Tacoma COMPLETE front drivetain, w/ ARB Locker preinstalled
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by randombob, May 20, 2012.
  1. May 20, 2012 at 8:23 PM
    randombob
    randombob [OP] Well-Known Member
    Eureka, CA
    2013 TRD OR
    stuffs
    SOLD!
    Due to recent modifications (yeah yeah yeah SAS we know please shut up now dude) I am selling my complete front drivetrain. I've listed it once before in a thread with everything, Breaking it all up now to keep the threads clean & clear and organized. had a couple of last-minute back-outs, Hopefully we can find a new home for this stuff!
    Asking $1100 for it all.
    OK here's the list:
    • Stock Gears, 4.10
    • ARB air locker pre-installed. MAYBE 25 miles driven engaged. That's being generous. probably like 10 realistically.
    • NEW-in-box, never opened ARB compressor & lines
    • Half-shafts w/ working CVs, all boots GOOD, no tears or leaks
    • Front spindles
    • Both upper and lower control arms
    • All hardware (c-clips, diff bolts,
    I stand behind everything listed, with one exception: Passenger wheel bearing is starting to go south, could stand replacement. However it's price VERY FAIRLY. Locker & compressor alone will run about as much as this whole setup, so that means…
    --If you're looking to 4x4 your prerunner, THIS IS A FANTASTIC DEAL.
    --If you want to add in a front ARB locker to your setup, this is a fast & cheap way to do it. Instead of buying the ARB & compressor elsewhere (almost as much as I'm asking), then spending a whole weekend installing or paying someone $1000+ to install it, you can simply unbolt and swap out your non-locked diff for this one. then run the lines & such. THEN you have spares of EVERYTHING on your front for the trail, ESPECIALLY the all-important half-shafts, which apparently run $1000-1400 EACH but are definitely the weak link in the IFS setup. Never broke any but I've heard stories… :eek:
    Let me know. I'm in eureka, CA. shipping will be $$$$ this is a large heavy pile o' metal. Best to make a drive if you can, otherwise it will NOT be cost effective I GUARANTEE.
    If you're on the fence, I think this will swing you: Adding a locker to your Tacoma will make magical fairies carry your truck over all obstacles you come across, and block mud from actually ever contacting your vehicle*
    *these claims not tested by the FDA
    If you're interested hit me up!
  2. May 20, 2012 at 8:27 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    :popcorn:
    Great deal!!!
  3. May 20, 2012 at 8:29 PM
    Sunner
    Sunner Well-Known Member
    This is a ridicolous deal. Dont need to wish you good luck here.
  4. May 21, 2012 at 1:28 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    holy...shit..if i hadnt just rolled my truck id totally buy this
  5. May 21, 2012 at 9:29 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    whats the gearing for the front diff?
  6. May 21, 2012 at 9:38 AM
    randombob
    Eureka, CA
    2013 TRD OR
    stuffs
    Pssst, check post ;)
  7. May 21, 2012 at 1:43 PM
    blacksheff405
    blacksheff405 no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    YOU DID WHAT?!?:eek:
  8. May 21, 2012 at 4:06 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    wow im retarded. . .
  9. May 21, 2012 at 6:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    rolled it ha :eek:
    sucks..
    someone buy this!!
  10. May 21, 2012 at 7:39 PM
    Sunner
    Yikes, at least your ok.
  11. May 21, 2012 at 9:06 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Not sure if it helps the sale but if someone too far away wants to buy it, you can use my UPS account. It'll end up being 100.00 flat for shipping.
  12. May 21, 2012 at 9:08 PM
    Sunner
    Well hello my new best friend. :D
  13. May 21, 2012 at 9:40 PM
    randombob
    Eureka, CA
    2013 TRD OR
    stuffs
    Bookmark this thread, but.... May have a local buyer. Supposedly to be here Wednesday to look it over and purchase. But I've heard that all before! So if you're interested, put your chips in. I'll go down TE line until someone doesn't back out or try to low-ball me last-minute or anything :)
  14. May 23, 2012 at 8:08 PM
    randombob
    Eureka, CA
    2013 TRD OR
    stuffs
    OK, Sold! Someone got a fantastic deal ;)
    Was worried actually when he rolled up to my house in a 2nd gen. I had to quick do a double-take to make sure I had actually specified the year or something that would indicate what it came off of and would work on :/. Luckily he had like 4 toyotas and it was not for the one he showed up in!
  15. May 23, 2012 at 9:56 PM
    acordova1050
    acordova1050 Well-Known Member
    Antonio
    Granada Hills
    '17 Tacoma TRD
    Walker Evans Wheels Baja Desingn Sport Fogs
    still got those spindles?
    Ill take them
    pm me
  16. May 23, 2012 at 9:57 PM
    acordova1050
    Antonio
    Granada Hills
    '17 Tacoma TRD
    ooops, sold. nevermind
