Zombie sniper rifle scopes
Discussion in 'Off-Topic Discussion' started by KodiakToyTRD, Oct 4, 2012.
  1. Oct 4, 2012 at 10:35 PM
    #41
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    absolutely as they are still "moving"
  2. Oct 4, 2012 at 10:35 PM
    #42
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    If they are not exposed to sunlight, they will be a darker color of "cold" than everything around them that was exposed to sunlight, at least at dusk and for a while there after.
  3. Oct 4, 2012 at 10:36 PM
    #43
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Most thermal-imaging devices scan at a rate of 30 times per second. They can sense temperatures ranging from -4 degrees Fahrenheit (-20 degrees Celsius) to 3,600 F (2,000 C), and can normally detect changes in temperature of about 0.4 F (0.2 C).
    And when something moves, even as small as a ball bouncing, the energy inside the ball causes heat. The movement causes the molecules inside the ball to speed up which will cause heat. So even though a zombie is technically dead the movement of molecules inside his/her/its body will cause heat. The ball is not a living thing either but it can still cause heat.
    Just my opinion with 3 minutes of google research
    [FONT=Helvetica,Arial][​IMG] [​IMG]
    [/FONT]
  4. Oct 4, 2012 at 10:38 PM
    #44
    KodiakToyTRD
    KodiakToyTRD [OP] Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Things did get interesting.
    :popcorn:
  5. Oct 4, 2012 at 10:42 PM
    #45
    KodiakToyTRD
    CO
    TW own'd me tonight! LOL!
  6. Oct 4, 2012 at 10:42 PM
    #46
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    so it's decided?
  7. Oct 4, 2012 at 10:43 PM
    #47
    PLC721
    Patrick
    Chandler, Az
    I WIN!!!!!
  8. Oct 4, 2012 at 10:45 PM
    #48
    95 taco
    95 taco Battle Born
  9. Oct 4, 2012 at 10:45 PM
    #49
    CayucosTacoma
    2004 Double Cab 4x4
    It's because you drive a white tacoma :p
    :cheers:
  10. Oct 4, 2012 at 10:46 PM
    #50
    PLC721
    Patrick
    Chandler, Az
    well.......
    ill accept that!!!
    :cheers:
  11. Oct 4, 2012 at 10:47 PM
    #51
    KodiakToyTRD
    CO
    That's waysis!!
  12. Oct 4, 2012 at 10:48 PM
    #52
    CayucosTacoma
    2004 Double Cab 4x4
    :sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin::sadviolin:
  13. Oct 4, 2012 at 10:52 PM
    #53
    CayucosTacoma
    2004 Double Cab 4x4
    side note:
    For this we added the Thermal-Eye X-50 Thermal Imaging Camera. As we all know, rising from the grave expels most of the heat from a zombie, leaving behind only faint warmth in the lower extremities. So if you view a stumbling figure with warm feet and a cold head, you know to take the shot. Just as the 5.11 Tactical Watch lets you calculate elevation compensation for long shots, the thermal imager helps you shoot with the confidence, knowing you're only going to re-kill the undead.
  14. Oct 4, 2012 at 10:54 PM
    #54
    95 taco
    95 taco Battle Born
    its only $3,000 :eek:
  15. Oct 4, 2012 at 10:57 PM
    #55
    KodiakToyTRD
    CO
    Warm feet. The rest is cold.
    I win mutha fucka!!
  16. Oct 4, 2012 at 11:01 PM
    #56
    CayucosTacoma
    2004 Double Cab 4x4
    I was reading that too. figured i'd restart the debate!
    so why only warm feet guys?
  17. Oct 4, 2012 at 11:02 PM
    #57
    KodiakToyTRD
    CO
    Movement across the ground. :notsure:
  18. Oct 4, 2012 at 11:13 PM
    #58
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    I think some friction would cause warmth in the body but not much.. Maybe just enough to tell if it's alive or dead through a thermal site. I bet they'd had to be walking/running for a while though before it would even appear. Same goes for the feet. Although they (assuming) drag their feet a lot would cause more friction. I still don't think it would be enough to determine a "kill" shot. Like said before, can't go wrong with a good 'ol iron site!
    btw, when is Top Shot gonna come out with a Zombie Sniper School series? We gotta get some zombies first. Who's up for the t-virus?? Not it
    http://www.bigbadtoystore.com/bbts/product.aspx?product=HCO10078&mode=retail
  19. Oct 4, 2012 at 11:19 PM
    #59
    KodiakToyTRD
    CO
    I'll try it if only my body reacts like Alice's.
    :cool:
  20. Oct 4, 2012 at 11:29 PM
    #60
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Has anyone mentioned decomposing flesh creating heat?
