You're Going to Laugh/Cry
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexi, Sep 18, 2020.
  1. Sep 18, 2020 at 6:19 PM
    Alexi
    Alexi [OP] Member
    Alexi
    Hey,
    So I'm 19, thinking I have my big boy self-sufficient pants on I'm out in my garage changing my oil for the first time, looking at my Hanes Manual I think I have this covered.
    I did drain the oil out then proceeded to fill 5.2 L (changed the Oil Filter) of 5W-30 into the engine, started it up and drove it around 200M (600').
    Sounds good yea?
    I drained the Automatic Transmission fluid, not the crank case. So not only did I drive 200M with NO transmission fluid I drove around with ~4L of oil more than capacity.
    So my question is:
    How bad did I fuck this up? Obviously I wont start it until I fix all the fluid issues but just how bad is this do you think?
    Alexi
    grizquad and Thatbassguy like this.
  2. Sep 18, 2020 at 6:21 PM
    Bishop84
    Bishop84 Well-Known Member
    You aren't the first, don't worry. No permanent damage.
  3. Sep 18, 2020 at 6:23 PM
    Alexi
    Alexi [OP] Member
    Alexi
    Thanks, I really hope so, I did this cause I'm broke to save money, a $2000-$4000 repair bill is going to kneecap me.
    Thatbassguy likes this.
  4. Sep 18, 2020 at 6:25 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    You only did bad enough to make a great Friday post story!
    Your Taco should be fine...
  5. Sep 18, 2020 at 6:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Sep 18, 2020 at 6:26 PM
    Bishop84
    You can't damage a trans unless you keep it running even after it stops engaging gears.
    Big habit, don't start a truck until you check the dip stick. Get into a routine.
  7. Sep 18, 2020 at 6:28 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Not the first, won't be the last.
    Thatbassguy and jackn7 like this.
  8. Sep 18, 2020 at 6:29 PM
    tcjacado
    tcjacado Well-Known Member
  9. Sep 18, 2020 at 6:32 PM
    BurntChickenNugget
    BurntChickenNugget Well-Known Member
    Eric
    2017 Tacoma TRD
    This is always my fear!
  10. Sep 18, 2020 at 6:33 PM
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    When you get back under the truck, get a paint stick and put a big T (for transmission) on the trans oil pan. It will never happen again.
  11. Sep 18, 2020 at 6:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. Sep 18, 2020 at 6:39 PM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    I thought the oil capacity was 5.2 quarts.
  13. Sep 18, 2020 at 6:40 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Look on the bright side, at least you're 19. Some of us are way older and still manage to do stupid shit like that on occasion.
    Wait until you buy a house someday. Only then will you truly realize how stupid and incompetent you really are ;)
    *digs furiously into broken air conditioner*
    Thatbassguy, CurtB, 4x4_Taco and 9 others like this.
  14. Sep 18, 2020 at 6:41 PM
    toucan
    toucan Stupid truck
    Sam
    Oregon
    2013 DC offroad MGM. 2012 Super White SR 4x4 RC
    SCS/Bilstein/Icon/JBA/ Relentless/ATH/Smittybilt/Meso/Mobtown/Archive Garage/BAMF/Pioneer/Rockford Fosgate/Sundown/Wet Okole/Spiker Engineering/I'mMr.Yo/RAMMounts/Softopper/Weathertech/Factor55/Morel/DD
  15. Sep 18, 2020 at 6:43 PM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Wow , this happens alot.
    ABNFDC, CXYyuppie and wilcam47 like this.
  16. Sep 18, 2020 at 6:45 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Points for manning-up and admitting it. You should be fine.
    Stuart762, Crow Horse, ABNFDC and 6 others like this.
  17. Sep 18, 2020 at 6:59 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    It just boggles my mind how one drains the ATF thinking its the oil... there is literally NO MOTOR above where the trans pan drain plug is.
    Either way, OP you are good, drain ENGINE oil completly, new filter, fill proper, then get 4 quarts of WS fluid from your local toyota dealership and top it off n go through the temp check mode.
    ABNFDC, Thatbassguy, jackn7 and 2 others like this.
  18. Sep 18, 2020 at 7:03 PM
    Alexi
    Alexi [OP] Member
    Alexi
    Totally agree, in hindsight it was obvious, im going to spray paint a "T" under there as someone else said.
    Thanks guys, this really cheered me up. I'm going to just have AMA tow it to a dealership and have then do everything, I need new/more power steering fluid and my breaks feel like mush (air prob). Its just better this way TBH lol
    ABNFDC and Biscuits like this.
  19. Sep 18, 2020 at 7:06 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What?
    Island Cruiser and Musubi3 like this.
  20. Sep 18, 2020 at 7:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Seriously, get the transmission fluid level correct. You are now running 3+ quarts low.
