Diary of a Madman..... OZ-T's build and pics
Discussion in '2nd Gen. Builds (2005-2015)' started by OZ-T, Apr 27, 2011.
  1. Apr 27, 2011 at 9:04 PM
    OZ-T [OP] I hate my neighbour
    This is by no means a serious build up thread , I just wanted to try to keep all my truck related pics in one spot
    I will edit the OP as I get organized .
    Current Spec :
    2009 DCLB TRD Sport 4x4 with tow package
    OME 885x coils , no spacer
    OME 90000 front shocks
    OME N182 rear shocks
    OME Dakar rear leafs
    OME CB drop
    Wheeler's SuperBumps , front and rear
    Toytec 3* axle shims
    275/70/17 Hankook Dynapro ATm's
    2" stainless N-Fabs
    Leer RCC Commercial canopy with DeWalt ProRac
    Aluminum headache rack
    Weathertech digifit floor liners
    Weathertech in-channel window vents
    OEM bed mat
    HomerTaco M1 1 1/2" Satoshi
    Grey Anodized Devill Horns by Andres
    Sleeper style eyelids by Toyota Man
    USA Spec PA15-Toy
    ImMrYo rear view mirror relocation bracket
    Relocated my horns
    Stock
    Add 265/70/17 Hankook Dynapro MT's and 2" stainless N-Fabs
    Add the aluminum headache rack
    Remove the TRD Sport bedside decals
    Add the Weathertech In-channels
    Repping TW in BC
    In the shop to get the lift put on
    Goodbye Toyota 4 leaf pack , hello OME Dakars
    OME 90000 Sport fronts
    OME N182 rears
    We added a centre pin collar extension to the Dakars in case I needed to add axle shims later
    Thanks to TW member PSU taco85 for this trick , you can find his thread on it here
    http://www.tacomaworld.com/forum/suspension/144224-dakar-installation-axle-shims.html
    With the 885's no spacer , 90000's , N182's and Dakars
    Up 2 3/4" front and back ( settled to 2 1/2" front and 2 3/4" back )
    Centre of hub to fender measurements are 22 1/2" front and 24 1/2" rear
    Added Leer RCC commercial canopy with DeWalt ProRac System
    The roof rack can carry 400 lbs
    Loaded with 16' finishing material
    Just added the grey anodized Devil Horns by Andres , thank you sir
    Trying out the no Nfab look for a bit
    275/70/17 Hankook ATm's , Homertaco 1 1/2" reduced depth satoshi , Sleeper style eylids by Toyota Man , Mag Grey Devils Horns by Andres
    Added a Ghost Graphix decal ,
    Thanks Ray !
    That's where I am for right now
  2. Apr 27, 2011 at 9:13 PM
    IluvTEA
    IluvTEA Well-Known Member
    South Dakota
    '10 DC LB 4x4 SR5 Super White
    Cooper ST 265/75/16 on Flat Black TRD OR wheels, window tint, blacked-out badges, front mudflap trim, BHLM, Base Black Rear Bumper Swap, Color-matched grille, Custom Relentless Fab plate bumper powdercoated flat wrinkle black and "TACOMA" backlit with Drunknsloth LEDs, Camburg 2.5" coilovers, LR UCAs, Power sliding rear window, Back-up camera anytime, FX-R projectors/Morimoto 3Five Ballasts/D2S bulbs 5000K, Black WeatherTechs, heated TRD seats with Roadwire Graphite Leather, OEM Roof Rack, front mud flap delete, Black Level 8 Guardians, TreadWright 285/75/16 with KG ...
    Looks good man, you need to get your bumper installed! It totally changed the look of my truck!
  3. Apr 27, 2011 at 9:13 PM
    I'm moving some of this stuff forward of the tampon-a-thon that are the pages that follow
    When I got my aluminum bumper from Eric @ Relentless Fabrications , he needed to substitute a 5" ID tube for the foglights for the standard 4" tube used on the steel bumpers .
    This gave me the option of using the 5" PIAA 540 series Plasma Ion foglights rather than the 4" PIAA 510's .
    My lights finally arrived , and when they did , I found that they were slightly too big to fit in the tube , so I decided to use a router to make a bit of clearance room so that the lights wouldn't be in contact with the bumper . I managed to get some time to do this today .
    Covers removed
    They just don't quite fit
    Scalpel
    The full tube posed some problems for the router base to ride on because the light mounting tab
    was a bit higher than the edge of the tube
    I rigged up a temporary base that was notched over the tab to give a flat surface for the router
    I changed the top bearing to get the bit to remove 1/8" of material
    I sanded the rough edges with some 120 and then 240 grit
    It now fits down to the lens side screws and has almost a 1/16" of clearance all the way around
    Test fit
    Test fit , pat myself on the back
    So , because I had to remove the PIAA cages from the 540's , I thought I would try this out
    1"x1" aluminum grate
    Cut out and test fit
    Cut out and test fit with light
    Got my foglight grate welded into the bumper by my fabricator friend
    Added Wheeler's SuperBumps , front and rear
    Installed front and rear Wheeler's SuperBumps
    OEM vs Wheeler's rear
    OEM vs Wheeler's front
    OEM
    Wheeler's
    Wheeler's front
    Added the ImMrYo rear view mirror relocation bracket
    Easy install , far better visibility , I highly recommend this mod
    Relocated my horns , but it got too windy to paint the radiator today
    Yanked out the plastic inserts behind the rear seats in order to remove the cast in shelf so that I can fit a tool box back there
    Update on my rear seat cubby storage solution
    Started with this
    Milled the upper piece , added a 5/16" stainless through bolt to register the axe handle
    Milled the lower piece , it needed to be rabbetted to span over the shelf support remnants
    I fixed these pieces through the back of the cubby inserts with #8 x 3/4" screws and fender washers
    I put the screws where I could cover them back up with the backing insulation so that they wouldn't rattle against the mounting surfaces
    That left me with this
    I built a toolbox that would fit the countour of the storage area under the axe
    Lid :
    Case :
    Tool box :
    Axe and tool box locations :
    Still waiting on Quickfists for the final axe mounts and an ARB Compact Recovery bag that fits to the left of the tool box
    Test fit
    All back together
    Got my Quickfists
    Added one Quickfist to my axe set up
    Got my ARB Compact recovery bag , fits pretty good
    There is an ARB 17500lb snatch strap inside
    Installed my sway bar relocates
    Added a Stant locking gas cap
    ohcaltexscar and ChadsPride like this.
  4. Apr 27, 2011 at 9:35 PM
    Thanks
    Thanks Boog
    Continued
    Received the LCAs and skids I bought from TW member thekernel114
    Pulled the skids off , TC skids according to Boyd
    Did a preliminary clean up and inspection on the LCAs , they look to be in great shape
  5. Apr 27, 2011 at 9:37 PM
    Decided to go ahead and build a new box with the revisions I wanted
    3/4" wider , 1/4" shorter , 3/4" narrower at the top , move the hinge location up 1" and add a shelf to hold oddball sockets ( 32mm , 35mm ) extentions and other assorted tools
    Got the case built , and the lid built today , after the glue has set up , I'll cut the opening portion of the lid out and mount the hinge
    Old prototype box on the left , new box on the right
    Finished Version 2 of my tool box
    The lid was rabbeted to accept the socket tray
    I use this Lisle 1/2" drive magnetic socket tray
    Cut off the handle , removed the through rivets and drilled it out to accept 1/4" hardware
    Used the tray as a pattern and drilled through the lid front , and attached 1/4"x 2" SS carriage bolts
    Mounted the socket tray
    Loaded it up with these tools
    Test fit #2
    Just needs a handle and some finish
  6. Apr 27, 2011 at 9:40 PM
    I understand :D
  7. Apr 27, 2011 at 9:44 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Looks good OZ, now get that bumper you have sitting around installed.
  8. Apr 27, 2011 at 9:44 PM
    The Leer will be on in the winter , off most of summer , the headache rack will be the opposite .
  9. Apr 27, 2011 at 9:44 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Pretty sweet! How's the difference in ride w/ that OME setup?
  10. Apr 27, 2011 at 9:46 PM
    Honestly , no difference from the 4 leaf pack ( TSB pack ) ride I had before , my ride was always a touch stiff from the E-rated tires .
  11. Apr 27, 2011 at 9:48 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Nice title
    Truck is looking good man
    :popcorn:
  12. Apr 27, 2011 at 9:49 PM
    Thanks Bubba
  13. Apr 27, 2011 at 9:50 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    GET THE R FAB BUMPER ON!DAMNIT! haha go canucks.
  14. Apr 27, 2011 at 9:50 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    the lift looks good on it. made a huge difference looking at the pics.
  15. Apr 27, 2011 at 9:55 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Love the whole look. She'll look great with that front bumper! :) Nice headache rack.
  16. Apr 27, 2011 at 10:04 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Nice truck! If is disappears it wasn't me....:anonymous:
  17. Apr 28, 2011 at 9:05 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    4.10 gears, sliders, and lots of buttons.
    I hadnt noticed this build, until it was held over my head by an un named member....Anyhoo.....Very nice! I dig the headache rack!
  18. Apr 28, 2011 at 9:05 PM
    :anonymous:
  19. Apr 28, 2011 at 9:23 PM
  20. Apr 28, 2011 at 9:24 PM
    tinker_troy
    T R O Y
    WY/SD
    Do you need help? Maybe I can send someone up your way :p
