Zerk grease quantity..new truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjbb2, Sep 26, 2011.
  1. Sep 26, 2011 at 3:54 AM
    rjbb2
    rjbb2 [OP] Member
    Bob
    NC
    2011 4x4
    Lighted 4x4 switch, Ipod direct adapter, Intermittent wiper, cruise control.
    Brand new 2011, (2.7l, base, auto, 4x4) 1 month old. After reading all the zerk grease threads and a lot of you finding they are near dry from the factory, I decided to go ahead and put in some Mobile 1 syn grease on all 5 zerks. I used over ½ of tube of grease and only greased until I head the pop and saw a little factory grease coming out. Don’t want to over-do anything with a brand new truck. 2 questions:
    1 If you have greased all 5 zerks on a new 4x4, how much grease did you use?
    2 Should I completely purge the factory grease with the Mobile1, or is it OK to have them mix?
    Mobile 1 is a grade 2 and suppose to be fine for all five zerks. Oh hell, I guess that's 3 questions.
  2. Sep 26, 2011 at 4:46 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    This has been pretty common at least in the 3 Tacoma's I have worked on. I personally do not purge all of the grease. I push enough out to get the water and real nastyness out. All that really matters is that you have a good helping of good fresh grease in there....
  3. Sep 26, 2011 at 5:16 AM
    rjbb2
    rjbb2 [OP] Member
    Bob
    NC
    2011 4x4
    Thanks...I am a bit paranoid about doing anything stupid to a new truck.:p
  4. Sep 26, 2011 at 5:21 AM
    dalsmthme
    Ithaca, NY
    It's fine, now that they are filled, just give them a couple squirts every oil change and you should be good to go for a long time....
  5. Sep 26, 2011 at 6:44 AM
    vtmactech
    vtmactech Well-Known Member
    KS
    '11 Reg Cab 4cyl 4x4 MGM
    Where are these 5 grease fitting at? I know it probably says somewhere in the manual but if someone could indulge me I would appreciate it.
  6. Sep 26, 2011 at 6:49 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    too lazy to type, sorry--a search should yield good results...
  7. Sep 26, 2011 at 6:56 AM
    dalsmthme
    Ithaca, NY
    1 fitting on each u-joint. Crawl under and look and you will find them. quantity will vary based on truck drive-line configuration....
  8. Sep 26, 2011 at 7:12 AM
    vtmactech
    KS
    And yet you managed to type anyway. Thanks.
  9. Sep 26, 2011 at 7:21 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    i have a double cab long box and i can only find 3, one on each u joint
  10. Sep 26, 2011 at 7:26 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Three on rear shaft two on front shaft. The two on the front shaft are hard to see and even harder to get the grease gun to them.
  11. Sep 26, 2011 at 7:27 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    so your saying theres more than one zerk per u-joint? maybe mine have been replaced before....hmmmm
  12. Sep 26, 2011 at 9:02 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    You shouldn't have them on your 2 wheel drive.
    To clarify, your joints do not need to be greased.
  13. Sep 26, 2011 at 9:09 AM
    grivera
    Hanover, MD
    YW, the search feature on this site is outstanding, and many times the responses include pics...
  14. Oct 3, 2011 at 7:30 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    All 5 of mine required 5-10 pumps at my first change. I would say that they were pretty dry from factory.
  15. Oct 3, 2011 at 11:10 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I put maybe 10 strokes in my 2007 the first time I lubed it. It had 15K miles at the time.
    Good practice is to not mix grease types. So yeah, purge the old stuff out just on principle. But then, I purge all the old grease from my u-joints when I lube since I'm rarely positive I'm using exactly the same grease and... why not?
    I don't believe using something special (like synthetic grease) will do anything for a u-joint. I say that because I've never had a problem with any u-joint I've kept lubed, even using whatever crap grease it is that comes bundled with the grease gun. That's never. Ever. Just lube it regularly and you'll be fine.
  16. Oct 3, 2011 at 3:05 PM
    rjbb2
    rjbb2 [OP] Member
    Bob
    NC
    2011 4x4
    Thanks, gives me reassurance that I did not over do it on a new truck. Guess these are not shipped from the factory with much grease in them. I guess I'll hit them ever other oil change and be ok.
  17. Oct 3, 2011 at 3:08 PM
    rjbb2
    rjbb2 [OP] Member
    Bob
    NC
    2011 4x4
    I was pumping and pumping (the grease gun that is:laugh::yay:) and was wondering where the hell all the grease was going? They are pretty dry from the factory.
  18. Oct 3, 2011 at 3:09 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    Would no grease cause a squeaking noise ??? (In the front passenger side)
  19. Oct 3, 2011 at 3:09 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Possibly.
  20. Oct 3, 2011 at 3:11 PM
    Night
    Canada
    I was wondering because I have this really annoying squeaking sound between 50km/h and 60 km/h.
