Rust Proofing, Rust Proofing, Rust Proofing!
Discussion in 'Product Reviews' started by Kevinztaco, Feb 2, 2013.
  1. Feb 2, 2013 at 9:31 AM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    Those of us who have to put up with snowy/icy and salted Roads face the dreaded rusts problems no matter what we try to do to prevent our toys from rusting. I've checked with a local shop that does rust proofing and the guy who does under body coating told me that he would do my Taco for $500.00 + Tax with a 10-year warranty. He said that in order for the 10-year-warranty to not void, I have to pay $35+Tax per year for his shop to check it annually. That's like $900.00 for 10 years. I'm curious if it is even worth the time and money? I'm planning to keep the Taco until it falls apart that is why I'm exploring my preventive options.
    Any body has any idea on effective DIY rust proofing technique? Thanks a bunch for any suggestions.
    She works like a loyal wife for me so far and I plan to keep it that way for a long time.
  2. Feb 2, 2013 at 9:39 AM
    Tacoma Mike
    Southern Maine
    Lots of threads on this.
    I suggest reading through them to get an idea of the way they are done.
    Myself it's Fluid Film and a pressure washer or hose twice a year.
  3. Feb 2, 2013 at 9:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've been looking into this myself lately and decided I'm going to try Eastwood products to treat the frame. I actually bought a complete Fluid Film kit but decided not to use it. Fluid Film is an oily film that never dries. It will do a good job protecting the frame but gathers road grime like a magnet so it'd make it very messy for working on the truck in the future so I decided against it. POR15 seems like a great product but in most of the reviews I was able to find, if you don't do the prep work perfectly, the product doesn't hold up. A recent product I was pointed to seems promising also. It's called Rust Bullet. I just started looking into it and don't know much about it yet. In short though, it seems like as long as you do something, you're better off than 90% of people on the road. Could be as simple as getting under your truck once a year with a wire wheel and a can of spray paint, just gotta keep up with the rust.
  4. Feb 2, 2013 at 1:41 PM
    Simon's Mom
    Simon's Mom Wag More Bark Less
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I had Toyota rustproof my 2013 truck this time around.
    My 2006 looked awful after a couple of yrs. 5 yrs it was a mess.
    They did a very thorough job & can go back to get it touched up for the life of ownership.
    It has some kind of warrantee too.
  5. Feb 2, 2013 at 1:47 PM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    Fluid Film application with undercoating gun/compressor twice a year, May and November. Give it a good undercarriage wash first and try to spray in every little nook and crevice. Avoid spraying the exhaust or the smell will be repulsive.
    Coming up on my first year owning my 2012 and the underside still looks great here in Massachusetts where salt and sand are used regularly. I also tow a boat and launch in salt water. I'm satisfied so far with this method.
  6. Feb 2, 2013 at 6:49 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    My 03 still looks like new after using liberal amounts of Amsoil heavy duty metal protector and fluid film. Fluid film isn't that cheap though.
  7. Feb 9, 2013 at 6:23 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I was in the same boat as you. I ended up getting the undercoating. In hind sight i am glad i got it done before winter and think it was worth it. They also drilled and sprayed the doors, tailgate, bedsides. I also plan on keeping the truck for a long time so I think it was a wise investment.
    Here's the link. there are pics at the end:
    http://www.tacomaworld.com/forum/detailing/238549-undercoating-protection-worth.html
  8. Feb 10, 2013 at 11:55 AM
    Kevinztaco
    none yet
    I wonder how thorough those guys are when it comes down to the hidden spots such as the insideand top of beams?
  9. Feb 11, 2013 at 7:46 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Good question. The best way is to stop by the shop and check out the work they do. The only thing that was not sprayed on my truck was the exhaust,heat shield, drive line and spare tire. I pulled the bed cubby boxes out and my bedsides were completely coated like they said so I was satisfied (I know composite bed doesn't rust). I did a thorough inspection on their model car before as well as after i got my truck back. That picture doesn't look like much is coated.
  10. Feb 18, 2013 at 7:14 PM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    What did Toyota charge for the rust proofing?
  11. Feb 18, 2013 at 7:28 PM
    OffroadToy
    The regular undercoating like the dealerships apply will develope cracks/holes over time where water will get in and rust... you'll never even see it happening and if you get it re-sprayed it will trap the moister in. Also, the shit covers up every nut/bolt making working on your rig a pita. Like mentioned Fluid Film is one of the best products on the market for rust prevention.
