Madjik Man's laugh-at/with-him "build"
Discussion in '1st Gen. Builds (1995-2004)' started by Madjik_Man, Jun 17, 2010.
  1. Jun 4, 2012 at 6:32 PM
    #81
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Can you actually feel when the clutch engages now? I cant with mine
  2. Jun 4, 2012 at 6:34 PM
    #82
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Don't know if mine was as bad as yours but it just feels more "solid" now.
    That's the only way I can describe it. Plus it returns to the utmost upper position every time, with only a tiny bit of play in the pedal.
  3. Jun 4, 2012 at 6:37 PM
    #83
    TACOMABOSS
    96 SR5 4x4
    Mine has always returned to the utmost upper position. And its always pop'ed/squeaked. Its really stiff I cant feel when it engages
  4. Jun 4, 2012 at 6:49 PM
    #84
    Madjik_Man
    WHOA Bro!
    j/k
    If I wanted to use cruise control, 85% of the time I would have to stick my foot behind the pedal and give a little help engaging the switch.
    In the clutch pedal squeak mod thread, I think the consensus was the #70 spring from autozone is a bit softer than the original OEM torsion spring.
    I'll see if I can dig up that post for you.
    Post #3 http://www.tacomaworld.com/forum/1st-gen-tacomas/159429-clutch-squeak-linear-spring-swap-tw-how.html
    Maybe that helps? :notsure:
  5. Jun 4, 2012 at 6:54 PM
    #85
    TACOMABOSS
    96 SR5 4x4
    somehow i knew i would get a comment like that hahaha
    I think im just going to say screw it and do the mod. if it doesnt work it doesnt work lol
  6. Jun 4, 2012 at 7:16 PM
    #86
    Madjik_Man
    There's no way it doesn't work.
    Let me know if it helps your issue.
  7. Jun 5, 2012 at 6:04 PM
    #87
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    What up bruh! How's the paint on the center console/cupholders holding up?
  8. Jun 5, 2012 at 7:09 PM
    #88
    Madjik_Man
    Beautifully.
    Check out post #76 for a more detailed answer.
  9. Jun 5, 2012 at 7:11 PM
    #89
    RMAN808
    Reid
    Pearl City, Hawaii
  10. Jun 5, 2012 at 7:21 PM
    #90
    Madjik_Man
    You quoting those two pics reminds me that the shifter boots look much nicer black
  11. Jun 9, 2012 at 6:17 PM
    #91
    Madjik_Man
    So after 6 years I finally got around to figuring out why my tailgate handle protrudes from the trim by at least 1/2"
    When I pulled off the access panel I was surprised to see one of those metal braces (?) just floating around my tailgate. The welds were busted
    Driver's side (busted):
    Passenger side (fine):
    Nothing a wooden shim can't fix:
    So now onto the reason why I opened the panel. This is what my tailgate handle has looked like for about 6 years:
    Upon inspection I realize that the panel itself was pushing on the back side of the handle mechanism thus making it protrude. Notice how the section of panel behind the handle is concave and not convex:
    Yup, it's the panel pushing the handle mechanism out:
    So I got out my body repair kit and went to work:
    Put every thing back together and voila! Flush:
    SkeetFighter likes this.
  12. Jun 9, 2012 at 6:20 PM
    #92
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    Looks good man. Like it
  13. Jun 9, 2012 at 6:21 PM
    #93
    RMAN808
    Reid
    Pearl City, Hawaii
    :eek: That's crazy...
    Because mine is exactly like that! Except it sticks out slightly less than yours does. I'm still waiting for my Pop&Lock to arrive (almost a month and a half already on backorder). Then I'll take the time to look at what's up under there.
    Was it tough to unscrew that panel? I have tried in the past and it was pretty tough and didn't budge.
  14. Jun 9, 2012 at 6:49 PM
    #94
    Madjik_Man
    I just got a #3 phillips head on it and just unscrewed them.
    Granted my biceps are the envy of most men and my forearms are like Popeye's from my porn addiction...
    ...but I think you should be alright. Hit it with a drill on low rpms if need be
  15. Jun 9, 2012 at 6:55 PM
    #95
    RMAN808
    Reid
    Pearl City, Hawaii
    Haha easy there muscle man! [​IMG]
    Yea I guess I'll find out when the time comes.
  16. Jun 12, 2012 at 12:59 PM
    #96
    Madjik_Man
    Painted my rear bumper semi gloss
    (no that's not overspray... that's my mad photo editing skills)
  17. Jun 12, 2012 at 2:47 PM
    #97
    Iceman2448
    Ga
    Looks good man
  18. Jun 12, 2012 at 2:52 PM
    #98
    TACOMABOSS
    96 SR5 4x4
    How much sanding did you do for the rear bumper?
  19. Jun 12, 2012 at 3:43 PM
    #99
    Madjik_Man
    45acp gave me his bumper and it was already painted flat black. (the first pic is how it came to me)
    It was scratched here and there, plus it could use a freshening up. Not to mention I wanted it semi-gloss, not flat.
    So I just sprayed 4 or 5 light coats over everything. By no means will it win any car show paint jobs, but it looks really good in person.
  20. Jun 16, 2012 at 1:14 PM
    #100
    RtacomaN
    RtacomaN Well-Known Member
    Taylor
    Colorado
    Looks good man. I am doing the plasti dip "see how I like everything blacked out"
    Then may move to this
