Yup...I'm close...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by azonicbruce, Dec 11, 2012.
  1. Dec 12, 2012 at 10:51 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    For the people who park in garages, turn on your headlights and when you want to get as close as you want put a mark on the wall for your headlights to meet up with it and there you go :D
    Im talking about the beam of the headlight for some who may be confused
  2. Dec 12, 2012 at 10:57 AM
    Chaloots
    Chaloots Well-Known Member
    do you know how to activate the lines on the back up camera? i have a 2012 and do not see how
  3. Dec 12, 2012 at 6:06 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If your floor is smooth it will slide after a few times. Construction adhesive like "no more nails" will keep it from moving.
    Take a tennis ball, punch a hole throught it, and tie it on the end of the string. Hand the whole thing so it just touches the windsheild. When it bumps the window, you are "there". Same idea, slightly different method that won't change with a bit of breeze through the garage. Either of these work for one vehicle only in that spot.
    Another idea, go to your local big rig parts dealer, and buy a cheap 8" convex mirror. Mount it in the front wall of the garage angled downward so you can see between the wall and the vehicle. This works for any vehicle you wish to park in that spot.
  4. Dec 12, 2012 at 6:11 PM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    I don't have any lines on mine :(
  5. Dec 12, 2012 at 6:15 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    these trucks are kind of goofy. without a scoop theres really no references on the hood. took my a while to figure this thing out off-road. the scoop gives a good reference, but then its like the only thing in sight lol.
  6. Dec 12, 2012 at 6:33 PM
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    I like that idea
  7. Dec 12, 2012 at 6:37 PM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    This might sound stupid but in the past I have intentionally set up things to hit. Grab a pylon or a pool noodle on a stick. Anything you can make stand upright that won't damage your truck if you bump it. Set up some obstacles and try to park as close to them as you can. Set up two in line and try to parallel park between the two without hitting them. This will give you a good feel for the size of the truck and where everything is. I used to be able to put either bumper of my tracker 1/2 inch away from whatever I was parked by. I haven't done this with my truck yet but it would help a lot. I am always parking too far back now..
  8. Dec 12, 2012 at 7:59 PM
    Larry
    Larry CARL
    CARL
    I got closer :D
  9. Dec 12, 2012 at 8:37 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Your link only leads to the Sears homepage.
    Good ideas, guys. Will have to see if one works for me. I have the side-to-side down pat (less than 6" comfortably). It's the length that gets me. The clearance in the garage is about 12~18-inches. By the way, based on experiece with her driving abilities (she routinely bounces off surroundings), my wife has already been banished to the driveway, T@co_Pr3runn3r.
  10. Dec 12, 2012 at 8:48 PM
    stewartx
    Huntsville AL
    In a 2012, the lines for the backup camera display should be displayed by default. In fact, some have asked how to turn them off, without a satisfactory answer.
  11. Dec 12, 2012 at 9:01 PM
    azonicbruce
    azonicbruce [OP] Well-Known Member
    Bruce
    Owasso, OK
    2012 SR5 4x4 Double-Cab
    Lol. Sorry guys, but now I can't help but think of this:
  12. Dec 12, 2012 at 9:05 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I watched this the other night on tv.
  13. Dec 13, 2012 at 7:58 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Regardless of nationality I'm pretty sure anyone would call someone out if they can't drive....Canadians just happen to do everything better than our capitalist neighbours haha
  14. Dec 13, 2012 at 8:06 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Tough to argue
  15. Dec 13, 2012 at 8:11 AM
    #35
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Same here.. first time I watched CBC in a while.
  16. Dec 31, 2012 at 11:42 AM
    #36
    flashtoo
    flashtoo New Member
    Just attach a tennis ball to the end of the string to let it hit the inspection sticker (or registration sticker, or something you put in the window of the vehicle) when you are positioned correctly in the garage. I've used this on every vehicle I've had (including motorcycles) for years. Never fails to correctly position the vehicle in the garage.
    First, get the vehicle positioned exactly where you want it in the garage. Next, take a length of string and the attached tennis ball (I use a cup hook screwed into the ball) and, from a ladder, hold the string contraption directly over the portion of the windshield that you want to use as your position marker. Mark the ceiling, screw the string into the mark, fine tune the string length, and then fergeddabout parking problems.
    Cost: string and tennis ball, although if you have a dog you probably already have a tennis ball ;-)
  17. Dec 31, 2012 at 12:09 PM
    #37
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I'm used to driving a tractor trailer in tight spaces..so the Tacoma isn't really an issue. Any of the things I've seen used,have already been posted here. Tennis ball and string,2x4 etc. I say cut the back wall out of the garage and extend it so you have more room to work on the truck,as well as park it !
    Oh yeah..and Canadians.. :rolleyes:
  18. Dec 31, 2012 at 1:45 PM
    #38
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    No issues here with my truck. Backing up is easier in tight spaces due to being able to see the box edges.
    I do miss the sharp hood corners of my '95 Silverado occasionally. The steel bumpers on those were nice when I would hit stuff too.
  19. Dec 31, 2012 at 2:57 PM
    #39
    F75gunslinger
    Christian
    Rochester,NY
    Although...if you have a dog..you might not have a tennis ball on a string for very long !!!
  20. Dec 31, 2012 at 3:17 PM
    #40
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    I hate people that can't park in the lines...
