Ziebart vs. Krown vs. Fluid Film
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fgeorge097, Aug 21, 2018.
  1. Feb 8, 2020 at 2:09 PM
    #81
    Rick111
    Rick111 Well-Known Member
    Rick
    2019 DCSB TRD OR 6M
    ARE Z series cap w/Bedrug
    The excess ‘red colored, liquidy’ Rust Check runs out and does not plug up the drains at the bottom of the doors and rocker panels. Look underneath where the rocker panel sections are stamped together. Fluid runs out of that area. It is not sealed there. And I can verify that the little rubber plugs come out and reinstall easily. Also there’s a larger plug on the aft side of the body above the rocker panels and large plugs on two of the doors.
  2. Feb 8, 2020 at 7:10 PM
    #82
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
    I know mechanics in the Watertown, NY area that will not work on an older model vehicle that had Zeibart applied. The problem is rust forms under the the coating they put on and you can't see it.
  3. Feb 8, 2020 at 7:14 PM
    #83
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    That's horrible advice. Honestly
    Rick111 likes this.
  4. Apr 19, 2020 at 11:37 AM
    #84
    0341Taco
    0341Taco Member
    Chad
    2016 White Tacoma TRD Off Road 4x4
    Hi guys, I had my 3rd gen Tacoma done by ziebart last October. After learning more about undercoating I wish I went with a oil based. My question is, can I still apply fluid film over the permanent coating and will this still help with rust prevention?
  5. Apr 19, 2020 at 1:05 PM
    #85
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    I get an oil undercoating (NH Oil Undercoating) done once a year on my truck. Looks nearly new under it. I also have cans of fluid film for squeaky leafs and that seems to be a temporary fix... but they're not rusty! I really need to take the leafs apart...
  6. Apr 20, 2020 at 6:52 AM
    #86
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I would say yes because the fluid film should creep into any openings in the undercoating.
    0341Taco[QUOTED] likes this.
  7. Apr 24, 2020 at 3:05 PM
    #87
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Agreed. The problem with leaving it alone is this...... just cant see where the cancer is happening til it's too late. This can be prevented or at least slowed.
  8. Apr 24, 2020 at 3:08 PM
    #88
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Anyone have any experience with this? My son is an aircraft mechanic. Wondering if this military grade corrosion preventer is worth a try or if it will explode if it gets too hot. 20200424_175146.jpg
  9. Apr 24, 2020 at 3:24 PM
    #89
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Where do you live in the northeast? I do FF applications for TW members $40 each. My truck is a 2014 with 150k, no rust. Located north central CT. PM if interested
  10. Apr 24, 2020 at 7:36 PM
    #90
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    You wanna know what the best rust protection is of all time? I've never seen a spec of rust on any of my vehicles. Wait for it...
    Live in Texas.
    Coolerman and Junkhead like this.
  11. Apr 24, 2020 at 9:02 PM
    #91
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You bastard.:rolleyes:
    andrewkissam[QUOTED] likes this.
  12. Apr 24, 2020 at 9:12 PM
    #92
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    ACF-50 for aircraft is making a name as a rustproofer (and lots of other things, which makes me more suspicious)
    100 dollars a gallon.
  13. Apr 25, 2020 at 4:59 AM
    #93
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Ok. I did a bit more reading on this So Sure stuff my son brought home. Apparently it's a military spec corrosion preventer for interior applications. Exterior grade applications need reapplication monthly. Not really a break through technology. He fabricates panels for the F16 and does structural maintenance, so he uses this stuff on bare metal. Sorry for the spam, I was hopeful someone else might have had some experience with this stuff. Looking like fluid film is a better yearly maintenance option than this.
  14. Apr 25, 2020 at 5:14 AM
    #94
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Don't know how zeibart is formulated today, but my brother had his 77 trans am done when bought new. That car looks as good today as it did new. You can see where they drilled holes in all the places that rust and filled with the stuff then plugged. Even the undercarriage of the car looks like it just came from the factory.
    Junkhead likes this.
  15. Jul 6, 2020 at 6:20 PM
    #95
    Chuck X1
    Chuck X1 Well-Known Member
    Chuck
    NW Indiana
    2020 Tacoma TRD Off Road
    Had an old timer tell me about a product called “Cosmoline”. He lives in Pennsylvania and owns an ancient Chevrolet that’s at least thirty years old. I looked it up on Wikipedia and it was developed back in WWII to prevent corrosion. Fluid Film, LPS-3, and others all seem similar. He said the truck still looks like new.
  16. Jul 6, 2020 at 7:16 PM
    #96
    cruxofthebisquit
    Orange Texas
    2000 TRD
    our first Gens are 20 or so.
  17. Jul 7, 2020 at 5:44 AM
    #97
    Chris_The_Red
    Chris_The_Red Well-Known Member
    Brooklyn, NY
    2018 Cement Tacoma TRD OR
    Cosmoline is pretty good. Removed it from some older firearms (M1, SKS, etc.) in PA. That stuff is a pain to remove. Almost like a heavy duty petroleum based coating. My brother in law just did the underbody on his Ram 2500. I guess we’ll see how it holds up.
  18. Jul 7, 2020 at 6:16 AM
    #98
    zoo truck
    None
    I did the undercarriage of my truck with it. Found out they now offer RP-342 cosmoline in black also. Its funny the regular cosmoline looks real similar to spectro chain wax, even smells similar.
  19. Jul 7, 2020 at 6:21 AM
    #99
    zoo truck
    None
    Forgot to comment cosmoline can be removed pretty easy with mineral spirits or kerosene. Acetone works ok to.
    Chris_The_Red[QUOTED] likes this.
  20. Jul 7, 2020 at 6:23 AM
    #100
    Chris_The_Red
    Brooklyn, NY
    Yeah, that’s exactly what I did. Quick google search and we were well on our way.
