Zerk help !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 5, 2010.
  1. Sep 5, 2010 at 5:10 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Changed oil and greased the drive shaft zerks - well tried to any way. Back is easy - they are completely exposed. The front ones are a PITA - they are hidden inside the U. I finally got them but it took a few tries and a few different guns to do it. Does any one have any tricks to make it easier ? If I should post this somewhere else on TW just tell me where. Thanks for any help.
  2. Sep 5, 2010 at 5:16 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    I found that if you move the vehicle just a little bit you can get on all of them. Trial and error, but you can do it with a regular grease gun with a flex shaft on it.
  3. Sep 5, 2010 at 5:17 PM
    gooberpeas
    gooberpeas Active Member
    Georgia
    2010 PreRunner SR5
    do you have a u-joint adapter for your grease gun?
  4. Sep 5, 2010 at 5:21 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2...might have to rotate the driveshaft to get to it. Also, I have one of those smaller "gun" type grease guns and I don't have any problems.
  5. Sep 5, 2010 at 5:22 PM
    george3
    new jersey
    tacoma
    You have to move it to do the rear ones but they are no problem as they are completely exposed. They front ones are the problem because they are inside the U. They shaft can be turned easily by hand if you put it in neutral. Thanks.
  6. Sep 5, 2010 at 5:26 PM
    george3
    new jersey
    tacoma
    Probably not. Can you post a link or a picture. I'll get one. I use an regular gun with a flexible hose and I finally got it with a small hand gun. I'd really like to get a u-joint adapter if that will help. Thanks.
  7. Sep 5, 2010 at 5:27 PM
    george3
    new jersey
    tacoma
    I finally got it with a small hand gun. Thanks.
  8. Sep 5, 2010 at 7:12 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
  9. Sep 5, 2010 at 10:57 PM
    george3
    new jersey
    tacoma
    Thanks Crom, for the link. Appreciate it !
