Does the 2012 Lower trim panel fit on pre 2012 trucks?
Old 07-14-2012, 03:32 PM   #1
ShaLor [OP] ShaLor is offline
ShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shedShaLor is one of the sharper tools in the shed
ShaLor's Avatar
ShaLor's Tacoma Gallery
I know the 2009 trim panel with the spots for switches fits on a 2007 tacoma, but now that Toyota has come out with a new lower trim panel for the 2012 year with one more spot for switches, I am wondering if anyone knows will this fit on older than 2012 trucks?
The 2012 part number for the lower trim panel is: 55407-04050-B0
The 2009 Part number for the lower trim panel is: 55407-04040-b0
I don't know the part number for the 2008 and older panel.
Old 07-19-2012, 05:57 PM   #3
SoCal LED Dash Swap
Jerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shedJerez is one of the sharper tools in the shed
Jerez's Avatar
Name: Roderick aka Royer
Jerez's Tacoma Gallery
I will let you know soon...I ordered the part and waiting to go pick it up at Toyota
Old 07-19-2012, 09:18 PM   #4
ShaLor's Avatar
Looking forward to seeing your results.
Old 07-24-2012, 04:42 PM   #5
SoCal LED Dash Swap
Jerez's Avatar
yes it fits
only problem...you cant install the cigarette lighter on it...the part itself is bigger than the hole since toyota eliminated the lighter plug for the 2012s
so one of these days ill buy another 12 v olug
also., it uses the same blanks as the 09+ so your existing atrac button will fit perfectly
Old 07-24-2012, 04:49 PM   #7
SoCal LED Dash Swap
Jerez's Avatar
negative....i dont smoke so im good lol
you can make it fit...just need to make the hole bigger
Old 07-24-2012, 04:57 PM   #8
ShaLor's Avatar
yes it fits
WooHoo! happy to hear it.
One more favor please. Looking at the picture of the switch blanks, it looks like there isn't room for the carling switches in there. I know you generally have to trim the sides of the switch blank opening for the carling switches and it doesn't seem like there is enough room to trim. So I was thinking of ordering the switch blank holders from OTRATTW and cutting out the space and putting them in that way. Can you find the measurements of the flat area for the buttons?
Three switch holder:
Cutout required for installation is 3.05 X 1.90 inches
Finished dimensions are 3.40 X 2.30 inches
Four switches
Cutout required for installation is 4.08 X 1.90 inches
Finished dimensions are 4.434 X 2.3 inches
Do you think either of these would fit?
Thanks so much for being everyone's Guinea pig.
Old 07-24-2012, 05:00 PM   #9
Jetfixer
aptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shedaptech is one of the sharper tools in the shed
aptech's Avatar
aptech's Tacoma Gallery
Old 07-24-2012, 05:00 PM   #10
SoCal LED Dash Swap
Jerez's Avatar
id have to check...post a link of what switch exactly so i can look...
im running the same blank covers from the 09 on this piece...i know there are new blanks now
but from what you say, it may fit
no prob...gonna post my 09 dash for sale soon
Old 07-24-2012, 05:02 PM   #11
ShaLor's Avatar
I may just buy that from you
Old 07-24-2012, 05:05 PM   #13
SoCal LED Dash Swap
Jerez's Avatar
Originally Posted by ShaLor View Post
ah, see with those i would think you need would need to trim because ive seen those installed to the left of the drivers side and the panel had to be trimmed for them to fit
Old 07-24-2012, 05:07 PM   #14
ShaLor's Avatar
Yep, that's why I was thinking I would just have to cut out the entire panel and put in their switch holders. I was wondering if the area is big enough for the switch holders or not.
Old 07-24-2012, 05:09 PM   #15
SoCal LED Dash Swap
Jerez's Avatar
im pretty sure theyre not big enough...so trimming will be required
Old 07-24-2012, 05:11 PM   #16
ShaLor's Avatar
I think we both agree that trimming is required, I am wondering if the flat area would hold the size that the OTRATTW switch holders would need to be without overlapping over the edges. I am not sure if I am communicating clearly or not, so my sincerest apologies if I am confusing.
Old 07-24-2012, 05:23 PM   #17
SoCal LED Dash Swap
Jerez's Avatar
it may fit...i would need to check one of those buttons to see how much need to be trimmed
now im curious because i plan on adding a locker and this is where i plan on adding the buttons
Old 07-24-2012, 05:32 PM   #18
ShaLor's Avatar
These are the dimensions of the switch holders:
Four switches
And here is a link to a thread I found on installing these particular switches and how much to trim.
http://www.tacomaworld.com/forum/2nd...-location.html
Old 07-24-2012, 05:36 PM   #19
Look away, I'm hideous!
joneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shedjoneill03 is one of the sharper tools in the shed
joneill03's Avatar
joneill03's Tacoma Gallery
All these replies after this post and not one "thats what she said" comment?
Old 07-24-2012, 05:39 PM   #20
SoCal LED Dash Swap
Jerez's Avatar
Four switches
ya that panel wouldnt fit on there...id rather just cut the piece on the existing panel...i wanted to try to fit a 5 switch and completely move the 12 v accessory plugs on a new spot
if you want to check it out, im having a bbq meet thing here at my house next saturday...burbank is about 45-50 mins from my house
i was going to but....mehhh
Installing 2012 stock radio in a pre-2012 Jerez Audio & Video 343 03-01-2015 06:10 AM
Does a 2009 Lower Trim Panel fit on a 2007? ShaLor 2nd Gen. Tacomas 14 06-20-2013 02:37 AM
Suggest Best Exact fit Seat Covers 2012 Pre-runner Access Cab? BOB Moore 2nd Gen. Tacomas 37 12-17-2012 03:57 PM
Crappy 2012 window rubber trim? donniep 2nd Gen. Tacomas 8 04-24-2012 03:27 PM
2012 Tacoma - Smoked Headlamp Trim Commanderwiggin 2nd Gen. Tacomas 6 03-30-2012 11:03 PM
