YZF600r Low compression on all cylinders
Discussion in 'Motorcycles' started by Jerneyman, Jun 8, 2018.
  1. Jun 8, 2018 at 9:22 AM
    Jerneyman
    Jerneyman [OP] Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Can anyone give some insight in to my problem here? I'm reading right at 60 psi on all cylinders, adding oil to the cylinders only increased the pressure by 5 psi. This was done with the throttle open and cranked until pressure stabilized. I did this test due to the loss of power I felt on the bike. No matter what, I could never push it past 80 mph and getting there was terribly slow.
    I'll be performing a leak down test tonight, so hopefully that will yield some useful information.
    Has anyone ever experienced this, the uniform loss of compression? Just looking for probable causes this could be attributed to before I tear in to this motor.
  2. Jul 26, 2019 at 11:43 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Reviving an old thread,
    OP, you ever get to bottom of this?
    There are some questions if not.
