Spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stubbs95tacoma, Jan 7, 2012.
  1. Jan 7, 2012 at 8:31 PM
    Stubbs95tacoma
    Stubbs95tacoma [OP] Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    I searched but didn't find a write up on how to change the spark plugs on a 1st gen 3.4l v6
    help anyone?
  2. Jan 7, 2012 at 8:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    unbolt the coils, pop them off the plugs, then remove with a spark plug socket.
    passenger side requires removal of the intake tube. Its really easy.
    make sure you put JUST A DAB of antisieze on the threads of the new plugs before install.
    Also get the plugs at the dealer, they should be denso brand.
  3. Jan 7, 2012 at 8:37 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Any reason they have to be that brand?
  4. Jan 7, 2012 at 8:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    the dual electrode ones from the dealer have been proven to work the best. They just happen to be that brand I think.
  5. Jan 7, 2012 at 8:39 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
  6. Jan 7, 2012 at 8:40 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  7. Jan 7, 2012 at 8:48 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Thanks guys I'll do this tomorrow and let you know how it goes.
  8. Jan 7, 2012 at 8:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Just remember, very important.
    Only put a dab of anti seize on the threads of the new plugs. too much will cause problems with removal down the line.
  9. Jan 9, 2012 at 9:14 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    For OEM non-iridium plugs, a lot of folks around here like Denso over NGK. I just did the plugs on my 2.7L with Denso's from the dealer, replacing the NGKs that only had 20K miles on them and looked in fine condition. Definitely an improvement.
    Also for removal of the plugs, if you don't have a plug socket, just loosen all the way with a 14/16mm whatever it is, then you can pull it out with the boot of the wire. Plug socket is a very worthwhile investment, however, since you should NOT just drop the new ones in, likely messing up the threads or gap.
  10. Jan 9, 2012 at 3:22 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Question...are the NGK platinum plugs ok? I know the owners of Bond Auto Parts (aka the Bond family) in NE and they get me parts at cost, and those were the plugs that he gave me so I put them in. I assume that's fine too?
  11. Jan 9, 2012 at 9:24 PM
    ludeaddict
    ludeaddict Member
    NorCal
    1996 Tacoma 4X4
    N/A
  12. Jan 9, 2012 at 10:36 PM
    tacopyro
    tacopyro Forever learning...
    SoCal
    01 Taco Pre SR5 V6 - 4WD
    Roll n Lock Cover and Stainless Step sides. New Mods. AFE Air Filter, PS Mag-Filter, Bilstein HD rear and 5100s Front. Michelins LTX MS2. Taurus E-Fan with FK50. Tundra Brake Upgrade. External Tranny Cooler. HO-Alt CS144 Mod, OMD Leaf Springs. Bull Bar. 4WD VF3AM Transfer Case, ADD/Manual Hubs. Supercharger with URD 7th injector. 4wd conversion complete Future Mods. rear sway bar, box the rear frame. I Love my Taco!
  13. Jan 11, 2012 at 8:04 PM
    Jereme109
    Jereme109 New Member
    Phoenix, AZ
    02 PreRunner SR5
    I'm about to do the same job on my truck. Do I need to change the wireset at the same time? I assume I probably should, but figured it was worth asking.
  14. Jan 11, 2012 at 8:19 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    got my plugs from dealership for $3.83 ea. call around price vary from deaerlships but its worth a try.
  15. Jan 11, 2012 at 9:22 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    I recently got mine on RockAuto....Very fair pricing.
  16. Jan 12, 2012 at 6:21 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I got mine at the dealer lower price than on line for OEM plugs, and a big difference in price from dealer to dealer.
  17. Jan 12, 2012 at 6:35 AM
    GMRtaco
    GMRtaco Well-Known Member
    IE
    07 Pre Runner DCSB
    URD TCAI, TRD Seat covers, WeatherTech Liners, BHLM, DTRLM, 6000K HID Heads, 3000K HID Fogs, Black Valence, Custom license plate mount, LED interior lighting, Pioneer 4200DVD, 2 10" infinite subs behind rear seats, spidertrax spacers, 265/65/17 Dynapro ATM with powdercoated stock wheels
    Whoa! Had no idea they made fake ones!
    Bought some from ebay a week ago and they are still sitting in my garage. Have to check them of out when I get home later!
  18. Jan 12, 2012 at 11:52 AM
    misterdmac
    Doostin
    '97 2.7L DLX
    Generally you change the wires at the same time, although they aren't really "matched" except by brand. On my cars and truck I usually change the wires every other plug change. Plug condition is what matters, wires just a conduit. Get a quality set and they should last at least 50k.
