Zombie Response Vehicle
Discussion in '2nd Gen. Builds (2005-2015)' started by Spencer, Mar 13, 2013.
  1. Mar 18, 2013 at 7:07 AM
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    you should! I figured to keep that OEM look to my truck I could either go with the orange LED look from the dash or pick the white led look- so I went with the white- my Flyzeye thing has the stock orange front led's and white lights-
    that being said,
    I apparently put john through hell wiring this panel to his sPOD cause these sexy switches came from eBay & he had to wire them himself.
    But
    they do make the switches i got in almost any color...
    I'd call & ask if he'll do the same setup for ya now that he's got all the measurements.
  2. Mar 25, 2013 at 2:30 AM
    Spencer
    TIGGLEBITTIES
    Newest add today:
    Viar air compressor!
    Mounting the tank has been a pain in the ass!
    Fabricated this doodad up so that the compressor sits nice and level & purrdy on the passenger side where those three random studs are.
    I'm proud of myself on this one. It sits securely & level
    But
    I found out the hard way what happens when you pull a new Metric style truck into my garage...
    The garage is stocked to the hilt with years on years of hardware and shit to fabricate repair and build two generations worth of jeeps, a scout and four other fords we've owned.
    Turns out there was ONE metric nut I found that had rolled under a shelf full of a thousand other American style hardware. Still looking for two more...
    Anyways
    It goes there.
    I'll post more pics later when I'm actually done.
    Side note
    Thank god for my sPOD.
    This install is CLEAN!
  3. Mar 26, 2013 at 1:59 AM
    Spencer
    TIGGLEBITTIES
    I hate getting off work late.
    Er
    My Neighbors hate that cause I end up working on my truck till 1 am.
    Got the tank mounted and ran the output side of the air line. Keeping a pretty good winning streak of clean installs if I don't say so myself
    Awful pic. Ill do a separate detailed write up on this later & put better pics here.
    Anyone know how I can find the temperature ratings on the OEM wire harnesses/ parts? This compressor- like all- gets hotter than the devils asscrack & melted the coating of at least one thick ground wire on the last truck it was mounted on... The place I have it now is pretty close to the wires.
    Or
    Does anyone have a suggestion of how to shield wires or hoses from melting from the heat of a hot steel air hose?
    Thanks
    goblue82 likes this.
  4. Mar 27, 2013 at 2:24 AM
    Spencer
    TIGGLEBITTIES
    Alright finished up the on board air
    Tank is under the drivers side with a pressure cutoff switch that must be wired in the circuit of the power switch.
    So I popped these off, drilled a hole, set a rubber grommet and popped off the factory grommet below it on the frame
    This second photo is the underside of that hole. This is a great place to run wires into the cab, as there's great places to zip tie wires etc to along the frame around here-
    avoid drilling into your body!
    And the system cuts the relay off at 110 psi and it's all holding steady!
    I can actually just Leave the compressor switch on all the time and it won't come on until I use it... But I won't. Either way makes it idiot proof and fail safe.
    If you install on board air,
    GET GOOD HOSE CLAMPS.
    I had some piece of shit china made hose clamps that made the air system leak like a sieve when I first turned it on. All four connections were leaking so I trashed the dinky little ones & put bigger ones stamped made in USA and bam. It'll hold forever.
    I used 3/8" hose and found some nifty places to run it inside the frame under the engine.
    if anyone's interested ill crawl back under and take pics & share my secrets
  5. Mar 28, 2013 at 8:04 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Clever bro!!!!
  6. Mar 29, 2013 at 12:08 AM
    Spencer
    TIGGLEBITTIES
    Well I'm bored. I think I'll get it tinted when I'm off work tomorrow.
    Found a couple of great groupons for it.
    Also
    If you're ever in need of car parts, auto work, tint or stereo parts,
    Get comfortable with Holt blvd in Pomona Ontario area west of Euclid street. Haggle for cash & DO NOT settle for the first place you stop at. Go to two and when you come back, you'll get stuff done for so damn cheap. They're desperate for cash.
  7. Mar 29, 2013 at 2:42 PM
    Spencer
    TIGGLEBITTIES
    If you're in socal
    Go to Steve's auto tint in upland.
    Not the cheapest, but I've had four cars done here and they're fantastic. ImageUploadedByTapatalk1364593341.581257.jpg
    More pics to follow.
    Damn I'm getting impatient with this build I'm gonna be flat broke soon DAMN YOU TACOMAWORLD
  8. Mar 29, 2013 at 6:53 PM
    Spencer
    TIGGLEBITTIES
  9. Mar 30, 2013 at 8:34 PM
    Spencer
    TIGGLEBITTIES
    Okay got the CB antenna hood mounts done!
    One side will be for cb, the other for short wave ham radio, the other will be CB.
    The CB will come first, HAM pending getting my certification for shortwave comm.
    Also I have a short antenna
    But I realized there's no use in getting a leetle antenna right next to two other giant cb/ ham antennas.
    Anyone want it? Just pay for shipping or gimme a beer & ill be over !
  10. Mar 30, 2013 at 8:38 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Spencer, love the build so far, especially from one Zombie guy to the next...not to mention, I was BORN AND RAISED in Upland! I still visit all the time.
    Keep up the good work, and if the outbreak ever happens, I know I got a friend in the 909. :thumbsup:
  11. Mar 31, 2013 at 7:44 PM
    Spencer
    TIGGLEBITTIES
    Thanks!
    I can't help myself on this build. I have so much I need to do to make it outbreak ready. If you need a buddy to go abuse our tacos with just let me know- i seriously need to make friends that actually know what they're doing outdoors and offroads. Most of my friends own civics and the like. :/
  12. Mar 31, 2013 at 8:07 PM
    Spencer
    TIGGLEBITTIES
    And next up this month is a roof basket fabbed up by Pelfriebuilt that'll house my 9" HID's
    (And secure cargo for cross continent travel when the outbreak happens)
    I went with these 9" HID's cause
    While yes, they're cheap china made bs,
    They work GREAT and they're again, cheap. The 400$ hella or similar hid will break just as easily given a good rock or shady thief, while mine can be replaced with 75 bucks and some digging around.
    I heard they're not very waterproof, so I opened the cases up and siliconed every seam inside & resealed them.
    This roof rack is gonna set me back a bit, so my next badass mod is gonna be a while after this.
    And my student loans are coming due in a few months... :(
    Anyone wanna donate to my cause?
    I take PayPal, Beer or food.
  13. Mar 31, 2013 at 8:11 PM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    Did someone say.. Zombie Response Vehicle? :eek:
    Never heard of such thing!
    :cool: :D
  14. Mar 31, 2013 at 9:52 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    :popcorn:
    This is gettin' good. . .
  15. Apr 1, 2013 at 12:09 AM
    #35
    The Traveler
    SoCal
    Well since Swanks did it...I have a total of 12 zombie decals on my truck. :D
  16. Apr 1, 2013 at 12:33 AM
    #36
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    X2 on Steve's Tint in Upland on Foothill! I have had 6 vehicles dome there and will have a 7th pretty soon. Cheapest package is around $199 and goes up to $399+ which is outrageous compared to other shops, but that place is LEGIT and your tint will never fade, peel, or bubble. Just thought I'd throw that out there.
    Also OP, I live right here in Pomona area and do electrical installs for many local members. If your ever in need of assistance for your wiring feel free to hit me up anytime. Check the link in my Sig for more details. I'll be updating my install thread shortly with 4 installs I did this weekend on members' trucks.
    Good job so far :)
  17. Apr 1, 2013 at 6:25 AM
    #37
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Such a badass truck :drool:
  18. Apr 1, 2013 at 6:52 AM
    #38
    Spencer
    TIGGLEBITTIES
    Ha! Looks like I'm gonna have to join in on the zombie decals soon!
  19. Apr 1, 2013 at 6:54 AM
    #39
    Swank
    Steven
    Greenville NC
    SOLD/TOTALED
    Ebay! I also snatched up these :D
    #39
  20. Apr 1, 2013 at 10:08 AM
    #40
    Spencer
    TIGGLEBITTIES
    #40
