Fog light install 2011 base model
Discussion in 'Lighting' started by bluepacific, Oct 10, 2011.
  1. Oct 10, 2011 at 10:00 PM
    bluepacific
    bluepacific [OP] New Member
    2011 Tacoma Access Cab 4x4
    Has anyone installed fog lights on a 2011 base model with 4-cylinder which is not pre-wired for anything? I want to use OEM parts and don't want to void my warranty with the install.
  2. Oct 11, 2011 at 2:47 PM
    imrocksolid
    imrocksolid Active Member
    11 SR5
    Morimoto mini-DS2 retrofit with blacked out headlights, All-Pro rear bumper, URD Short Shifter, Extang Tri-Fold, charcoal filter delete, aFe pro dry filter, shorty antenna
    I'm planning on using info found here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/51165-ebay-fog-light-kits-08-09-10-tacomas.html
    and
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/3990-non-oem-fog-light-install-anytime.html
    Not sure if either of these will void the warranty though.
  3. Oct 11, 2011 at 6:22 PM
    bluepacific
  4. Oct 12, 2011 at 6:46 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    I used the above mentioned method on my non-prewired 08 and it works great. I found a plug that would fit the switch at a salvage yard. I run my fogs all the time, with no other lights on, use them for daytime running lights.
  5. Oct 12, 2011 at 7:22 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I did my own mod by wiring them into the running lights without a switch. I you haven't noticed yet your head lights & running lights will turn off after you turn off engine and open door. So I leave my running lights on always and use fogs & running lights as DLRs. I don't have a part # for the light plug but I do have a picture of what you need. I got the fogs from a member upgrading his bumper. And I got all parts to hook them up at Pep Boys for $20. My Auto OEM Fog Light Mod
  6. Oct 12, 2011 at 7:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good info in this thread already but just figured I'd ad that adding fog lights will not void your warranty unless you do something really really really dumb like try to use the spark plug wire for power. Otherwise, adding lights, either OEM or aftermarket will not voild your warranty.
  7. Oct 29, 2011 at 6:27 PM
    bluepacific
    Thanks for all the info, I ordered and installed a fog light kit from Metro Toyota in Kalamazoo, Michigan, works and looks good.
