Brilliant! Listened to Recommendations. Satoshi Grill Horn Relocation w/ Lots a Pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cape Codder, Feb 12, 2011.
  1. Feb 12, 2011 at 6:29 PM
    Cape Codder
    Cape Codder [OP] Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    1st, Thanks to w8n4mud (link to his post & pic) and chris4x4 (link to his post & pic) for their Posts about the best location for the horns.
    From another "Satoshi Horn" Tread, Here
    You can also see my Satoshi Grill Separate Letter Emblem Write-Up, Here
    Also added My Backspacing/Offset Drawings in the "Wheel & Tires" forum
    And my only use for Plastidip, so far
    Standard Disclaimer: Don't damage your vehicle, I'm not responsible.
    This Write-Up is just how I did it.
    Please Post any questions here, rather than PM Me.
    After looking it over, I saw that I could reroute the Horn/Temp Sensor Harness.
    This is a very easy mod, with the exception of fitting your finger where they don't fit
    1st Unplug Horns and Temp Sensor (if applicable).
    Pop as many fasteners as needed to lift plastic off the top of the radiator
    Pull Wiring Harness backwards, unsecuring where necessary, until it's behind driver's headlight.
    I marked the harness in some of the photos
    Reroute Plugs and Harness (marked red) thru lowest hole in metal surrounding radiator (driver's side). Viewed from behind headlight
    EDIT: CAUTION: Please note the following
    Thank You Adam for Decreasing my Ignorance a little and watching out for all of Us.
    That was an Epic Fail on my part.
    I should have started that thread and asked the dumb question
    To clarify "Removal": I removed one or both screws to shift the AIRBAG SENSOR, just enough to get the Horn Plugs thru.
    I DID NOT Disconnect, ManHandle or Hammer on the AIRBAG SENSOR at any time!
    The rest viewed from in front of the radiator with Grill removed
    Removal of part, circled in photo (AIRBAG SENSOR), will be necessary to get the plugs thru.
    I was gonna start a thread, asking one of those dumb questions, "What's this part ???" :D
    But I figure someone here's gonna tell me.
    So to continue, Loosen and Shift the unknown part (AIRBAG SENSOR), circled in the picture.
    Resecure the Airbag Sensor after feeding the Horn/Temps Sensor Plugs and harness thru.
    Route below Tranny Cooler and cable tie where convenient.
    Sorry, been a while. Looking at my pictures, I believe I used Stainless 3/8-16 x 3/4" or 1" Bolts and Nylocks (Nylon Insert Nuts) with Flat and Heavy Fender Washers.
    Alternative is to use Nuts and Lock Washers, but putting both on will be tough. You'll understand later.
    The hardest part of the Job is getting fingers and wrench behind metal cross member to start and tighten the nuts.
    Fender Washers, both in front and behind metal
    Any large nuts and bolts will do
    Mount Horns from front: Bolt, Flat Washer, Horn, Fender Washer, thru Slotted Hole in Metal, Fender Washer, NyLock.
    I used the two equally spaced slotted holes closest to center.
    Don't forget to plug in the Horns
    EDIT:
    Both Horns as viewed thru REMOVED Grill
    Continue the Harness past the Horn location for the Temp Sensor.
    The Harness just reached an existing Slotted Hole
    After plugged in, the Temp Sensor snapped right into an existing hole on passenger's side.
    Side View from Passenger's Side
    Viewed thru Lower Grill.
    Once Grill installed and hood closed, you don't see them.
    I was going to Mesh my Lower Grill anyway
    Look Ma, No Horns
    Finished
    Link to Emblem Write-Up Here or in My Sig
    Hope this is helpful
    Happy Modding and Enjoy your Tacoma
    CC
  2. Feb 12, 2011 at 6:42 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Thanks I'm relocating the 2morro
  3. Feb 18, 2011 at 8:17 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Looks great man! Great write up! Gonna do this tomorrow for sure!
  4. Feb 22, 2011 at 6:31 PM
    Cape Codder
    Jack
    Thanks, more pics than words.
    Quick & easy mod
    CC
  5. Feb 22, 2011 at 6:35 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    OUTSTANDING write up
    great job with the pictures
  6. Feb 22, 2011 at 6:48 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Very nice
  7. Feb 22, 2011 at 8:07 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    The "unknown" part in the second pic is the air bag sensor that deploys the air bags if you get in an accident. That being said you should take extra care when handling this piece. Other than that good write up and I will be doing this soon!
  8. Feb 22, 2011 at 8:44 PM
    Cape Codder
    Jack
    Thanks
    Thanks
    I should have started that thread and asked the dumb question.
    Have Edited the OP reflecting that information
    Thanks again
    CC
  9. Feb 22, 2011 at 9:08 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    typically yellow connectors mean SRS system. i know that the unknown part being SRS was already mentioned, but i'm just saying, generally, interior/exterior that rule applies.
  10. Feb 22, 2011 at 10:52 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Great write-up! Looks like a nice job for my 14 year old and his straw like fingers
  11. Feb 23, 2011 at 4:52 AM
    StandingCow
    StandingCow Well-Known Member
    John
    NJ
    09 SR5 4x4 V6 access cab
    I just threw the airbag sensor away...
    lol jk jk... thanks for the write up dude. I will be doing this once it warms up.
  12. Feb 23, 2011 at 8:34 AM
    OZ-T I hate my neighbour
    On my list of mods now , thanks for the write-up .
  13. Feb 23, 2011 at 3:43 PM
    Cape Codder
    Jack
    I now remember reading that somewhere, but it wasn't relevant at the time, so I guess it didn't register.
    It's in the Memory Banks now, won't forget that information again.
    Thanks
    Thanks.
    So there is a reason to have kids. :wink:
    Thanks, I'm with ya on the warm weather.
    I have a warm weather list.
    Above pictures were taken early last fall.
    Just got around to the Write-Up.
    Glad to be of help. You must have the weather issue too, though.
    CC
  14. May 21, 2011 at 11:32 AM
    Sapper Six
    Sapper Six Active Member
    VA
    '11 TRD Off-Road TX
    Debadged; Weathertech Floor Liners; Misc. Paint Modifications
    Outstanding how-to! Thanks for taking the time to do this for us man.
    I just did it now, went off without a hitch. You were right, for anyone but small children with tiny hands, re-mounting the horns was tricky with getting fingers back there to put the washers and nuts in place.
    Thanks again!
  15. May 27, 2011 at 10:35 PM
    jb3pin
    jb3pin Active Member
    Bend, OR
    2011 T|X TRD DoubleCab
    Nice write up, thanks. I managed to thread the horn and temp sensor wires through a passage above the airbag sensor which eliminated any need to touch it altogether.
  16. Jun 27, 2011 at 8:47 PM
    Cape Codder
    Jack
    Thanks Guys, and Your Welcome.
    Don't remember why I went with the lowest opening.
    CC
  17. Aug 2, 2011 at 6:09 PM
    Cape Codder
    Jack
    Thought I'd Bump this for the new members I see, doing the Satoshi Grill Mod.
    CC
  18. Aug 13, 2011 at 7:49 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Thanks for the great write up. Rep to you. I did this finally today.
    As noted above - routing the harness through the other hole means you don't have to touch the SRS sensor.
    I also just used two existing bolts for the support bars down there to mount the horns. The spacing isn't quite right - so I pulled some of the wire for the temp sensor out of the loom and extended the wire between the two horns. Just soldered a few inches of wire in. But it was very easy to do.
    If you do this don't forget to get some high temp paint and paint your AC condenser while you're at it. Now I am Satoshi ready. Just have to finish the actual grill...
  19. Aug 15, 2011 at 8:14 PM
    Cape Codder
    Jack
    Thanks, Glad to be of Service
    Lookin' forward to Pics of Satoshi
    They're a lot of work, but worth it IMO
    CC
  20. Oct 14, 2011 at 11:06 AM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Since you said to post here instead of PMing you, I'm reviving this thread (sorry all)
    In the pic from what you posted above, I circled 2 parts:
    #1. shows where I can pull the temp sensor to - this is the farthest point I can pull it after rerouting it through the SRS sensor hole. I cut every fastener I could find behind the headlight, but it's still not as much slack as what you're showing in your picture.
    #2. shows the nut I used to mount one of the horns
    So as it stands right now, I'm running one horn (one better than none, I guess)
