“Check Charging System” in Accessory mode, normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CementKevin, May 19, 2018.
  1. May 19, 2018 at 10:49 AM
    CementKevin
    CementKevin [OP] Active Member
    Kevin
    2018 Cement Tacoma Offroad 4x4
    As I tried access remote on before I start the truck, I get a message that says to check the charging system. Is this normal during accessory mode? I just bought the truck for days ago and I’m not sure what to expect from it.
  2. May 19, 2018 at 10:59 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    It is normal...just an alert to let you know your pulling power from the battery.
  3. May 19, 2018 at 1:30 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Normal
    /end
  4. May 19, 2018 at 1:32 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Normal, if it stays on after you start it then you have an issue.
    2016Tacoman likes this.
  5. May 19, 2018 at 11:02 PM
    CementKevin
    Kevin
    Thanks guys!
  6. May 19, 2018 at 11:08 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Welcome to TW, don't spend too much while you're here...
    Anchovy and CementKevin[OP] like this.
  7. May 21, 2018 at 3:47 PM
    jasontacoma
    jasontacoma New Member
    CT
    2017 Quicksand TRD OR DCLB w/ PT
    Also, that's ignition on mode not ACC. You won't get that in ACC. Without the brake pushed one press to ACC another to ON. Also If you press it while in Neutral it will shut off the engine while leaving it in either ON or ACC ( I forget which one) Great for when your on the phone with bluetooth as the head unit doesn't lose power.
