zip tie on shock rubber
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hmsailor, Dec 27, 2017.
  1. Dec 27, 2017 at 12:13 PM
    hmsailor
    hmsailor [OP] Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    do i have to cut it? its all wrinkled up.
  2. Dec 27, 2017 at 12:16 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    naw just slide/pull it bach down. No problems, common :cheers:
  3. Dec 27, 2017 at 1:19 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    No need, just work it a bit and it'll slide down
  4. Dec 27, 2017 at 1:54 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Sounds like something you need to speak to your urologist about
    hmsailor[OP] likes this.
  5. Dec 27, 2017 at 1:58 PM
    Pigpen
    Dan
    Northwest Montana
    Cut it off. It doesn't do anything of value. The shocks look better without it too.
