35" Pitbull Rockers and Cumburg UCA's en route!
Discussion in '4Runners' started by Bawlzdeep, Feb 8, 2012.
  1. Feb 8, 2012 at 9:53 AM
    Bawlzdeep
    Bawlzdeep [OP] I'm dropping the hammer
    Jon
    Penn Valley CA
    S/C'd 97 4Runner 5spd
    lift, tires, winch, 5spd swap, dual lockers..
    :woot:Just called and ordered my 35x12.50R17 Puitbull Rocker Radials from Discount Tire. 2-3 days shipping and then time to bring out the big hammer maybe the saw! I refuse to rock a body lift.
    And then the Camburg UCA's should be in. No more weak creaking ball joints! I'm one wheel bearing away from having a completely new front end.
    Pics will be up as soon as I get parts.
  2. Feb 12, 2012 at 9:31 AM
    TNRunner
    TNRunner Blah,blah,blah...
    TN
    2017 Double Cab
    What kind of a deal did you get on the Rockers?
  3. Feb 12, 2012 at 12:09 PM
    Bawlzdeep
    Jon
    Penn Valley CA
    Discount Tire Direct for $398 + $50 insurance for each and free shipping. So after they waived one of the insurances and threw in free valve stems they got around $1750. Just a lil more than the $800 I was prepared to do with the 15's and KM2's. Ohh well:rolleyes: these tires are pretty ridiculous in the sand and mud.
    Got the new shoes on Saturday morning and went wheeling/camping right after install. I ended up having grind a bug chunk out of my UCA to keep the sidewall out of it. It's fine for right now in a straight line but still hits with light steering. Once the new UCA's are in then I'll be able to start working the body clearance issues. The rear is gonna be pretty easy but can't tell about the front yet.
    Here's the pics finally (Samsung Galaxie S II Skyrocket)
    Buddies Jeep stuck in the first hole that I putted through in 2wd, love these tires!
  4. Feb 12, 2012 at 12:21 PM
    TNRunner
    TN
    2017 Double Cab
    Nice! Couple of my buddies run 'em and they are bad azz.
  5. Feb 12, 2012 at 2:11 PM
    Wildjones
    Wildjones Member
    San Jose, CA
    Wow! Looks great!
    Not to thread jack you, but I have a somewhat random question for ya (coming from a complete 4Runner newb). When you lift a 4R 2.5-3" do you have to do new UCAs like you do for the Tacos?
  6. Feb 12, 2012 at 2:18 PM
    TNRunner
    TN
    2017 Double Cab
    It's highly recommended!:)
  7. Feb 12, 2012 at 3:04 PM
    Nick Sells
    Nick Sells Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    THAT LOOKS AWESOME! Wish I could make that happen on my 5th gen.
  8. Feb 12, 2012 at 3:13 PM
    blacksheff405
    blacksheff405 no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    do you know how many miles you can get out of those tires??
  9. Feb 12, 2012 at 3:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    dear god those things are nuts. nice runner... closely resembles a tank
  10. Feb 13, 2012 at 11:18 AM
    Bawlzdeep
    Jon
    Penn Valley CA
    Supposedly 35k. I've only put 10k on it since Aug 2010. They should be around for a while!
  11. Feb 21, 2012 at 11:16 AM
    Bawlzdeep
    Jon
    Penn Valley CA
    New UCA's are in finally! I don't need new wheels after all. They have plenty of room. Very easy install and great hardware, good welds, just very clean pieces....for now.
    Original destroyed UCA's. The outermost portion is what I had to grind out just to clear the sidewalls to bolt the wheels on. The rest of the missing paint is from the slight turning radius issue. Yeah I know it's bad
    First attack with the sawzall
    Still have to address the rear
  12. Feb 21, 2012 at 12:18 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Awesome man. Big tires and small lift=win. Not a huge fan of the chrome, but it does look pretty good.
    How are the pitbulls on the highway? Tons of noise?
  13. Feb 21, 2012 at 9:26 PM
    Bawlzdeep
    Jon
    Penn Valley CA
    Wow wow wow! That's aluminum not chrome! I wouldn't mind blacking them out but they're really growing on me. Flat black was my original plan. The noise isn't really that bad, little more than the Kumho's but no where near swamper loud.
  14. Feb 21, 2012 at 9:42 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    damn those look awesome !! iv been thinking about 35s for a while, not sure im ready for pitbulls tho. what gears are you running?
  15. Feb 21, 2012 at 9:48 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Looks sick!
  16. Feb 21, 2012 at 10:16 PM
    Bawlzdeep
    Jon
    Penn Valley CA
    Thanks guys, it's still a work in progress, always will be. Still got stock 4.30 gears but the 5spd is geared a lot lower in the bottom gears, 5th is still a little lower than the auto 4th. She pulls just fine for me. Has no problems at highway speeds either. I'd deffinitely have at least 4.88's with an auto. I'll never go back to an auto though!
  17. Feb 27, 2012 at 4:02 PM
    hard2kill
    hard2kill Well-Known Member
    John
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    what size were those kl71? i had them on my old duramax but never on the trail....how were they on the trail,rocks,mud?????? btw the pit bulls are badass tires, simply awesome....nice rig
  18. Feb 27, 2012 at 5:18 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Dan that thing is awesome
  19. Mar 25, 2012 at 4:04 PM
    peacefrog53
    peacefrog53 Member
    How the hell did he get stuck?? He is in an XJ!! I think this was photochopped.... :devil:
  20. Mar 25, 2012 at 9:23 PM
    Spoonman
    Jamie
    Alberta
    Totally looks like his snorkel is saying "NO PLEASE NO! NOT THROUGH THAT!"
