Best anti-theft method for offroad lights
Discussion in 'Lighting' started by pLon, Dec 2, 2011.
  1. Dec 2, 2011 at 10:55 AM
    pLon
    pLon [OP] Well-Known Member
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    I was wondering what mods can be done to protect your $300+ each HID lights on your truck? I've seen some anti-theft nuts but those aren't that hard to cut and take the lights off in my opinion, some other people just put a small weld on the nut after the light is in place but this is a permanent mod and you can't remove them anymore right? :confused:
  2. Dec 2, 2011 at 10:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you don't want to weld, thread locker will work. If someone really wants them, they can just cut the bolt off and it's theirs. Even if you weld the nut, with a small cheater bar, you could easily snap the whole bolt right off. You can slow people down, but there's nothing you can do to 100% prevent theft.
  3. Dec 2, 2011 at 11:14 AM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    I live in Tijuana, the truck sleeps inside of my garage so there's no worries at night it's very secured, but any parking is a theft possibility, then the best option would be to take the lights on and off depending if I need them to offroad or if I'm just going for groceries to the market right?, by the way the lights are 3 HID Soltek La Paz and 2 Rigid Industries Dually so I'll hate to loose those since I worked very hard to get them
  4. Dec 2, 2011 at 11:25 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    John
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
  5. Dec 2, 2011 at 11:29 AM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    hahaha hope that was possible :p
  6. Dec 2, 2011 at 11:31 AM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    This site has some cool stuff, thanks for the link :D
  7. Dec 2, 2011 at 2:04 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
  8. Dec 2, 2011 at 2:08 PM
    Texio
    Texio Well-Known Member
    Austin, TX
    11 4WD DBCab SB
  9. Dec 2, 2011 at 3:03 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Tnx Alan and Texio,
    Texio the thing is that I'm having a front bumper being built something as Special_K's used to had (KR fab) so I'm installing all my lights there, but thanks for the idea :)
    I just had another idea, since the Baja Designs have 3 mounting screws, the base for each light will have a hole in the center and at both sides a half moon to be able to rotate side-to-side the light (up and down is adjusted with the screw on top of the lights), and all 3 mounting screws with a nut soldered as a limiter and another nut in the middle to keep it tight or loosen it to rotate the light (this middle nut with tread lock or the security nuts that have plastic inside so they don't twist easily), I don't know if you can imagine what's on my mind lol
  10. Dec 2, 2011 at 3:30 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    red thread locker if they get through a good dose of that there either getting my glock or my lights could go either way.
  11. Dec 2, 2011 at 10:01 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    I would second the thread locker idea. Perhaps in addition to security type nuts. And then get an alarm with two way remote and microwave sensors that will trigger the alarm if someone stands next to the truck for too long. They don't actually have to touch it.
    A family member has this type of alarm on his fully restored Bronco. Go stand within three feet of the Bronco and the alarm chirps and activates a single green light on the pager/remote. If you continue to stand there, it chirps again and activates a second light on the pager. The pager also beeps this time. Further loitering will go to full alarm, red light and beeping on the pager. It is the only sure fire way to get him out of bed on a Saturday morning.
  12. Dec 3, 2011 at 8:13 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol when installing my arb i went off with the grade 8 bolts and red thread locker lolz
    no ones taking that either at least not with out a blow torch :)
  13. Dec 3, 2011 at 10:58 AM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Yes definitely I'll be using grade 8 bolts, because no mater what security locks you use if the bolt can be sawed easily, then my idea is to weld a nut at the bottom giving enough room to adjust headlights horizontally and another nut to tighten the lights in place with red thread lock, thank you all for your ideas I'll speak with the guy that will custom fab the bumper :D
  14. Dec 3, 2011 at 12:46 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Stake the threads with a chisel, red threadlocker, or weld. Still won't stop a determined theif. The best you can do is slow them down.
  15. Dec 3, 2011 at 1:21 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    Yes you can only slow them down, good thing I have a 2-way Viper alarm, so I will be advised when it gets triggered, this way they only have about 5min tops until I get there :)
  16. Dec 13, 2011 at 10:26 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    my GF's dad had these laying around. He only had two, so I snagged both of them
    The top requires a key that you would put in your socket wrench
  17. Dec 14, 2011 at 1:12 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    I think I will have the light bar fabricated plug and play, to put it away when I'm not off-roading, also I wanted to ask what are the California laws for off road lights, you have to have them covered (even if the covers are clear)? Unplugged?
    I am here: http://maps.google.com/maps?ll=32.568235,-116.585793
  18. Dec 14, 2011 at 1:29 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    In CA, you can only have 4 uncovered lights. So if you got 2 headlights, and 2 fog lights, everything else needs to be covered. Doesn't have to be unplugged
  19. Dec 14, 2011 at 3:11 PM
    pLon
    Heriberto
    TJ
    06 Tacoma DC 4x4
    none yet
    I was asking this because a friend of mine told me that once, he was pulled over on the freeway and the highway patrol checked if he had unplugged his off-road lights, thanks for the clarification :)
    I am here: http://maps.google.com/maps?ll=32.568591,-116.585753
  20. Dec 14, 2011 at 3:34 PM
    OffroadToy
    My Piaa lights mount with nuts that are pretty accessable. What I ended up doing was covering them useing hose clamps...2 on top of each other (total of 4.)They're situated in a way that it's hard to get a socket/screwdriver on them. Most theifs wouldn't bother after seeing the time it would take.
