Zuk on 38's
Discussion in 'Other Builds' started by Tan Zuk, Mar 4, 2012.
  1. Mar 4, 2012 at 4:13 PM
    Tan Zuk
    Tan Zuk [OP] You will Love it or Hate it!!!
    Hi Everyone,
    I live in Pompano Beach, Florida and this is my 1987 Samurai JX Build.
    • (This is one of my Bucket List Builds so it is a bit over the top)
    Here is the before pic
    Finally got the front suspension together enough to roll the Rig outside for the first time in a year and a half.
  2. Mar 4, 2012 at 4:14 PM
    Tan Zuk
    My buddy stopped by today with his stocker. Thought that you would like to see what that looks like next to the big one while it was out.
    For those interested in the lift dimensions:
    Stocker is 15.5” to the bottom of the rocker panel.
    Big one is 36” to the bottom of the rocker panel.
    There is a 20.5” difference in lift from the stocker to the big one.
  3. Mar 4, 2012 at 4:15 PM
    Tan Zuk
    Here are the suspension and drive train stats:
    88" wheelbase, 84 inches tall, 82 inches wide.
    Front frame extended 8 inches rear 3 inches
    4 1/2 inch YJ lifted springs
    Toyo 38's and 16x12 wheels
    85 Toy front axle with all Trail Gear inners including Trunion Bearing Eliminator
    529 gears open and High Pinion, 6 Shooter Knuckles with High Steer and 1 inch
    Space.r
    Rear axle is Trail Gear offset Sami Toy housing, 529 gears open and 1.5 spacers,
    Rear Disk Brake, Outboard Shocks.
    FJ80 steering box, Panhard bar and Rancho 9000 36" length.
    ZOR Snatch
    6.5 Transfer Case Gears
    The trans will also be gone through
    No driveshafts yet
  4. Mar 4, 2012 at 4:16 PM
    k20me
    k20me Well-Known Member
    Josh
    BroCal
    2016 4Runner
    Holy crap. Samurai's are the best!
  5. Mar 4, 2012 at 4:17 PM
    Tan Zuk
    Here is the motor. I have a small machine shop and machined a lot of the parts for the
    motor, suspension and steering mods.
    Here is the Before Pic
    After
  6. Mar 4, 2012 at 4:18 PM
    Tan Zuk
    Motor: 1.3 .020 over and deck shaved,
    I used dish pistons because of the decking,
    1.6 Reynolds ported polished and larger valves and shaved head.
    Adjustable timing gear was used because of the shaving of the head and block.
    I also had to make a custom timing adjuster wheel. It was too small in diameter and was unable to get the timing belt tight.
    Internals are balanced and flywheel,
    I'm going to use a Centerforce clutch this time.
    The intake was made from a solid block of 6061. It started at 35 pounds when the machining was done it was 8 pounds. I also decided to machine the water ports in the manifold.
    The carbs are 32mm Katana GSX-F.
    The external accessories on the motor I have also machined up.
    The distributor has been switched to mechanical.
  7. Mar 4, 2012 at 4:20 PM
    mondexyota
    mondexyota Well-Known Member
    Beau
    Titusville, FL
    2010 Barcelona Red DC SR5 4x4
    3" Toytec spacer lift, 285x70x17 Nitto Terra Grapplers on 17x9 XD Misfits
    Thats badass man!
  8. Mar 4, 2012 at 4:25 PM
    Tan Zuk
    6061 Aluminum Intake
    This was manually machined on a mill and took 260 hours just for the intake by itself. There was No Cad used to design it.
    ( This ways a solid block and weighed 35 pounds )
    When it was finished it was 8 pounds
  9. Mar 4, 2012 at 4:28 PM
    Tan Zuk
  10. Mar 4, 2012 at 4:32 PM
    Tan Zuk
    I also do fiberglass work ( Not By Choice)
    After installing the front Shrock Work bumper it looked like it was missing something. I decided to make a lower valance to conceal the 8” frame extension. I’m also getting a bit older and needed an additional step. I decided to make some running boards for the 2nd step. The back tire is being used as the 1st.
    The bumpers, fiberglass pieces and the body moldings were Rhino Lined to match the paint for durability.
    Front Lower Valance
    Side View Running Board
    Rear Side View Running Boards
  11. Mar 4, 2012 at 4:34 PM
    Tan Zuk
    Front Frame Extension is 8” and is level to the ground instead of following the frame. I also smooth out all my welds. This tends to add a lot more time to a build just my preference.
  12. Mar 4, 2012 at 4:37 PM
    Tan Zuk
    The Rig is rather high as you can see. This presented some unique problems trying to get the steering geometry setup without a steep angle. I will go through the mods and the parts that needed to be made to correct the problems in the next couple of posts.
    I also have an unusual steering set up with the FJ80 box, Lifted YJ springs and the addition of the Panhard bar just to make it more complicated. There is not a great deal of room to work with when you have to add a shock tower in the mix on the DS.
    Steering Front View. I still need to do some welding and fitting yet.
    The steering geometry is set at 5 degrees.
    Panhard Bar was bent at one end to 5 degrees to shorten the PS mounting bracket. I have a 3/4 Heim in the DS and will be using a suspension bushing on the PS. This will help the bar from flopping with the bend in it.
    Extended High Steer Arm was made from 8620 the same material the 6 shooter arm is made out of. These pieces will be tig welded together. The block started off at 30 pounds. After several hours of whittling I got it down to a more manageable 9 pounds.
  13. Mar 4, 2012 at 4:45 PM
    Tan Zuk
    Good Question
    It will be a pavement pounder, not to say that it isn’t built to handle what I decide to put in front of it.
    Had some health issues a few years back unfortunately I'm no longer able to wheel.
    Fortunately I’m able to still put in a few hours a day to complete a few builds and not sit in front of the TV eating Twinkies.;)
  14. Mar 4, 2012 at 4:49 PM
    Tan Zuk
    To help eliminate one problem:
    I started off by dropping the FJ80 box 1” to help decrees the drag link angle. The Frame was notched 1” and the holes filled in the frame before adding the frame plates. This was done to the inside, outside, top, bottom and the notch.
    1" Frame Drop Mod
    1/4 Outside Drop Plate
    Outside plate mounted with DOM bushings and rosset welding holes.
    Inside plate mounted
  15. Mar 4, 2012 at 4:52 PM
    Tan Zuk
    Now that I have the FJ80 box mod done. The next issue was mounts for shocks, panhard and bump stops. This took me quite a while to come up with something to incorporate all of this into 2 mounts.
    Note:
    These mounts were made to sandwich over the TG Shock and Ball support Brackets on both sides.
    Driver Side (Side View) Shock Mount and Bumpstop Pad
    Passenger Side (Rear View) Shock Mount ,Panhard Bracket and Bumpstop Pad that still needs to be added to the top.
    Passenger Side (Side View) Shock Mount ,Panhard Bracket and Bumpstop Pad
    Passenger Side (Front View) Shock Mount ,Panhard Bracket and Bumpstop Pad
    Drivers Side Frame Panhard Bracket and Lower Bumpstop Mount
    NOTE:
    Thought I would add that I switched over to the 6 shooters after the pics were taken.
  16. Mar 4, 2012 at 4:52 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Wow, that's in the running for the nicest Zuke in the world, ever. Good work.
  17. Mar 4, 2012 at 4:54 PM
    Tan Zuk
    This is the side that got to be very congested.
    Components:
    Fj80 Box
    Panhard Bar Bracket
    Ford Shock Tower
    Mods:
    1" Frame Notch
    Frame Plating
    Bump Out for the Steering U-Joint and Box Plating
    Drivers Side Bumpstop Mounting and Pad Locations. There will be additional bracing added to the Panhard Bar Mount for the stress of the Bumpstop Action.
    FJ80 Box 1/2 Extension Block. I added this to lengthen the Drag Link. This will also cut down on the angle and decrease the rotational effects of the Panhard Bar.
    Note:
    The Drag Link length is 37 1/2 inches. Anything over 36 inches is ideal for a Panhard Bar applications.
  18. Mar 4, 2012 at 4:59 PM
    Tan Zuk
    Here is a bit about me. Been a machinist for 32 years. Consisting of Tool Maker, Tool and Die Maker, CNC Machinist and Job Shop Machinist. I also have a small shop that I make my 1 off’s for my Bucket List Builds.
    Throughout that time I have built several custom motorcycles, Hotrods and a few Rigs.
  19. Mar 4, 2012 at 5:01 PM
    Tan Zuk
    There is a lot of info there to look at. I will post the rest of the build in spurts. This will give you enough time to take a good look and ask questions.
  20. Mar 4, 2012 at 5:07 PM
    Tan Zuk
    I will take the time to thank everyone being I was posting as you were replying.
    k20me
    mondexyota
    nvdeserted
    Gelo760
    Thanks for taking the time to stop in. I appreciate the supportive comments. Greatly appreciated.
