Noise after 3" OME Lift kit
Discussion in '4 Cylinder' started by dtown, Feb 7, 2012.
  1. Feb 7, 2012 at 11:08 PM
    dtown
    dtown [OP] Member
    Littleton, CO
    2.7L 4x4
    Yeah,
    I read a lot about this before I decided to go with an OME 3" complete lift on my 09' Taco reg cab 4x4. I went with a complete leaf spring kit, 885 coils w/ 3/4" front spacers. I am still running 16" wheels w/ goodyear wrangler duratrac tires. I was really hoping that after having this kit installed professionally, that I would not be a victim of "the noise" that seems to plague 4 banger tacos w/ a lift kit.
    So, "the noise." I am not a mechanic, but I am somewhat mechanically inclined. That being said, I've read about a lot of different remedies for this noise, which consists of a vibrating that happens in the driveshaft or diff. when you take your foot off of the gas and you're going faster than about 55. I don't think it happens when I'm in 4wd, so it must be the rear shaft. But then again I never go faster than 50 or so when im in 4, so it's tough to say, but I don't think it happens in 4.
    I've read about some remedies which include; Simply flipping the rear driveshaft from end to end (some say it works some claim nonsense), installing the 3 degree axle spacers that OME offers, getting a new 2-piece driveshaft to compensate for the now "whacked out" angles that lifting the truck caused where the shaft meets the diff? I think? At any rate, as I am not a mechanic and only somewhat mechanically inclined, I was really hoping someone on here with a 2nd gen. 4 banger, lifted, would have some answers to this problem, for a grateful tacoworld member:) I know there are others' who have run into this issue, so hopefully some folks can chime in w/ a little insight!
    I hope everyone that reads this has a phenomenal day and an even better night! God Bless you and your family and friends.
    Clint
  2. Feb 7, 2012 at 11:19 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
  3. Feb 8, 2012 at 11:22 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Between the carrier bearing spacer and the rear axle degree shim, you should be able to get the rear driveline as close to 0 degrees as possible. Both are available from Toyteclifts.com
    With front vibes, the front diff drop may be necessary.
  4. Feb 8, 2012 at 11:24 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    First, the front:
    Whoa - 885 springs AND a 3/4" spacer? Do you have any downtravel left at all? Actually, that photo doesn't look like the front is crazy high - are you sure you didn't perhaps use 884 springs with a spacer? Measure from the center of the front hub to the bottom of the front fender and report back.
    Now, the noise.
    Yeah, a loudish noise through the cab when you let off the gas going around 60 or 55, is probably the rear driveshaft. You can't "change" to a 1 piece driveshaft, because that's what you've already got. The "carrier bearing" driveshaft is only on the longer access and double cab models.
    It's pretty easy to end-for-end swap the driveshaft. Try it out if you want too.
    Aside from that, maybe just grease your driveshaft zerks and then don't worry about it.
  5. Feb 8, 2012 at 11:24 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Holy crap , how much lift did you get with that set up on a reg cab ?
  6. Feb 8, 2012 at 11:30 AM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 90021 with 885s and top plate spacer, 2" AAL, OME rear shocks, Camburg Uniball UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    the answer must be in the 4 billion + posts! :eek:
  7. Feb 8, 2012 at 11:39 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If you don't address the vibration from the u-joints, they will eventually fail. The rear noise/vibe is from the u-joints excessive movement. They are only quiet and vibe free with a few degrees of misalignment(the actual number escapes me). By clocking the rear axle pointing closer to the transmission lessens the misalignment and will either reduce or eliminate the noise. This is accomplished with a wedge shim between the leaf seat and the axle.
    I didn't check the op's truck before my first post. :facepalm:
