Zerks
Discussion in '1st Gen. Tacomas (1995-2004)' started by HeadlampRevamp, Mar 7, 2011.
  1. Mar 7, 2011 at 10:48 AM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Got under the truck this weekend to grease drive shaft but noticed that the zerks are completely rusted. Would it be ok to go ahead and put a grease gun to them if I took a wire brush to them first? Just afraid of rust getting pushed through when the grease is applied.
  2. Mar 7, 2011 at 12:03 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Try to wipe off the 'ball' that's exposed on the top. That's the critical part. You could try to get grease in there... but the ball might be seized. You'll know almost immediately if the ball is seized (the grease won't go in and will just come out the sides).
    You could replace them.....
    Some zerks are 'press in' and others are 'threaded in' - I'm not sure which ones the tacoma has. You can try to unscrew 'em..... but they're made of soft metal and if they're that rusty, they'll break. If they break, use an 'Easy Out' to remove the stud left in the hole.
    And honestly? If the zerks are rusted, then there's probably rust inside the bearings that you can't see.
  3. Mar 7, 2011 at 12:38 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I always push in the ball in the zerk with a punch, to free it up so the grease WILL go into the bearings.
    Most are replaceable too if they're too corroded.
