Zerk fittings
Discussion in 'Technical Chat' started by MaGuyver, May 3, 2010.
  1. May 3, 2010 at 11:30 AM
    MaGuyver
    MaGuyver [OP] Well-Known Member
    Charleston, SC
    True Flow XDI cai, DT short headers, Tinted glass, Line-X coated rails, bed mat
    I now have bump or thump on my 07’ 4dr (non-4wd) Tacoma when I stop and the release the break a little. I had it on my 2004 but that was from day one and on this one it has just started at 34000 miles. I have read a number of posts on diff. sites about what you should do or what might be the problem. I just need to know if there are zerk fittings on my vehicles’ drive train? Thanks
  2. May 3, 2010 at 3:58 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I think greasing the slip joint can help....
  3. May 5, 2010 at 2:49 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    There are zerk fittings on the drive shaft. Dont put more than a few pumps on the gun into the slip joint, a couple is all you need.
