the cowl and are then held in with ABS cement). If anyone wants to try this mod, I can 3D print these for you.
    [​IMG]20211110_195849 by Jose, on Flickr
    [​IMG]20211110_173811 by Jose, on Flickr
    [​IMG]20211110_173815 by Jose, on Flickr
    I connected the two sprayers to each other using 5/32" washer tubing from Prestone (sold in a 6 foot length at Autozone) and placed a T-fitting in the middle of the tubing. This, in turn, connects to the tubing coming off the pump on the washer reservoir. The reason for the T in the center is to ensure even flow to both sides. I added a zip tie to each connection in order to avoid loosening over time (the T didn't feel all that tight on the tubing).
    [​IMG]20211110_173819 by Jose, on Flickr
    [​IMG]20211110_173827 by Jose, on Flickr
    I used a single strand copper cable to fish the tubing from the pump through the fender well and out the cowl area so that I could connect it to the T-fitting. There is a readily available opening next to the reservoir through which you can put the tubing into the fender well.
    [​IMG]20211110_184459 by Jose, on Flickr
    From there, you can run the wire up the fender well into an opening that leads into the cowl area. I tested the wipers to ensure the tubing wouldn't become impinged on the wiper arms and it all looks good.
    Here they are with the cowl mounted to the truck
    [​IMG]20211110_173844 by Jose, on Flickr
    A test showed that they were spraying properly, such that the windshield ended up evenly wet with the movement of the wipers.
    [​IMG]20211110_184329 by Jose, on Flickr
    Yossarian, andywear, Rldanie and 9 others like this.
  4. Nov 12, 2021 at 7:08 AM
    #2024
    Plkyone
    Plkyone Well-Known Member
    Those little mods make such a difference wow attention to detail!!!!
    unstpible and MatosTaco like this.
  5. Nov 14, 2021 at 9:01 PM
    #2025
    Henrytmoc
    Henrytmoc n00b
    Hen
    SGV
    1998 Tacoma Xtracab 2WD
    Desmond Regamaster MP
    Installed some Integra seats in the Taco.
    No welding. Used Recaro sliders and planted brackets. Did not have to weld anything. Recaro rails bolted right up to the DC2 Integra Type R seat and bolted right up to the planted bracket for the driver side.
    Passenger side is the passenger seat from a 98 Integra. Slider closest to the passenger door comes right off with removing 2 nuts and 1 bolt. The slider closest to the transmission tunnel needed to be cut to utilize the side bracket. Bolted the Recaro sliders into the seat by drilling an additional hole on the Integra brackets. The rails fit perfectly into the planted bracket without any modification or extra drilling.
    andywear, sinks88, Akkording and 6 others like this.
  6. Nov 14, 2021 at 9:50 PM
    #2026
    SiberianTacos
    SiberianTacos Well-Known Member
    02 Tacoma Dbl Auto 4wd
    redid my headliner and added seat jackers (weird name)
  7. Nov 15, 2021 at 2:14 AM
    #2027
    Henrytmoc
    Henrytmoc n00b
    Hen
    SGV
    Love it! Currently working on doing the same. I used to do road racing in my previous car as well.
    bugly64, BeLance89, ireymon and 7 others like this.
  8. Nov 15, 2021 at 12:00 PM
    #2028
    Plkyone
    Very NICE!!!!
  9. Nov 15, 2021 at 12:03 PM
    #2029
    Plkyone
    This is looking cool! Are you going with full black or just the accents?
  10. Nov 15, 2021 at 1:45 PM
    #2030
    SiberianTacos
    I will attempt to black out anything and everything I can. How ever I am against using spray paint. So it takes time and creativity to apply materials.
    CrustyTaco and Keahiokekoi like this.
  11. Nov 15, 2021 at 3:04 PM
    #2031
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    I've been impressed with what you've done so far. I'm curious to see your approach for some of the other pieces.
    I did an interior color change with my car in college that involved spray painting plastic parts and I will NEVER do that again. I'm sure if you use good paint and prep things well it can be alright, but the scratches and flaking paint were really really bad.
  12. Nov 15, 2021 at 6:36 PM
    #2032
    Plkyone
    ‘yup I know what you mean but you can get really good results with a good prep and paint.. The old European shop I used to work at had a guy that came in and did interiors and he would mix his color and use a airbrush with amazing results
    unstpible likes this.
  13. Nov 18, 2021 at 8:10 AM
    #2033
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    So youre the reason i cant find any is300 wheels!:D
    MatosTaco[QUOTED] and Plkyone like this.
  14. Nov 18, 2021 at 11:46 AM
    #2034
    MatosTaco
    96 Toyota Tacoma
    Lol, in all fairness, only some are is300, others are Supra wheels- but yes, I am sort of hoarding them. I promise they will be released back into the wild in new leather and carbon :thumbsup:
    unstpible and DashMaple[QUOTED] like this.
  15. Nov 18, 2021 at 8:13 PM
    #2035
    MitchHamwich
    MitchHamwich Well-Known Member
    Mitch
    SLC, Utah
    2004 double cab SR5 TRD sport 4x4
    Do you have any more pics of your back seats? Or lack there of? I’ve been thinking about taking mine out for more room.
  16. Nov 18, 2021 at 8:22 PM
    #2036
    SiberianTacos
  17. Nov 28, 2021 at 5:17 PM
    #2037
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Curious what the seat foam set ya back. And if you have a Part#
  18. Nov 28, 2021 at 5:23 PM
    #2038
    reallifeonhold
    Travis
    2004 4WD 5MT
    The p/n is 71511-04150. I paid about $150 from ToyotaPartsDeal.
    unstpible and Nevin[QUOTED] like this.
  19. Nov 28, 2021 at 5:30 PM
    #2039
    Nevin
    Washington
    Thank you!
  20. Nov 29, 2021 at 10:45 AM
    #2040
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    That's not bad
