2 Inch lift with ARB on OME 885, 886
Discussion in 'Suspension' started by Sandman614, Feb 27, 2011.
  1. Feb 27, 2011 at 9:42 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I am looking at putting 5100's with either 885, 886, or eibach 1.6" coils on. I don't have an AAL or TSB done on the rear, so I'm only looking for about 2" on the front. What amount of lift did you get with your setup? Are the measurements below accurate?
    Wheelers lists:
    *OME 885 Tacoma Front Coil Set Provides approx 1.75" lift on stock Tacoma's.
    *OME 886 Tacoma Front Coil Set Provides approx 1.75" of lift on a Tacoma with a Bull Bar and Winch.
    ARB lists:
    *2 Inch 05+tacoma Stock Kit (885+N140S)
    *2 Inch 05+tacoma Heavy Kit (886+N140S)
    lists:
    *885--- Medium 2" lift coils for 110 lbs additional front weight
    *886--- Heavy 2" lift coils for 200+ front weight -- No top plate spacer needed--
    Other people (not pointing fingers):
    *The 886's give 3" lift with a bumper and winch.
    *Eibach 1.6" give that lift unladen, and on Extended cab trucks.
  2. Feb 27, 2011 at 9:44 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I have OME 885s with Billy 5100s set at zero and I'm getting a solid 3" of lift
  3. Feb 27, 2011 at 9:45 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    885s gave me 3 at first, then sagged overtime, I would get 886s for a full 3 inch
  4. Feb 27, 2011 at 9:45 PM
    ColtsTRD
    Scott
    AZ
    thats without a aftermarket front bumper. I'd rock the 885s if you didn't want the added height that the 886s will provide
  5. Feb 27, 2011 at 9:46 PM
    ColtsTRD
    Scott
    AZ
    I've only had mine on for about 2 months, they settled nicely. I was at 3.5" :eek:
  6. Feb 27, 2011 at 9:49 PM
    ColtsTRD
    Scott
    AZ
    Oh and OME revised there springs a year or 2 ago so that they don't sag so much...the new models have an "X" at the end.
  7. Feb 27, 2011 at 9:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why the bilsteins and not the OME shocks?
  8. Feb 27, 2011 at 10:00 PM
    ColtsTRD
    Scott
    AZ
    from what I understand the OME shocks retain there heat and stuff more than Bilstein. Chris4x4 explained it to me but I forgot now :eek:
  9. Feb 27, 2011 at 10:01 PM
    ColtsTRD
    Scott
    AZ
    and billys have a lifetime warranty...OME is 2yrs I think
  10. Feb 27, 2011 at 10:18 PM
    OZ-T
    Peter North
    British Columbia
    Thanks Scott
  11. Feb 28, 2011 at 6:44 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    So since everyone here has gotten approx. 3inch lift with 885 and 886 how can ARB and Wheelers claim that it will provide approx. 2 inches of lift?
    A customer like myself looking for 2 inches of lift would purchase one of these kits and be sorely disappointed that I actually got approx. 3 inches of lift.
    I get that they updated the coils, but it has been stated that that was 2 years ago, that is plenty of time to update their websites.
  12. Feb 28, 2011 at 8:22 AM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    When I was getting ready to order my OME complete lift I sent Wheeler's and Toytec and email asking how much lift this kit would provide.
    Wheeler's said I should expect 1-3/4" to 2" in the front and 2-1/4" to 2-1/2" in the back.
    Toytec responded that it would be 2" in the front and 2-3/4" in back.
    With that info I decided to add the 10mm top spacers from Wheeler's to my setup. The 10mm spacer should add 5/8" to 3/4" of lift up front.
    When I was done I had gained 3-1/2" in the front and 2-3/4" in the back. These numbers were taken within the first couple of days from the lift being installed so there has not been any settlement yet. I think if I would have skipped the 10mm spacer I would have gained 2-3/4" both front and back. I like the level look that the 10mm spacer gives but I am concerned about my CV angles. I have considered taking the 10mm spacers out and waiting to see if the front settles. If it did settle I could put the 10mm spacers back in.
    I had Wheeler's assemble my front shocks and coils. I think it is a good idea to have the longer top studs from the spacer kit installed when the coils are assembled even if you are not sure if you need the top spacers at this time. That way if you do decide to add the spacers you do not have to disassemble your coils to install the longer studs required to add the top spacer. You could save your self some hassle or $$ that way if you think spacers may be something you would want down the line.
  13. Feb 28, 2011 at 2:40 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thank you!! I still would like to know why the Vendors are claiming 2" when people are clearly not getting it.
  14. Feb 28, 2011 at 2:49 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    I had the same questions as you before I plunked down cash for the OME kit. I asked the same questions in this tread
    http://www.tacomaworld.com/forum/suspension/134785-ome-whats-real-number.html
    Some say you will get 3" up front. I think it's safe to say it will be between 2-3/4" and 3" (without spacers), there is bound to be a small difference in how accurate different folks will measure.
    Of course the guys that post are giving you the initial measurements. It would be nice if we had some follow up measurements say 6 to 9 months after the lift was installed.
  15. Feb 28, 2011 at 3:01 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    most people seem to be getting about 3" of lift with the 885s and a 10mm top plate spacer. if u got the 885s w/o the spacer and since you have the arb bumper im sure thats heavy enough to settle you down to about 2" of lift. but remember when ever you first put them on they will read a little bit high then will settle
  16. Feb 28, 2011 at 3:19 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thanks for everyones input, I might just have to settle for the lift I get and do an AAL for the rear..
    Can someone with an ARB bumper or similar with 885's post up their measurements?
  17. Feb 28, 2011 at 3:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Actually, THe OME shocks tend to stay cooler than the 5100's. The 5100's are a medium duty shock, while the OME's are a bit more "heavy Duty"
  18. Feb 28, 2011 at 3:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Send a PM to Mountainwolfpup and see what he got with his 886's. Figure about an inch less with the 885's
  19. Feb 28, 2011 at 4:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Thanks again Chris! I'm pretty sure I did though I can't find his response at the moment or I would add it to the list of others.
  20. Feb 28, 2011 at 4:33 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    chris4x4, how long have you had the 885's installed, what was your initial lift and have they settled any?
