Idle problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Weasel, Oct 1, 2007.
  1. Oct 1, 2007 at 8:26 AM
    Weasel
    Weasel [OP] Member
    Hopefully someone can point me in the right direction. The idle on my truck is really low after it warms up. It is now idleing around 500 rpm's. It drives normally, nothing else is wrong that I have noticed. No check engine light or anything. Any thoughts or suggestions would be greatly appreciated.
  2. Oct 1, 2007 at 1:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Might want to check the idle air control valve. On the 3.4L V6, it's right under the throttle body. Most likely it'll need to be cleaned out. Just grab a can of Gumout or something similar and use that on the IAC valve. Which reminds me that I need to do mine!
  3. Oct 1, 2007 at 1:50 PM
    Weasel
    Weasel [OP] Member
    It's 2.7L, is it still in the same location? Also my battery crapped out on me, and when the new one was put in was when this started.
  4. Oct 2, 2007 at 6:20 PM
    sslongmuir
    sslongmuir Well-Known Member
    Maine
    95 single cab 2.7 on 33's
    Custom rock sliders
    my 2.7 idles low but when i throw a scan tool on it it has nothing to do with it. i would kinda like to know too. its fine sometimes but mostly rough.
  5. Dec 9, 2007 at 3:08 PM
    solo0033
    solo0033 Member
    sr5 prerunner trd
    when cleaning the throttle body...can i open and close the little plate in there and spray the cleaner behind the plate? thanks
  6. Dec 9, 2007 at 3:12 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yes, you can open up the valve and spray cleaner in there. You should also grab a used toothbrush to get to the little spaces in there to get it clean.
  7. Dec 9, 2007 at 3:21 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I can say nothing more than humanoid, listen to his wisdom and experience.
  8. Dec 9, 2007 at 3:25 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    how much lower does it idle than mine
  9. Dec 9, 2007 at 3:48 PM
    solo0033
    solo0033 Member
    sr5 prerunner trd
    cool thanks....one other question im looking at this pic (above) of #8 (permalink) [​IMG] vbrep_register("40554") [​IMG]
    [​IMG] 12-09-2007, 04:25 PM
    2003greenbean
    and his engine temp. is the same as mine ..that looks a lil hi as it is above half...i come from driving hondas where it is alot lower (below) = temp. gauge needle ...please advise. thanks
  10. Dec 9, 2007 at 3:50 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    That engine temp is normal.
