Thread Status:
Not open for further replies.
  1. Nov 3, 2018 at 2:18 PM
    backcountryj
    backcountryj [OP] Pending Approval
    Jonathan
    GA
    I’ve got a set of Prinsu style side plates for a topper rack and mounting hardware I’m considering selling.
    First off this is only side plates and hardware, and is NOT Prinsu. Extrusion bars and mounts will still need to be purchased, fabricated, for a complete rack. These were purchased from a member that has made a few sets of rack kits, that are very similar to Prinsu, but are indeed different.
    The side plates are made from 1/4” aluminum stock and are about 53” long and meant for a short bed. They are laser cut and powder coated (admittedly not the best powder coat I’ve seen but functional). The hardware I have and will include is as follows:
    4x per crossbar Black Stainless Steel button head cap screw, washer, lock washer to attach the crossbars to the side plates.
    2x per mounting feet anchor plate, stainless steel bolt, fender washer, lock washer to attach feet to rails
    2x per mounting feet bolt, fender washer, lock washer to attach feet to crossbars
    I have enough hardware for up to 8 crossbars and 6 mounting feet.
    There is nothing wrong with the setup, and is still partially wrapped as delivered to me in June. I bought this kit before I got my topper with the intent to put it to use. I ended buying a used topper that already had a Yakima roof rack and that setup meets my current needs.
    I’m in no rush to sell so the price is pretty firm. $185 + actual shipping. PayPal only, FF or you cover PayPal fees.
    AAC2519F-AA0E-4566-9815-19F6D859984A.jpg F40541B7-3842-4368-8640-9D31A6C8BABD.jpg 32782D48-EF02-4CC9-92C6-A40E68147F59.jpg FEE4A31E-7DC4-4A87-BC90-626C3B44CDD5.jpg A8FD4E7B-D439-452F-B55E-FC6CCA98F03D.jpg
  2. Nov 3, 2018 at 3:26 PM
    Kikeyota17
    Kikeyota17 Well-Known Member
    Enrique
    Trd pro
    but does it bolt like the prinsu in roof or no ??
  3. Nov 3, 2018 at 3:31 PM
    backcountryj
    Jonathan
    GA
    Yes. As stated previously, I’m only selling sideplates and hardware. Crossbars and mounting feet must be added for a complete roof rack.
  4. Nov 3, 2018 at 3:36 PM
    Kikeyota17
    Enrique
    Trd pro
    I know but if its bolt same like the prinsu In top of the roof o will take it
  5. Nov 3, 2018 at 3:59 PM
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    No. There are no mounting feet included. You will have to buy or have fabricated.
  6. Nov 3, 2018 at 4:09 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    First line of his post says this is for a topper(over the bed on a shell) not the cab so it will not bolt to the cab.
  7. Nov 3, 2018 at 4:41 PM
    backcountryj
    Jonathan
    GA
    It can be mounted the same as a Prinsu, in the correct application. On a topper/camper/shell, etc.
    Yes sir!
    Reading comprehension is strong with you young padawon :thumbsup:
    SuperBad[QUOTED] likes this.
  8. Nov 5, 2018 at 7:21 AM
    backcountryj
    Jonathan
    GA
    Monday bump
  9. Nov 5, 2018 at 2:37 PM
    Easy_rider
    Easy_rider Well-Known Member
    VA Beach
    15 TRD PRO
    2" AAL Tint Yellow fogs Ultra gauge Egr rain guards ARE shell Bed mat HID low/high 32'' stealth LED light bar LED bed lights 6'' Led side lights coverking seat covers head rest screen/DVD player CB radio Homemade CB antenna bed bracket Diff breather mod Custom camper shell rack On board air Master Air Relocated hitch plug Homemade Shell rack Rear seat USB plug Jerry can pressurized with hose attached Blue sea fuse block under hood with 80amp breaker All dash light WHITE LED converted
    still aval?
  10. Nov 5, 2018 at 4:01 PM
    backcountryj
    Jonathan
    GA
    The set is still available at the moment.
    PM replied as well
Thread Status:
