Zombie Response Vehicle
Discussion in '2nd Gen. Builds (2005-2015)' started by Spencer, Mar 13, 2013.
  1. Sep 19, 2013 at 10:20 AM
    #121
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    bad ass! subd
  2. Sep 19, 2013 at 3:51 PM
    #122
    Papa Taco
    Papa Taco HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
    nice shocks.... :jellydance:
  3. Sep 19, 2013 at 4:37 PM
    #123
    Spencer
    Spencer [OP] Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Thanks !
    Kinda useless without the rest unless I'm making some badass pogo sticks lol
    Keep an he's on the group buy section I got em from down south- they do little 5-6 person buys so you gotta be quick!
  4. Sep 24, 2013 at 8:01 PM
    #124
    Spencer
    TIGGLEBITTIES
  5. Oct 6, 2013 at 11:03 PM
    #125
    Spencer
    TIGGLEBITTIES
    Crappy pic
    But
    Got my ham radio in finally!
    Pics to follow in the daylight...
  6. Oct 6, 2013 at 11:05 PM
    #126
    Spencer
    TIGGLEBITTIES
    Also
    A new Deaver leaf pack,
    KING 2.5 " rear shocks
    Total chaos UCA's
    And KING 2.5" 600 rate coilovers are purchased and on their way to me. This beast is about to get sexy.
  7. Oct 29, 2013 at 11:42 PM
    #127
    Spencer
    TIGGLEBITTIES
    Pssst. Hey you.
    If you're subscribed to this thread, you'll see this first.
    So I'm giving you first crack at my suspension.
    15,000 miles on stock 2013 offroad Bilstein suspension- all of it. UCA'S, coilovers, rear leafs and rear shocks.
    soon as four wheel parts gets their shit together, it's all coming off and going for sale to feed this addiction. Leave your name here and you'll be first at it.
    Should be all off and ready to ship this weekend! Lemme know if anyone's interested.
  8. Oct 31, 2013 at 11:44 PM
    #128
    Spencer
    TIGGLEBITTIES
    Aww skeet skeet god damn.
    ImageUploadedByTapatalk1383288226.211841.jpgImageUploadedByTapatalk1383288237.477348.jpg
  9. Nov 2, 2013 at 10:05 AM
    #129
    Spencer
    TIGGLEBITTIES
  10. Nov 2, 2013 at 11:45 PM
    #130
    Spencer
    TIGGLEBITTIES
    Annnnnd the clusterfuck continues....
    Deaver gave me one wrong bushing, so one leaf can't be installed
    And 4 wheel parts sold me rear shocks that are 3" too short at full droop.
    I assume the shocks can't be the limiting factor in down travel...
  11. Nov 4, 2013 at 6:01 PM
    #131
    BajaRunner
    BajaRunner Rock magnet
    Drew
    Chino Hills, CA
    12 4wd DC Tacoma TRD OR
    Which Deaver leaf packs did you get? I'm considering Deaver and Allpro.
  12. Nov 4, 2013 at 6:54 PM
    #132
    Spencer
    TIGGLEBITTIES
    The j66 pack. It's beautiful. The stock was a two leaf and went fully negative arch when jacking it up.
    Be careful with your shocks though! It gives you 1.5" lift, partly through the thickness of it- the king 2.5" that are available do not fit this setup. At full droop they're about 2" too short :/ I figure I'm not gonna be jumpin it any time soon so ill be okay but i hate knowing the shocks are the limiting factor on the axle.
    If you're not running constant weight in the rear, go for Deaver. Otherwise the all pro expo pack, which needs about 500 lbs constant to ride well.
  13. Nov 4, 2013 at 6:56 PM
    #133
    Spencer
    TIGGLEBITTIES
  14. Nov 6, 2013 at 12:21 AM
    #134
    Spencer
    TIGGLEBITTIES
    Coilovers adjusted. Learned a hard lesson.
    If you get kings & need to adjust, it says you must remove from the mount & put it in a vice to adjust it. (2.5 turns is .5")
    DISCONNECT THE TAPER BOLT FROM THE UCA. Then swing the uca way up outta the way- the coilover will not come out by any other means whatsoever. It'll get close, but you'll just smash your fingers & scuff up the shiny parts. Do NOT remove the top portion of the taper bolt that goes through the UCA uniball. You'll never get that uniball to rotate at the right angle & just fuck up the uniball.
    Hold the bottom shock mount in a vice, but stick an Allen in the top mounting plate Allen to keep the head from rotating the shaft in the bottom mount. The instructions do not mention this for some stupid fuckin reason, but if you don't keep the top plate and bottom shock mount aligned while cranking the spring down, you'll take five times as long to crank it down and spend a half hour confused & angry as to why the shock won't line back up into the truck.
    Pics to follow all these instructions soon.
    Once I figured all this out, I got one side totally done in 30 minutes. Learning that process took 4.5 hours.
    goblue82 likes this.
  15. Nov 6, 2013 at 6:51 PM
    #135
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Who builds that roof rack
  16. Nov 6, 2013 at 6:57 PM
    #136
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    He said Brute Force Fab on the last page. Good looking rig, now you just need some aggressive looking tires
  17. Nov 6, 2013 at 10:43 PM
    #137
    Spencer
    TIGGLEBITTIES
    Thanks dude!
    Ill have wrangler MT/R with Kevlar on here before too long.
    I actually use the truck so i discovered the "all terrain" rugged fails apparently meant
    "All terrains made of asphalt and rainbows"
    They're fuckin pricey though... :/
  18. Nov 6, 2013 at 10:50 PM
    #138
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Sub'd. Nice truck man!
  19. Nov 7, 2013 at 3:22 PM
    #139
    BajaRunner
    Drew
    Chino Hills, CA
    I love my MT/Rs!!!!! go to www.tirecrawler.com I got mine from there for cheaper than any place else.
  20. Nov 8, 2013 at 5:34 AM
    #140
    Spencer
    TIGGLEBITTIES
    I looked em up & they are a bit cheaper.. But how's the warranty? I mean I assume they'll hold up better than stock tires but I've fuckin destroyed them at 15,000 miles... I usually wind up using those ripped sidewall warranties from Americas tire.
    Considering going to the Goodyear down the road from me cause they offer some deal with alignment plus tires & I need em both. I also need nearly 2K to finish this project haha
