Your unique mod on the 1st Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Oct 14, 2010.
  1. Dec 1, 2016 at 4:37 PM
    #541
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    I was searching for these arb brush bars a while back but only found them in Australia. Could you share where you got them?
  2. Dec 1, 2016 at 4:53 PM
    #542
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    They were fabricated by @Mobtown Offroad here in MD, plans to link them to sliders are eventual
    Chipskip and Mobtown Offroad like this.
  3. Dec 1, 2016 at 4:59 PM
    #543
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    They came out pretty well if you ask me haha
    Chipskip likes this.
  4. Dec 1, 2016 at 5:27 PM
    #544
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    This is pretty stupid but help for me
    I have a after market CD player in mine witch I can connect my phone to via aux cord when ever I did this I would always put my phone some where and it would fall to the floor so I started putting in on my dash and one day my phone almost slid out my window I cought it just in time so I went to the dollar store and bought Velcro and stuck it to the top of the dash and to the back of my phone so I could stick it with in hand reach for when I wanted to change songs
    RedManRocket likes this.
  5. Dec 1, 2016 at 11:42 PM
    #545
    UtahTacoma02
    Dave
    SLC
    Thanks for the info, good to hear they will link up to the slider in the future. Maybe I will get them for Christmas this year :hattip:
  6. Dec 1, 2016 at 11:57 PM
    #546
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    The ARB decal had us all fooled. But that is a seriously awesome mod I have never seen on a Tacoma before.
    Faztec1 likes this.
  7. Dec 2, 2016 at 11:49 AM
    #547
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    A spot to charge streamlight flashlight, bracket made from small piece of aluminum screwed to console side, ran wire under console for cleaner look
  8. Dec 2, 2016 at 11:51 AM
    #548
    AZ4x4Taco
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Small platform for dogs, two pieces. back is remove able, all can be removed in about 30 seconds. flips up for underneath storage options.
    Mr Yoda, slonny17, SwampYota and 6 others like this.
  9. Dec 2, 2016 at 11:52 AM
    #549
    AZ4x4Taco
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Photo with it flipped open
  10. Dec 2, 2016 at 11:53 AM
    #550
    Wulf
    rock raisin
    I like this idea!!!
    DustStorm4x4 likes this.
  11. Dec 2, 2016 at 11:57 AM
    #551
    AZ4x4Taco
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Platform was pretty easy to do, sheet of plywood and a few 1×4's had a 2x4 to use as support. got the carpet at home depot for $20, it's almost a color match too which was nice. had the little pouches from work, they hold gloves and first aid kit, fill them with batteries when I go camping too for flashlights
    slonny17 and DustStorm4x4 like this.
  12. Dec 2, 2016 at 12:49 PM
    #552
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Awesome. Pure awesome.
  13. Dec 3, 2016 at 6:35 PM
    #553
    Zemuron99
    Zemuron99 Well-Known Member
    Seattle, WA
    '98 TRD V-6 4x4
    TRD S/C URD Fuel Upgrades 9 aftermarket gauges!!
    Sorry, it's been a while since I've been on here. To answer some of the questions. No, no compass nor outside temp gauge. The tranny temp gauge probe is 'T''d into the outlet line to the stock cooler, so I'm getting fluid right out of the transmission. My flow is transmisstion -> stock cooler -> aux cooler -> back to transmission. I know there's some risk of over-cooling the fluid, and when it's less than about 40-45 out, and the TC locks, I can be running in the 130-140 range. But I also have 33's on it, so other times I can heat up pretty quickly when the TC is unlocked, so that's when I want and need maximum cooling. Some have run to an aux cooler first then the stock cooler, which could in theory put some heat back IN the transmission if the coolant at the bottom of the radiator is warmer than the transmission fluid coming from the aux cooler.
  14. Dec 3, 2016 at 7:16 PM
    #554
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    so you just put the full length of the stuff. so adjustable like unistrut, but doesn't take up as much room
    VL0IDKNr74FSViyc34ZDGRczBIKJYhCTJlza3PJi_044b6bfedf903cd989510880e22c624bd655c924.jpg
  15. Dec 4, 2016 at 9:12 AM
    #555
    1997tacomav6
    Denver
    For less than 100.00 you got to add red line hood struts.
  16. Dec 4, 2016 at 9:44 AM
    #556
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    One of the best mods I've done to my truck.
    Faster_n_you98 and bowyer2002 like this.
  17. Dec 4, 2016 at 9:51 AM
    #557
    chaosrob
    chaosrob Well-Known Member
    I purchased the elite set and am just waiting for them to come in. These look like a great mod for the money, prop rods always get in the way when doing anything under the hood, at least for me
    1997tacomav6[QUOTED] likes this.
  18. Dec 4, 2016 at 11:00 AM
    #558
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    So awesome. What wheels are those?
  19. Dec 4, 2016 at 11:10 AM
    #559
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Look like fairly generic d-window steel wheels.
  20. Dec 4, 2016 at 11:21 AM
    #560
    Tacotruck7
    SoCal
    2025 SR5 4x4
    I like the look a lot but I wish they weren't so heavy. My little 4 banger will have issues.
