Rear diff breather mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ross123, Nov 28, 2010.
  1. Nov 28, 2010 at 10:45 AM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    Is the rear diff breather mod really needed? Or is it one of those things ppl do just in case?
  2. Nov 28, 2010 at 10:47 AM
    jandrews
    '09 FourDubDee TRD OR
    Define "needed"? If you regularly cross water, I would say it's absolutely necessary.
    Codyfish likes this.
  3. Nov 28, 2010 at 10:49 AM
    ross123
    fort bragg
    Ok that's really all I was looking for.
  4. Nov 28, 2010 at 10:49 AM
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    It is only needed if you plan on submerging your rear diff in water. If you dont plan on taking it through water and mud you should be good leaving it where it is now.
  5. Nov 28, 2010 at 10:52 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Like Jandrews said, its only needed if you plan on crossing water up to your axles, if its just small puddles don't even worry about it.
    If you plan on offroading, you may as well just do it because chances are your going to cross some deeper water at some point in your travels.
    JDawg562 likes this.
  6. Nov 28, 2010 at 10:54 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    for well under $20 i say do it anyway just incase
    REDdawn6 likes this.
  7. Nov 28, 2010 at 10:57 AM
    06RedComa
    06 4x4 DC Sport
    x2 and the mod is super easy
  8. Nov 28, 2010 at 10:58 AM
    ross123
    fort bragg
    Yeah I have all the materials. I was just putting it off until I got my lift done so I didn't have to buy a new hose if its not long enough but I think I'll just do it. Thx guys
  9. Nov 28, 2010 at 11:05 AM
    OffroadToy
    It's also a good mod for backing down boat ramps.
    BWSecretQ likes this.
  10. Nov 28, 2010 at 12:06 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Deaver 1.5" AAL Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on, Carrier Bearing flip
    ^What he said. Some lakes I have to drive completely in the water to get my tin can off the trailer. Peace of mind is worth the 20mins this takes.
  11. Jan 17, 2011 at 1:05 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    so whats needed to do this mod?
  12. Jan 17, 2011 at 1:07 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Its a 2nd gen thing as far as I know.
  13. Dec 15, 2011 at 7:05 PM
    comajoe
    comajoe Well-Known Member
    rougemont, NC
    06 tacoma sr5
    its an ALL gen
    RedRed likes this.
  14. Dec 15, 2011 at 7:30 PM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    It's under Mods & Tutorials at the top, 2nd gen how to's, diff breather mod for dummies.
  15. Dec 15, 2011 at 10:09 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    Click on My Diff. Breather Mod. Pics link, below... I made it as easy as pie with photos and details...
    For the OP, if you drive a HOT differential into water that is close to a foot or more deep, the water (usually muddy) can and will siphon into the differential oil by way of the AXLE SEALS.
    The stock 'breather' is really only an exhaust valve to let hot gasses out of the diff. When you dip into cool water there is negative air pressue (a vacuum) inside the diff... and to break that vacuum, air or muddy water will try and get in, as it should.
    The FRONT breather (4WD) has a proper 2 way breather (lets hot gasses out as well as cool air in to break the vacuum). That breather is located at the end of a rubber tube, high up, near the fuse box.
    The mod. does the same thing for the REAR diff... We put the 2 way breather at the end of a tube, high up.... It is easy. See my pics...
  16. Jan 20, 2015 at 10:00 AM
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  17. Feb 13, 2017 at 8:35 AM
    Geeterman
    Geeterman Dave - THL
    Dave
    2017 Tacoma TRD Off-Road 4x4
    2017 TRD OR 4x4 King Shocks OME Heavy Springs Prinsu Cab and Cap Racks Fuel - ANZA D583 Bronze 17x8.5 -6mm General - Grabber X3 LT265/70R17/10 121/118Q Baja Designs S8 30" Driving/Combo LED Light Bar Baja Designs S2 Pro , Work/Scene LED Southern Style Offroad - Slimline Hybrid w/30" Baja Cutout All-Pro Off-road APEX Sliders Leer 100R Top - WeatherTech Lasercut floormat’s RotoPax - LOX Pack, 2 Gallon Water, 2 Gallon Gasoline GEN2 x2 PowerTrays - Bussmann RTMR REDARC - Dual Input 25A In-vehicle DC Battery Charger
    I'm new to Toyota's and Off-roading in general. Is this a issue limited to 3rd Gen owners or is this a modification that previous models have had as well. Just trying to understand why Toyota would have designed it this way. Anyone know?
  18. Feb 13, 2017 at 8:54 AM
    Lux
    Lux @jamesgrouss
    Jim
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    all models have the breather sitting on the axle itself since the 1995 tacos and probably before that too, Im not sure if they have it extended on the 3rd gens but I don't think they do, not sure why they haven't fixed this yet if that is the case. Just look on your axle and if you see this thing, you should do the diff breather mod.
    MattMan01 likes this.
  19. Feb 13, 2017 at 9:18 AM
    David K
    The problem is that thing is not really a breather but is a one-way, spring vent.
    It will expel expanded gasses from inside the differential but will not let air in during a vacuum condition (caused when you drive into cool water when the diff is hot).
    When there is a vacuum, air (or water) will try to get into the differential to cancel the vacuum. It will do this by passing through the axle seals.
    A true breather, like what they put on the front differential, up high above a water crossing depth, will let air into the differential thus breaking the vacuum and stop the natural tendency for water to be drawn in through the axle.
    Geeterman and beertimecontinuum like this.
  20. Feb 13, 2017 at 10:47 AM
    Geeterman
    Dave
    Thanks for the information guys. I'll plan on doing the modification. Looks really simple and seems like it will save a lot of headache later.
