Installed Pro-Comp 3" lift with ABS issues
Discussion in 'Suspension' started by PHOLT11, Mar 12, 2012.
  1. Mar 12, 2012 at 5:43 AM
    PHOLT11
    PHOLT11 [OP] New Member
    Clarksville Tn
    11 TRD Sport
    KMC XD 795MB Hoss Whees, Black Smitty bilt tube step bars, Smittybilt bull bar, bedcover, bed extension
    I have a 2011 Toyota Tacoma Sport that I installed the Pro-Comp Colis on my Bilstein 5100 struts to allow for the 285 70-17 Nitto Terra Grappler AT's. My question is when I am taking a curve to the right at about 40 mph my ABS is engaging but once I let off gas and straighten up it goes away. Any ideas? I bought the Pro-Comp 3" suspension lift with shocks but since the bilstein struts were same length I used the bilsteins instead of the explorer struts and shocks it came with.
  2. Mar 12, 2012 at 5:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You probably need to get the ECU reflashed for the larger tires. The VSC system is set up for stock sized tires, when you take a corner with larger tires, the wheel speeds relative to each other are different with larger tires and the ECU thinks you're out of control. Get the reflash and that should solve your problem.
  3. Mar 13, 2012 at 6:11 PM
    PHOLT11
    Clarksville Tn
    11 TRD Sport
    Thanks Man, I will try that.....is there a perfomance chip you would recomend instead of paying dealership 85 an hour.
  4. Mar 13, 2012 at 6:14 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  5. Mar 13, 2012 at 6:24 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The DIY way to reset the ECU is to disconnect the negative battery terminal overnight and reconnect in the morning. This will deenergize all the computers and they will have to relearn. It works for transmission shifting points, it may work with the ABS. Worth a shot, I did it to my truck after a lift, no issues.
  6. Mar 13, 2012 at 6:25 PM
    OZ-T
    Peter North
    British Columbia
    It's not ABS , it's the skid control ECU that controls VSC
  7. Mar 13, 2012 at 6:27 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    ECU, VSC, ABS, ECT, TSB, damn acronymns, so confuzzing.
  8. Mar 13, 2012 at 6:28 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    I have that lift and had the same problem. You need to get the dealer to do a zero point calibration. And you will probably want to have the alignment perfect before doing this. Fixed the issue for me.
