Zero Undercoating!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeTako, Sep 30, 2015.
  1. Sep 30, 2015 at 6:50 AM
    scw156
    scw156 Well-Known Member
    PA
    2016 DCLB Off-road MGM
    I have an Infiniti that has undercoating from the factory. At least I assume it's from the factory as I didn't pay extra for anything unless the dealership just threw it in for free.
    Overall the car looks great. I'm under it several times a year and no rust anywhere and it's a 2010. That is unless the rust is hiding under the undercoating.
  2. Sep 30, 2015 at 6:51 AM
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    I am no expert in undercoating, the last car I had undercoated was probably 30 years ago. I have a feeling that there is good undercoating and bad undercoating. I also believe that not every vehicle needs it. I had a BMW that was clean after 10 years (body rusted out though). I would not hesitate to undercoat a Tacoma, rust seems to be their Achilles heel.
    If I remember correctly, the 80's pickup had rust issues all over the place. the famous 2 piece pickup bed with a gob caulk... that was not one of their better ideas. That was the truck that got me wanting a Toyota pickup, I loved the one in back to the future. by the time I got around to getting one it was a 91 and the two piece bed was gone.
    Carl
  3. Sep 30, 2015 at 6:55 AM
    R o g u e
    R o g u e Member
    1996 Dodge Ram 2500 12 valve Cummins
    Someone posted this on another thread. I cannot attest to these guys in particular, but most folks who live in severe weather environments swear by
    oil spraying in general. I see they have a DYI kit.
    Rotten - how are the Krown shops? My problem with them is they aren't close by.
    http://nhoilundercoating.com/Do_it_yourself_kit.html
  4. Sep 30, 2015 at 6:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Shame on me for going by the thread title of 'Zero Undercoating'
    AFAIK this doesn't translate to 'unpainted frame'. But I've been wrong at least once a day for a long time.
    Hobbs and thecelt[QUOTED] like this.
  5. Sep 30, 2015 at 7:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    My Z cars and my Mazdas did have some factory treatment, so I understand what you are talking about. While it's a rust preventative for sure, it's not the traditional 'tar like' undercoat that is often applied when we think of the term 'undercoating'. The stuff you speak of is well bonded to the metal, and hard as a rock! Toyota would do well to use that in key places prior to assembly.
    In fact, my '90 Z had lots of cosmoline underhood as a protectant while shipping. Didn't care for that too much, as it made the bay more difficult to have look nice.
  6. Sep 30, 2015 at 7:04 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    :worthless:
    thecelt likes this.
  7. Sep 30, 2015 at 7:09 AM
    wachuko
    wachuko Well-Known Member
    Orlando, FL
    WTB-2019 Tacoma Double Cab TRD Off Road 4x4
    My plan is to do it myself... for the frame. I was planning on using POR-15 and then paint over it. Since POR-15 is not UV resistant, you must coat over it with something that is.
    I was thinking of doing it immediately after getting the truck to avoid dirt to build up and then have to spend more time cleaning stuff out.
  8. Sep 30, 2015 at 7:11 AM
    rottenpixies
    rottenpixies Well-Known Member
    New York
    2015 DCLB 4X4
    Haven't used them yet, but by doing rust prevention research on here I found a few people recommending them. They have the oil type spray that everyone says won't collect moisture. Will report back after I have it done (will be soon before winter)
  9. Sep 30, 2015 at 7:13 AM
    mercerc
    Carl
    Palmyra NY
    that will be one rock solid frame. I have read others on these forums who did the same thing. they ended up only painting the outside of the frame where the sun could hit it, the rest they left with POR-15.
  10. Sep 30, 2015 at 7:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not sure why you'd have a UV resistance need for the frame area, unless you park upside down a lot. :D
    However, you might look into the encapsulator (what POR-15 is) from www.monstliner.com
    I think it can be left plain.
    wachuko[QUOTED] likes this.
  11. Sep 30, 2015 at 7:18 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Theoretically, just about anything works. The reason they seldom do, is workmanship and the idea you can treat metal just once. Sloppy workmanship clogs drain holes and if it hardens and cracks, it actually promotes rust. That 's why you only use stuff that must be reapplied every year and you do it yourself. When you store a motor, you fog the inside with oil because it runs and coats with the help of gravity to reach areas you normally could not after assembly in enclosed areas. But like you motor oil, you still have to reapply it as it does wash away eventually.
  12. Sep 30, 2015 at 7:19 AM
    wachuko
    Orlando, FL
    I have painted a few things with just POR-15 and leaving it outside, unprotected, gives it a dull/cloudy look over time (even if not directly exposed to the sun). So best to coat it with some paint that will hold and look great.
    I will take a look at that encapsulator. Thank you for the link.
  13. Sep 30, 2015 at 7:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    www.monstaliner.com
    Spelled it wrong in the first link. Sorry.
  14. Sep 30, 2015 at 7:28 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Long lasting coatings will be waxy, which then you should read the threads about removing and cleaning that stuff off, and the dirt it collects.
    I take the boat/Marine approach. A light, water displacing oil. It only takes a minute or two to go around the truck and spray everything. Easily cleaned off, easily applied, displaces water, electrical safe. If it collects dirt, once again it's easily cleaned off for reapplication.
    My process is every couple months, I go around the truck with Marine Simple Green, rinse, then spray CRC 6-56 on metal, and 303 on the rubber/plastics.
    I've been planning to pick up a six pack of 4oz POR-15 cans. I've read that you want to use the whole can once you open it, so you don't want a huge can unless you plan to knock out the entire frame in one sitting.
    For me, I'm starting to get a little rust around welds.
    My plan there is since it's an encapsulator, and actually prefers a little rust to grab onto, just get a fresh stainless brush from the welding area at the Depot, brush the weld area, wipe off with acetone, apply the POR-15 with a small brush. Once it's cured, hit it with some chassis black spray paint, let cure, then reapply CRC.
  15. Sep 30, 2015 at 7:30 AM
    #35
    BadBrains
    AL
    @DeTako We'll probably meet up at some point to cruise the Eglin range, then you can check out my truck and judge for yourself.
    DeTako[OP] likes this.
  16. Sep 30, 2015 at 8:02 AM
    #36
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Too bad he doesn't have any cool stories.
  17. Sep 30, 2015 at 8:29 AM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    After your careful work, doesn't seem like CRC would be needed (in those areas) again. Encapsulated is pretty much it, no?
  18. Sep 30, 2015 at 8:31 AM
    #38
    DeTako
    DeTako [OP] Well-Known Member
    Felix
    Florida
    '16 TRD Sport 4x4 DCSB
    Dude! Solid advice... Thank you!
  19. Sep 30, 2015 at 8:55 AM
    #39
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    At least the new Chevy trucks dip or spray their frames before assembling with a black waxy substance.
  20. Sep 30, 2015 at 8:56 AM
    #40
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Has anyone noticed that there's no more radio antenna.
