Zerks & Grease
Discussion in '1st Gen. Tacomas (1995-2004)' started by gonathan85, May 11, 2010.
  1. May 12, 2010 at 11:58 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Excess grease in the U-Joints just gets spun off everywhere...Excess grease in the Slip Yoke ends up ozzing out the open yoke end...
  2. May 12, 2010 at 12:29 PM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    BFG TAKOs, Deck Plate, k&n, Bullie w/ PIAA 520s, Alpined w/ 8" sub, All Mobil 1 synthetic.
    My bad. Yes slip yoke. Technically you grease the shaft spiders but yeah the u-joints. My point was to not over apply grease to the yoke. Skol.
  3. May 12, 2010 at 12:39 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I'm just curious...Did u get this info from the FSM? I would like some back up facts pls...There are numerous threads regarding greasing and not one of them states it's harmful to overgrease...
  4. May 12, 2010 at 1:35 PM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Thanks skol!!
  5. May 12, 2010 at 2:42 PM
    Skolfoppa
    Skolfoppa Member
    MN
    Black 3.4 TRD
    Its not in the FSM. Its basic hydraulics. When the yoke has too much grease the shaft can't compress and "can" cause damage. For most grease applications the idea is lubrication not saturation. This is my .02, so do whatever you feel is best for your vehicle. Skol.
  6. May 14, 2010 at 5:36 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    My Haynes Man. says just pump grease into the the slip joint grease fitting until it comes out of the slip joint seal...
  7. May 14, 2010 at 8:07 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I use Mystik JT-6 on my entire drive shaft and it works great. Pump it in til you see some old grease come out.
  8. Oct 17, 2010 at 7:17 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Hey, I have a 2004 ext cab Tacoma and I found 9 grease fittings on the two drive shafts, not only 8. Are you sure you got em all ???????
  9. Oct 18, 2010 at 4:53 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
  10. Oct 18, 2010 at 6:15 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    Yep, I own a grease needle too. You can pick them up at Autozone for 3.99. No excuses for anything going dry and they are real handy to have.
  11. Oct 18, 2010 at 6:26 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Hummm ... some good advice (and links) on this thread.
  12. Jul 11, 2011 at 1:05 PM
    TheTourist
    TheTourist Member
    Central Alberta
    01 xcab 2.7L 4x4
    there are definitely 9 grease nipples on my 01.
  13. Jul 11, 2011 at 2:53 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    yup 9 on my 02 4x4
  14. Jul 22, 2011 at 12:48 PM
    40950
    CR, WA
    stock
  15. May 2, 2013 at 7:01 AM
    #35
    Bultaco57
    Bultaco57 New Member
    OK
    10 PreRunner V6 SR5 TRD Sports
    Dealership tells me my driveshaft needs lubrication on my (2 WD) Pre-Runner but there are no zerks and it will need to be added in order to grease it. Wanted to charge me $250. I rather do this myself to save cost and anyone know how to go about this? I saw somewhere where there are 2 different kind of zerks and 2 different kind of grease. Will need instructions which zerks go to what and does it already have a bolt in place for you to replace it with zerks.
