ESP concern with a larger tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mops, Mar 5, 2014.
  1. Mar 6, 2014 at 12:55 PM
    #21
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I'll have to call and give Brad some shit for not being behind his desk. They are not the cheapest place to have work done, but they will stand behind it and get any problems ironed out. I would much prefer that route than trying to save a couple bucks and pay more for it later on. Yeah, it's no longer my occupation, but it's a hobby. I like it better that way. When I get bored or antsy, I get to go build stuff.
  2. Mar 6, 2014 at 1:03 PM
    #22
    Mops
    Mops [OP] Well-Known Member
    Mop
    NW NC
    Haha, the guy I spoke to initially said Brad is the Toyota expert, so he would be doing the work. And yea, there is def some comfort going with them. The $490 with align was not bad. Its was the 7 hours shop time that surprised me. Seems like a nice guy for sure. Maybe he goes very slow to get things just right? Cool, same here with detailing and landscaping. I do it when want to these days. Lowe's takes most of my time. I was only asking to say you are welcome to do it if you would like. He has this link, so he may be looking in:)
  3. Mar 6, 2014 at 2:49 PM
    #23
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Here you go
    12 pages of people with VSC issues / sensitivity after lifting , and a pdf file from the Toyota FSM for resetting the VSC ECU after changing any suspension parts
    http://www.tacomaworld.com/forum/suspension/41215-lift-vsc-answer.html
  4. Mar 6, 2014 at 7:50 PM
    #24
    Mops
    Mop
    NW NC
    Not questioning at all. Just doing my due diligence.
  5. Mar 8, 2014 at 6:25 PM
    #25
    SoCal1
    SoCal1 Member
    Install a quality set of upper arms and re-align it and you'll be set! These will add much needed caster and help you with the premature ESP activation! We recommend Total Chaos, Icon or Camburg upper arms. All of these will do the trick!
  6. Mar 8, 2014 at 6:26 PM
    #26
    OZ-T
    Peter North
    British Columbia
    All that does is give you more caster
  7. Mar 10, 2014 at 5:19 PM
    #27
    SoCal1
    SoCal1 Member
    Too low of caster will cause it to activate prematurely. "A great alignment" is a little vague. Post the specs and we can try and help with a little more detail
  8. Mar 10, 2014 at 5:22 PM
    #28
    OZ-T
    Peter North
    British Columbia
    3 caster , 0 camber , 0 toe
  9. Mar 10, 2014 at 5:23 PM
    #29
    Boone
    Boone, NC
    Airbags deployed
  10. Mar 10, 2014 at 7:08 PM
    #30
    Boone
    Boone, NC
    Airbags deployed
    We'll get it figured out. The guys at High Country are damn good, and I've got a hell of a alignment tech that can actually align some shit to other than factory specs. #DCLBFTMFWMFDIE.
  11. Mar 10, 2014 at 7:33 PM
    #31
    Mops
    Mop
    NW NC
    The same guy Brad will be taking it to?
  12. Mar 10, 2014 at 7:43 PM
    #32
    Boone
    Boone, NC
    Airbags deployed
    I don't honestly know who High Country uses now, but like I said before I'm sure they will stand behind their install. If there are any alignment probs, Alray Tire can right any wrongs. Judd or Jimmy will set it at the optimal settings, not factory specs.
  13. Mar 10, 2014 at 7:57 PM
    #33
    Mops
    Mop
    NW NC
    10-4. I was more or less asking because my A5 needs a proper align. So much inner shoulder wear. Going to pick up some adjustable UCA's, and want the align done right.
  14. Mar 10, 2014 at 9:58 PM
    #34
    SoCal1
    SoCal1 Member
    Casters at 2 and will get much better around 3.4 to 3.7 degrees. Also, stiffer tire sidewalls than stock can make it worse.
  15. Mar 10, 2014 at 9:59 PM
    #35
    OZ-T
    Peter North
    British Columbia
    My caster is at 3
  16. Mar 11, 2014 at 6:32 AM
    #36
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
