ZP 2005 Mid-travel Prerunner Build
Discussion in '2nd Gen. Builds (2005-2015)' started by zeropresence, Feb 7, 2012.
  1. Feb 7, 2012 at 9:21 PM
    zeropresence
    zeropresence [OP] Well-Known Member
    SOLD the Tacoma. Landcruiser life now.
    Make/Model: 2005 Toyota Tacoma TRD Offroad Prerunner Doublecab
    Tires: 285/75/16 BFG A/T
    Front end: Fox Racing 2.5 internal bypass coilovers w/ remote reservoirs from a armored Hilux (was told only 2 sets were ever made). Just had this revalved for the truck by Fox. Fox Racing 2.0 bumps shorted to 2ins. Camburg UCA with 1.25'' uniballs.
    Rear end: Allpro Expo 3'' Spring. King Racing Smooth Body 2.5x10'' (Revalved by Doug at Mirage Racing)
    Other: Snugtop Xtra Vision shell, DMZ Motor Mount Gusset Kit, Total Chaos spindle gussets, 2 x 30'' BlackBox LED bars, custom bumper, Diehard Platinum Battery, custom C02 and gas can bed mounts.
    Fabricator: My brother Landon McQuestion
    Stock front end setup:
    Stock coilover out:
    Cutting off stock bumps:
    UCA and bump in:
    Fox C/O, UCA, bump in:
    New spring and rebuild/revalve by Fox:
    Bump:
    Frontend finished:
    Allpro Expos vs Stock:
    Take 2:
    Fox 2.0 vs King 2.5 Racing 10''
    Cutting off stock shock mounts:
    Cut off now grinding:
    Shock mount on axle removed:
    Doing work:
    Plated the frame with 1/8" where the shock hoops will tie in:
    Frame plating close up:
    Cycling and deciding where the shocks will end up:
    Shock hoop in place:
    Finished shock setup:
    It was a tight fit:
    Extended brake lines:
    The clips for the flairs just came in so those will be going back on soon:
  2. Feb 7, 2012 at 9:36 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Nice truck man!!! I like the suspension. Its a sleeper
  3. Feb 7, 2012 at 11:17 PM
    Anteupp
    Anteupp Mega Member
    Andrew
    South East Wisconsin
    Total Chaos Long Travel 4x4, Fox Coilovers, DMZ spring under, 16" king tripple bypasses, Garage built bedcage/bumper, full cage coming soon...
    loving the taco, reminds me of my truck when i didnt have long travel in front and out back. come out to a run sometime! im jelous of your tools to i want a plasma cutter!!!
  4. Feb 7, 2012 at 11:24 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Nice build dude! you've done what a lot of us are always talking about lol. How does she handle ?
  5. Feb 7, 2012 at 11:39 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    awesome truck, is there a reason you removed the rear fender flares? did the shock hoops mess with them or what?
  6. Feb 7, 2012 at 11:47 PM
    zeropresence
    Thank you. She handles amazing right now, plans for a two shock frontend is next. I'll post some gopro video of last weekend's testing.
  7. Feb 7, 2012 at 11:48 PM
    zeropresence
    Had to remove them to remove all the shock plastic wheel well lining.
  8. Feb 8, 2012 at 12:02 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    Looks like a great setup! Got any pics of how you mounted the rear shock to the axle? Also with the hoop positioned it looks like it causes the shock to lean inwards.. is that typical?
    Let me know how that goes cause I was thinking about the same thing!
  9. Feb 8, 2012 at 8:06 AM
    Bens MBL TACO
    Bens MBL TACO Well-Known Member
    San Diego, CA
    07 Prerunner Rumbler
    AFE Air Intake, Billy 5100's up front set at .85 with top plate and lean spacer, Eibach coils, Bilstein 5160's rear shocks, Toytec AAL, TRD Exhaust, Flowmaster Super 44 Muffler, JBA Headers, 5k 35 Watt HID, 3K 35 Watt HID fogs, Anytime fog mod Fierce 265, 70, r17.
    Bitchin build, man.
    Thanks for a solid deal on those leaf packs again. Yet to put them on though.
  10. Feb 8, 2012 at 8:14 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Sweet setup, I've been looking into doing something similar with my rear suspension.
    Did you cycle the rear suspension when you determined your shock size?
  11. Feb 8, 2012 at 8:43 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    Hey this is Landon the fabricator of this truck, The shock is there because that's where it fit. It was like threading a needle between the frame and the tire. One side benefit is with that angle on the shock it will fight body roll a small amount.
    Not before we got the shocks, I knew with that spring it would need no bigger than a 10" travel shock. At the slightly forward angle it uses all but 3/4" of the shock.
  12. Feb 8, 2012 at 8:46 AM
    theduck911
    Max
    Locked and Geared!
    So it bumps out before the shock bottoms out?!
    So now you just have to get a rear hydro bump & you're setup would be awesome:cool:
  13. Feb 8, 2012 at 8:48 AM
    Supermoto
    Landon
    Encinitas/San Diego
    Yes that always the way you want to build it. The rear really doesn't need an air bump with this setup and this valving.
  14. Feb 8, 2012 at 9:46 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Gotchya... Is that hoop a custom one or is it sold as a kit?
  15. Feb 8, 2012 at 9:49 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    why wouldnt you want a air bump in the rear? valving only determines how slow a shock compresses/decompresses. unless theres some type of internal bump like people do on bypasses..
  16. Feb 8, 2012 at 9:54 AM
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    Very nice setup!
  17. Feb 8, 2012 at 9:55 AM
    Supermoto
    Landon
    Encinitas/San Diego
    It is custom
    I just mean its got enough valving in the shock to slow the rear compression enough that it doesn't bottom out hard at all. Maybe once we get a dual shock on the front and his speed picks up even more it will need a bump in the rear.
  18. Feb 8, 2012 at 9:55 AM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Half-Ass Prerunner Daily Driver
    Lots of broken parts
    Looks good man. What's the stroke on those FOX bumps up front? 2.0's right?
  19. Feb 8, 2012 at 9:56 AM
    97yota4wd
    Eric
    Mesa, AZ
    ahh gotcha. but you think the rear can keep up with how it is now with a air bump in the front and a dual front shock setup? :confused:
  20. Feb 8, 2012 at 9:59 AM
    Bobber Bill
    Los Angeles, CA
    Dual front? What'd I miss?
