more robust bed tie-down points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beechcraft, Mar 2, 2009.
  1. Mar 2, 2009 at 8:45 PM
    beechcraft
    beechcraft [OP] Member
    NJ
    06 AC 4x4 TRD-S
    I recently bought an '06 to replace the '99 with 271k miles that Toyota bought back from me.. and while I'm impressed that nearly everything is improved, I don't believe the bed rail system will meet my needs.. I regularly move arcade machines which tend to have a high center of gravity and need to be strapped in as tight as possible. A 3" strap pulled taut would hold in damn near anything, I'd rip the rails off if I tried that on the new truck, and the D-hooks at the back of the bed don't seem that strong either..
    Has anybody added in hooks in the place they were found on the 1gen trucks? the placement was ideal for what I need. Anything aftermarket available or any other good solutions?
    first time poster, but this has been a great resource I've searched through for many years.. thanks!
  2. Mar 2, 2009 at 8:51 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Welcome!
    dang thats some heavy duty stuff right there
    Get the TSB done first and then we will talk D-rings :)
  3. Mar 2, 2009 at 9:20 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Exactly. Then you can steal all the video games you want without a problem.
  4. Mar 2, 2009 at 9:21 PM
    beechcraft
    NJ
    06 AC 4x4 TRD-S
    Obviously, my first thought was the D-rings.. but even at 800 lbs WL I'd probably stress them too much with a 3" strap and they would be the weak link. They'd probably work fine for most things, but I can't chance it and I need something heavier than that..
    I want the get the TSB done, but I'm under the impression it has to be under warranty for that? I'm at 55k miles so I'm still under powertrain, but not B-to-B. Any idea on cost outside of warranty?
    On the old taco I cracked leaf springs twice.. I went with heavier springs after the first time and one still cracked a year later.. a normal load isn't any more than 600lbs or so usually, but every now and then I'll get something like that first pic above, that game weighs about 1k lbs.
    My first truck was an '86 1 ton long bed (7.5') with a 22RE. Couldn't really tow anything with that but it could haul anything. Long bed sure would be nice on a Taco, I think they phased it out in '97 or so?
  5. Mar 2, 2009 at 9:25 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    What he's talking about is installing the D rings into the bed bolts. You simply won't find a stronger tie down point than that.
    You could probably go with an AAL instead of the TSB. Someone more knowledgable on this will chime in, I'm sure.
  6. Mar 2, 2009 at 9:38 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    If those are the cheap ones, where do we find better ones?
    I'd like to have the strongest ones possible. I believe I just ordered the rings you posted, but I'd like to know about stronger ones.
  7. Mar 2, 2009 at 9:53 PM
    beechcraft
    NJ
    06 AC 4x4 TRD-S
    Thanks.. I'm interested to hear what my options are for the springs as well..
    I'm aware of exactly what he's talking about, though. I don't need the D-rings at the rear of the bed (I assume this is standard-issue?) so I could relocate them to the front, but if there is anything heavier out there I need to go that route. The D-rings will likely stretch and the flange will probably bend over time using heavy straps. The bolts themselves are surely solid enough.
    I realize I'm in a minority here as most people don't actually use tacos for heavy lifting .. moving a couple bikes or a fridge isn't going to warrant any undue stress on the rail system.
    If there is nothing heavier readily available out there I'll probably look into getting a couple rings fabbed up from plate steel that I can attach to the bed bolts, it'll probably only cost a few bucks and could be laser/water cut in a minute and then bent in the middle, or something along those lines..
  8. Mar 3, 2009 at 5:47 AM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    Yeah, that's what I ordered and plan to do. I also see that you can cut, remove or place the washer under the d-ring...I plan to cut. It provides more base for the head of the bolt.
    In the picture above, he uses the washer under the d-ring. This probably looks better than cutting (depending on how cleanly I can use my angle grinder).
  9. Mar 3, 2009 at 6:18 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The size of the strap does not have anything to do with how much force is applied to the D ring. The strap has a hook on it that is less than 3 inches, doesn't it?
    If the D rings on the 1st gen Taco were strong enough look for one in a junkyard and install them on the front bed bolts. Personally, I think an 800 lb working load rating would be entirely adequate for your use. The 1000 lb unit you refer to has its weight being pulled down by gravity. The enire 1000 lbs is not applied to a rearward vector and you would have the load split between two rings providing a 1,600 lb working capability.
  10. Mar 3, 2009 at 6:29 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Bed bolt d rings or similar heavier duty thing using bed bolts, make sure you don't have the magic folding tailgate ( not sure how much of those machines ever hit it) tsb for that too but only up to 36k. There is a reinforcement thread. I'm doing Toytec 1.5 AAL that works with the tsb leafs & timbrens for load handling without bottoming.
  11. Mar 3, 2009 at 6:01 PM
    TheTacoManChach
    TheTacoManChach I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    I need you to drop the Blitz game off at my house if thats not a problem...
