-   -   Remove Readylift???? (http://www.tacomaworld.com/forum/suspension/192418-remove-readylift.html)
chris2011 12-11-2011 07:21 PM
I have readylift kit on 2011 access cab 4x4 with blocks in back. Changed rear shocks and had some rough country shocks put on. Now, im wanting to take readylift kit off and go back to factory. How best way to take spacers off??
NC15TRD 12-11-2011 07:23 PM
Reverse of the way you put it on
KPT 12-11-2011 07:23 PM
Is it a top plate spacer or a coil spacer?
Either way you'll have to remove the coilover assembly from the truck. If its a coil spacer you'll also need a spring compressor.
chris2011 12-11-2011 07:25 PM
I had a shop to put it on and money a lil tight here at holidays and was going to do it myself.
NC15TRD 12-11-2011 07:26 PM
Readylift is all top plates on tacomas
KPT 12-11-2011 07:26 PM
Gotcha. Well that will make it easier.
NC15TRD 12-11-2011 07:32 PM
http://www.tacomaworld.com/forum/sus...g-removal.html
Read this^^^
chris2011 12-11-2011 07:32 PM
Once strut assembly is out will i need a spring compressor to take spacer off???
KPT 12-11-2011 07:33 PM
You will not.
NC15TRD 12-11-2011 07:37 PM
Simply unbolt spacer and reinstall strut
chris2011 12-11-2011 07:37 PM
Originally Posted by KPT (Post 4170056)
You will not.
Ok thanks! So once spacer is off just put strut assembly back on to get factory ride height??? Thanks for help!!!!!
KPT 12-11-2011 07:38 PM
Get an alignment right afterwards.
NC15TRD 12-11-2011 07:39 PM
You got it
chris2011 12-11-2011 07:39 PM
Yeah most definately. Thanks alot for help man!!
KPT 12-11-2011 07:42 PM
No problem
:gossip: Thank Nick too
