-   -   Need advice on Engine Vibration (http://www.tacomaworld.com/forum/4-cylinder/193903-need-advice-engine-vibration.html)
vikx 12-20-2011 10:56 AM
Hello all,
I'm a newbie to Toyotas. My truck has a 2.4 L with automatic. 54K miles. 2WD. The motor seems to vibrate at idle, shakes the steering wheel slightly, also seems to idle too fast. Accelerates OK from a stop. It actually seems to run pretty smooth; the idle vibration is driving me NUTS. Any thoughts?
Thanks in advance.
gcoates 03-31-2012 04:52 AM
When sitting at a light, if you take it out of gear does the vibration stop ?
vikx 04-01-2012 10:12 AM
The vibration happens in drive or neutral. It's like the engine is idling a little fast. Nothing I can put my finger on, just not a "smooth" running motor. The truck seems to run fine, starts every time, no other issues. I've never had a Tacoma before, but don't think this is normal? Thanks for the help.
DGXR 04-03-2012 08:15 AM
http://www.tacomaworld.com/forum/4-c...vibration.html
vikx 04-04-2012 09:04 AM
Thank you for the link! This one has certainly never "purred like a kitten".... LOL.
