Zerks or no..?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rick1051, Oct 23, 2023.
  1. Oct 23, 2023 at 3:26 PM
    Rick1051
    Rick1051 [OP] Member
    Rick
    2013 Grey Tacoma
    Ok I know, stupid question but I was handed down a 2013 2WD PreRunner from a family member and I went to grease the driveshaft u joints but don’t see any? Isn’t there supposed to be 5 separate locations? Pardon the ignorance, still learning the truck. Thanks guys!
  2. Oct 23, 2023 at 3:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Likely were changed. It's arguable, that the sealed units are better. Toyota switch to sealed units for 2nd gens after a large customer satisfaction campaign.
    I havent replaced a worn sealed one yet.
    joba27n and Rick1051[OP] like this.
  3. Oct 23, 2023 at 3:53 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    5 zerks is for 4wd only anyways. Three on the rear driveshaft and 2 on the front driveshaft.
    XSplicer62, Rick1051[OP] and Tiedie like this.
  4. Oct 23, 2023 at 4:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    I think all 5 lugs have no zerks, as sold that is.
    Rick1051[OP] likes this.
  5. Oct 23, 2023 at 6:01 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Prerunners like mine have no zerks. It's part of the stage III weight reduction package:bananadance:
    Rick1051[OP] and GTGallop like this.
  6. Oct 23, 2023 at 6:03 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Smart move... Those Zerks are heavy. "It weighs as much as 10 boxes you would use for moving." ~ Sheila Jackson Lee
    JustAddMud and racerX969 like this.
  7. Oct 23, 2023 at 6:08 PM
    2WD
    Pete
    Not to mention you need a grease gun with a large capacity to use them should be banned!
    GTGallop[QUOTED] and JustAddMud like this.
  8. Oct 23, 2023 at 10:33 PM
    Waasheem
    Waasheem
    2007 xrunner
