Zuk on 38's
Discussion in 'Other Builds' started by Tan Zuk, Mar 4, 2012.
  1. Mar 4, 2012 at 5:08 PM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    Amazing! Fapfapfapfap!
  2. Mar 4, 2012 at 5:09 PM
    Tan Zuk
    Tan Zuk [OP] You will Love it or Hate it!!!
    Anybody watching the motor video?
    So, nobody is watching the video and there are no questions?
  3. Mar 4, 2012 at 6:16 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    yer 1.3 is purdy... and sounds like it runs real nice.
    I admire your machinist skillz
    and wish I had those tools to build my junk.
    This build is really neat to look at...
    But I was wondering...
    Your state's LEA has no concern about tires sticking out that far
    from the wheel wells... on 'da street ?
    Isn't that gonna be somewhat of a harsh ride and entry
    if you have something disabling ?
    I'm interested in seeing more...
    can you hire someone to take it out and wheel it ?
    I just want to see if it works... as bling as it looks :D
  4. Mar 4, 2012 at 7:48 PM
    Tan Zuk
    Just wanted to start by saying thanks for some good questions.
    I also appreciate that you like my work skills. Been making parts for years for people
    and now I can finally see what I can do for myself. There is a big investment that needs to be made to just buy the machines. You also have to tool up or you won’t be able to make anything.
    Where I live it isn’t really too bad. I shouldn’t have any issues because there are a few trucks that have a similar tire setup.
    The ride should be much better then what I have on the DD that I have. The springs that I’m using are the YJ’s and I also extended the wheelbase to help.
    Really don’t want to discuss my disability because we are on the internet. Hope you understand. I can say this though, as far as getting in and out. I can do this but I wouldn’t want to have to do it more then a few times a day.
    It won’t be ready for awhile yet. I wouldn’t have to hire anyone to take it out. I have people standing in line already.
    I live in Florida and it is flat here and mostly mud holes, lakes and plenty of sand. The wheeling spots are getting harder and harder to find. You usually have to go out to someone’s private land.
    I hope that I did an adequate job on answering your questions.
  5. Mar 5, 2012 at 10:33 AM
    Tan Zuk
    Toy-Zuk Hybrid Steering Link
    Here are the parts I used to attach the Zuk steering column to the FJ80 box.
    Toyota 1980 4x4 Steering Slip Yoke Link
    Zuk stock steering link
    NOTE:
    These pieces were shortened, machined the ends for a press fit then tig welded.
    The reason I used the Toy slip yoke was to let the shaft be able to move under flex. I have seen other parts used I thought this would be a better solution. I have had a couple Toy 4x4 and the slip link worked well.
  6. Mar 5, 2012 at 10:35 AM
    Tan Zuk
    Here is a comparison pic:
    Without Front Bumper and Valance
    With Front Bumper and Valance
  7. Mar 5, 2012 at 10:38 AM
    Tan Zuk
    I have looked at a lot of build threads the past bunch of years. I haven’t seen anyone use this trick or they never showed it. This is what I do before I even think about spending any money or proceeding with any mods.
    I hope this Helps out.
    My build was starting with the 38’s. I needed to see if these were going to fit and what is going to need to be done to accomplish the entire mod.
    The trick is making a 38” wood tire out of plywood. The next thing is to get it in the air enough to fit the wood tire. Once this is done you start making a plan of attack.
    The plan was to move the front axle 4-5 inches forward and the back axle 3 inch to the rear. There was also going to be a stretched front frame that worked out to be 8 inches. I also wanted to cover the extension as much as possible with the bumper.
    This was just the minimum plan of attack and was very subject to change.
    Here are a couple of pics to give you an idea what I’m talking about.
    1st pic is of the 38" wood tire. I got a lot of yea rite when some of my friends stopped by. They have all since changed their minds.
    2nd pic shows how to lay out the stretch. I used masking tape on the flair and marked the position with a marker. I used string taped on the mared position with a nut on the end to get my axle positions. I also found out that my jack stands were not nearly tall enough. If I remember rite I needed to go up about 7 more inches
    This was a cheap extension out of wood for the stands to fix my problem. It worked out well.
  8. Mar 5, 2012 at 10:44 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    subd! amazing build!
  9. Mar 5, 2012 at 10:44 AM
    Tan Zuk
    Got hooked on the Zuks again after reading about the bike carbs on the Zuk motor. Read all about that mod for about a year. Didn't really like what they had come up with as an intake. New I wanted to do one out of a solid block of AL.
    There was a problem, I had no Zuk. Now I have 2.
    This is going to be a pavement pounder and really don't want to take any chances with safety so everything is triple over engineered.
    Thanks for the question
  10. Mar 5, 2012 at 10:46 AM
    Tan Zuk
    Its the little things that help the most. I find using wood and cardboard for mockup is very cheap and less time consuming to use. If it doesn't work out no big deal.
    I even machine up my proto type pieces from wood first. Just to make sure they work out.
    Wood Extended High Steer Arm
    Finished Piece
  11. Mar 5, 2012 at 10:48 AM
    Tan Zuk
    Here is another thing I have not seen mentioned either. It is very important to get your suspension setup correctly.
    Most of us have the Rig stripped down when we are setting it up for the new mods.
    This is a Big Problem.
    When you stick everything back in it the suspension you worked so hard to setup is not where you thought it was going to be setting. It is important to add weight back into the vehicle.
    Try to add the weight where the parts are to be located.
    This was my list:
    1. Add sand bags to the inside to compensate for the parts that were missing. I got these cheap at Home Depot.
    2. Add weights to the front extension to compensate for a front bumper. This is very important if you are going with a winch.
    3. Add weights to the engine compartment for the missing engine.
    Here is a pic of what it looks like.
  12. Mar 5, 2012 at 10:53 AM
    Tan Zuk
    Here is another example of not spending money on parts until I have a good idea that it is going to work.
    Using materials I had laying around the shop consisting of:
    Conduit Pipe
    Duct Tape (used to wrap the threads on the Heims for a tight fit)
    Masking Tape
    Cardboard
    Couple of 2x4 Wood Pieces
    Couple old Heims from an old project.
    2 old 5/8 Bolts
    This was used to help me layout the Panhard Bar
    Here is a pic Marked in detail to show you what was used.
    After looking at the above example I thought I should show the parts in their proper position. This will give you a better idea what I was using them for.
  13. Mar 5, 2012 at 10:55 AM
    Tan Zuk
    I will let you take a look at the info before posting anymore.
    Please feel free to ask questions if needed.
  14. Mar 5, 2012 at 11:04 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    People always look at me funny when I make parts out of cardboard. At least im not alone :p
  15. Mar 5, 2012 at 11:11 AM
    #35
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    ill go ahead and ask what everyone is thinking:
    about how much money did you put into this?
  16. Mar 5, 2012 at 11:29 AM
    #36
    Tan Zuk
    I have had a couple of comments about my cardboard muck up pieces on one of my other build threads. This is usually from the Cad guys.
    This is always how I've done it. It is cheap and reliable and I always seem to get a good part.
    I started calling it old school 3D Cad puts more meaning behind it.
    You can see that I don't limit myself to just cardboard.
  17. Mar 5, 2012 at 11:32 AM
    #37
    Tan Zuk
    Not sure everyone is thinking this. I have 5 build threads going and you are the 1st to ask.
    I would say that I'm closing in on the budget I set before starting.
  18. Mar 6, 2012 at 11:15 AM
    #38
    Tan Zuk
    I have a DD TT and it gets BAD road noise and when it rains it sounds like a tin shed. I knew that I was going to address this problem in the new Rig by installing Dynamat.
    Here are a few pics of the new interior and the Dynamat process. I found by working in smaller pieces and get it pressed down tightly was the better way (JUST MY OPINION).
    The firewall front cab and tunnel was a challenge. I also did the inside of the doors and inner panels.
    Painted Interior
    Roof DynaMat
    Driver Side Rear Inner Panel DynaMat
    Driver Side Panel & Seat
    Headliner
    PS Front Panel
    Rear Panel
    Back Mounting Bracket for Rear Panel (Front View)
    Same Back Mounting Bracket for Rear Panel (Side View)
  19. Mar 6, 2012 at 11:20 AM
    #39
    Tan Zuk
    :wave:If there is any interest with the vehicle peeking in on the PS Front Panel pic let me know.:wave:
    This is another build and can post a couple of pics and stats
  20. Mar 6, 2012 at 11:22 AM
    #40
    Tan Zuk
    I had an 8” drop for my steering. This ended up being a 13 degree drag link angle. The Rig will see mostly street use as you know and that much angle would be way too much.
    Here was the solution I came up with.
    1” drop FJ80 Steering Box
    Box DS Frame Rail 1/4x5x24 Plate top, bottom, both sides
    TG Drop Pitman Arm
    4” Custom Extended Arm
    TG 6 Shooters
    Anti-Rotation Deflection Bracket
    With these mods I was able to achieve a 5 degree Drag Link and Panhard bar angle. This was now a safe, clean and expectable mod. IMHO
    This is a closer view of the Extension and the Anti-Rotation Deflection Bracket and in different views to give a better perspective. I believe that I have got them clearanced so there will not be any interference. I will have to start cycling the suspension just to double check.
    The 6 Shooter arm added to the Extension will be Tig welded by a Pro down the street. The welds will be smoothed out on the bottom for the
    Anti-Rotation Deflection Bracket mouning surface. This gets bolted in place with a 9/16 Grade 8 bolt on the arm and (2) ½ Grade 8 socket head bolts on the ears. There will be 2 additional 90 degree gussets welded to the bottom side for piece of mind.
    I got this done on Friday thought I would share some pics.
    Marked View
    Front View
    Side View
