Need light information, what is best off road lights?
Discussion in 'Lighting' started by jphilipj, Jul 12, 2012.
  1. Jul 12, 2012 at 7:05 PM
    jphilipj
    jphilipj [OP] New Member
    OK, getting ready for my 2012 DC 4x4 ..I am going to install a 3 tab Crossfab light bar.
    I have no idea what the best lights to run are. I want max light with lowest amp draw.
    I assume i have to run some sort of aux relays etc..any place with a tutorial on what is needed, best etc..don't want to cut corners.
  2. Jul 12, 2012 at 7:13 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I can say that I wanted bright lights but didn't want to pay for high end HIDs and didn't trust Kragens to last. I got a pair of KC daylighters. They look good, but their light is really yellow - much more than my headlights. Their throw is amazing though - I can light up signs and treelines much further than my factory high beams. I can't really recommend them as a great option since I don't love the yellow output, but they're good quality for the $160 I paid, and highly functional. I guess this is more of a "this is what KC daylighters are like" reply than a recommendation. Hope it helps.
  3. Jul 17, 2012 at 10:21 AM
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Get three lights (your choice of size: hella 500,700 etc) and buy two 100w hid kits so you will end up having a spare bulb and ballast. That should be more light than you could ever imagine! Or spend major money on a quality led light bar (42" or so should be 15-20k lumens)
    Another great idea is to search youtube for light outputs for example search "3 100w hid lights" or "42" led light bar" and compare them that way! Im in the process of doing the same thing but behind my grill and i am going with three 100w hid kits and it should be insane
  4. Jul 17, 2012 at 10:24 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Imagine that you happen to set of lightforces haha kidding.....ive def heard good things about them they would be a nice light to convert to hid!!
  5. Jul 17, 2012 at 10:25 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
  6. Jul 17, 2012 at 10:43 AM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    im doing a set of hellas converted to 6000k hid.
  7. Jul 17, 2012 at 10:47 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    LIGHTFORCE! :D
    I'm also interested in the light bars TRS guys are selling, I don't know a ton about them yet but I do trust the guys at TRS.
    So my biased vote would be in favor of retrofit and light bar from TRS and for you and your situation LightForce lights for your bar because, well just watch a few videos of theirs and tell me you don't want them
  8. Jul 17, 2012 at 10:48 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  9. Jul 17, 2012 at 10:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^This...
    Best is way too broad. It depends on what your usage will be. Amp for amp, the max light for the lowest draw will be LED and they will be expensive! Brightest will be HID or a high end halogen but again, it comes down to usage. If you are going to run them on the road, where they will be turned off and on with your high beams, you won't want HID's because the ballasts don't like to be toggled like that. HID's like to be turned on and kept on. LED's put out a ton of light and have extremely low draw. The LED light bars can be mixed with spot and flood pattern LED's also so you can get a good mix of lighting. Halogens will be relatively inexpensive but you'll have to go with a higher end lamp if you want good light output and might have to mix spot and fog pattern lights to get the overall light pattern you desire.
  10. Jul 17, 2012 at 11:05 AM
    goomba
    Josh
    San Antonio Fl
  11. Jul 19, 2012 at 5:51 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Hella, hell ya
  12. Jul 19, 2012 at 9:18 AM
    DevL
    DevL Well-Known Member
    3 Scorpion LED floods = 35316 lumens. Done.
    If you consider Rigid lightbars only get the Specter series. They currently only come in 6" and 10" sizes. Also available as Dually D2 and in the SRM2 lights. No big light bars available yet.
  13. Jul 19, 2012 at 9:19 AM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    but how much is that? LED's are expensive as hell
  14. Jul 19, 2012 at 9:26 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I like my hella 500 black magic's, I have two, not crazy bright, but they light up a country road better than the factory high-beams.
  15. Jul 19, 2012 at 9:36 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Nahh only about $500 EACH hahaha
  16. Jul 19, 2012 at 10:37 AM
    white toy taco
    Albuquerque, NM
    here are my 2 KC daylighters, there obviously the long range beam pattern. my garage is about 100 ft away from where my truck was
    these are my 35w HID headlights.
    but if you want most light output with lowest power then HID is your best option. here is a thread where you can get some ideas http://www.tacomaworld.com/forum/lighting/131486-show-off-your-lights.html
  17. Jul 19, 2012 at 1:27 PM
    DevL
    The question was not "What are the cheapest lights I an put on my truck?"
    The brightest, most efficient, smallest lights are the Scorpion 5" LED floods. After that 100W HID, especially if you want throw. No halogen is even in the mix. After that you are looking at 50-75W HID and various long lightbars.
    WAY, WAY, way down the list comes 35 watt HID and 70-100W halogen.
    At the bottm of the list comes 55 watt halogen.
    Price Lightforce 240 Blitz HID.
    Price a 40" Rigid Industries or Baja Designs lightbar bar.
    The Scorpion does not sound so bad now does it?
  18. Jul 19, 2012 at 1:31 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
  19. Jul 19, 2012 at 1:42 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Those little monsters are beasts i would live to get a set of those to replace my fogs so i can blind people than flash me :D
  20. Jul 19, 2012 at 1:55 PM
    Pugga
    Massachusetts
    That's intelligent... let's blind the driver in the car speeding directly at me :rolleyes:
    If your lights are properly aimed, no one would flash you to begin with...
