Zero RPMs, Zero Temperature reading, ABS + TRAC light while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ramonortiz55, Feb 17, 2016.
  1. Feb 17, 2016 at 8:06 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Yup.
    Just as the title says it.
    Started last week while my pops was borrowing my truck. He mentioned to me that while driving at constant highway speeds the following happened:
    RPM reading dropped to zero.
    Temperature reading dropped to zero.
    ABS light is on.
    TRAC light is on (truck with squiggly lines below it).
    I asked him if it was raining or if he was driving fast in any type of slippery condition and he said no.
    I really don't drive the Tacoma as much, but I decided to drive it to work this week and see if I could replicate the issue.
    I recorded this:
    https://youtu.be/YtLaSXBM_bc
    I apologize for the camera being sideways. The only way I could record this was while I was driving and I did so in the "safest" manner.
    I searched on TW and only found issues with the ABS + TRAC lights kicking on randomly while driving, but nothing that had the RPMs and Temp gauge drop to zero.
    Any thoughts?
  2. Feb 17, 2016 at 8:10 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Here is a picture I took:
  3. Feb 17, 2016 at 8:11 AM
    ramonortiz55
    Ramon
    Texas
    stock
    A couple of miles down the road I decide to pull over and see what happens, gauges resumed normal operation but lights remained on.
  4. Feb 17, 2016 at 8:13 AM
    ramonortiz55
    Ramon
    Texas
    stock
    oh, and the truck is perfectly stock with the only thing I did to it was relocate the smog pump (secondary air injection pump, whatever you call it)
  5. Feb 17, 2016 at 8:16 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Since you got it well documented, seems like warranty time.
  6. Feb 17, 2016 at 8:18 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I know it has warranty, and I will take it to the dealer.
    I would like to see what everyone thinks the issue is, and I am starting a thread for anyone that has an issue on this in the future.
  7. Feb 17, 2016 at 9:32 AM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Don't happen to have anything plugged into the OBD2 do you? I had to trickle charge my truck 6 weeks ago. Once she started I was down the road going 40mph or so when my dash lit up like a Christmas tree and my gauges went to zero (except speedometer). I pulled over and unplugged, and plugged in my UG and everything was fine. Haven't had any problems since.
  8. Feb 17, 2016 at 9:33 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I have an ultragage plugged in.. hmmm...
  9. Feb 17, 2016 at 9:33 AM
    AKHawkeye
    Anchorage, AK
    Locked as stock
    It was also colder than a witches tit and hadn't ran in 3 weeks.
    Whelp, this edit turned into a self quote.
  10. Feb 17, 2016 at 9:34 AM
    ramonortiz55
    Ramon
    Texas
    stock
    i doubt the cold had anything to do with it. Tacoma spends most of its time under a cover since I mainly drive the Camry for work and a 3rd gen 4runner for trail rides
  11. Feb 17, 2016 at 9:36 AM
    ramonortiz55
    Ramon
    Texas
    stock
    The UG is plugged in, but the screen doesn't read any gauges. It continously reads "searching gauges" or "scanning gauges" something like that.
    It does that because I didnt set up the UG properly when i transferred it from the 2013 Tacoma to the 2015 Tacoma.
    Ill have to unplug it and drive it like this for a couple of days and see what it does...
  12. Feb 17, 2016 at 9:38 AM
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Try running with it unplugged from the OBD2 port and see if you experience any issues with the gauges?
    :notsure:
    Speedo, tac, voltage, and lights that is.
  13. Feb 17, 2016 at 9:39 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Ill try that.
  14. Feb 17, 2016 at 1:49 PM
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    Had a similar problem with my 2015 due to the UG...... It was unplugged during an alignment and not re-installed properly. Caused the TRAC + VSC + ABS lights to illuminate while driving, but the UG went blank. Problem solved after I removed, then re-installed the UG plug into the OBD port. Been good for almost 4k miles now......
  15. Feb 23, 2016 at 10:35 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Well, looks like it was the UG.
    I've had it disconnected and no issues at all.
    Saves a trip to the dealer.
    Fenwick1993 likes this.
  16. Feb 23, 2016 at 10:37 AM
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Good to hear this solved your issue. You should be fine with plugging it back in. If it's not seeded properly it can cause some funny business. Maybe your Dad hit it with his knee or leg while entering/exiting the vehicle.
  17. Feb 23, 2016 at 10:37 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Glad to see its not just first gens that have issues with the UG :)
    Glad you got it fixed!
  18. Feb 23, 2016 at 10:40 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    :fingerscrossed:
    Hope it stays fixed.
  19. Feb 23, 2016 at 10:49 AM
    ramonortiz55
    Ramon
    Texas
    stock
    its probably what happened.
  20. Feb 23, 2016 at 10:50 AM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    I had the same thing occur on my Tacoma, turned out the trailer wiring harness got ripped and was causing electrical shorts.
