3.4L 5VZ 1st Gen Oil Change Guide
Old 08-13-2009, 10:44 AM   #1
chris4x4 [OP] chris4x4 is offline
chris4x4's Avatar
chris4x4's Tacoma Gallery
(See 4.0L 1GR 2nd Gen Oil Change for 2nd Gen Tacomas)
First, You want to make sure you have all your things ready to do the oil change:
Needle nose Pliers
3/8" ratchet wrench
4" extension (3/8")
14mm socket (3/8")
Filter wrench
5.5 quarts oil
Oil Filter
Oil Catch Pan
Lots of rags
You want to park your truck on a level surface, with the front wheels turned all the way to the left.
Locate the Oil drain plug, and useing a 14mm socket, and extension, remove the plug, and drain the oil.
While the oil is draining, Look into the driver side wheel well. Useing the Needle Nose pliers, remove the push pins holding the wheel well liner on.
You will then see the oil filter.
Place a bunch of rags under the filter, on top of the skid plates, so as to absorb any oil that spills from the filter when its removed.
Remove the old oil filter, and clean the filter mount of any dirt around it.
On the new filter, Lubricate the filter gasket.
Then install the new filter.
Check the oil pan to make sure the gasket is not stuck to it.
Clean the Oil pan around the drain plug, install the new gasket, and drain plug. Tighten the drain plug to 29 ft-lbs.
Fill the engine with 5.5 Quarts of your favorite oil.
Start the engine, and let it run for a few mins., then shut it off. Check for leaks around the drain plug, and filter, then check the oil level.
All done!
Take the used oil to a local oil recycling drop off in your area. Most Auto parts stores will take your used oil for free.
Old 08-13-2009, 11:36 AM   #2
Lest We Forget
cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack
cmack's Tacoma Gallery
Nice write up. Thanks again for the help. And I'm only getting a lift right now if it's free.
Old 08-13-2009, 11:47 AM   #3
chris4x4's Avatar
Anytime, Buddy. I'll see what I can do about/aboot the lift.
Old 08-13-2009, 11:53 AM   #4
Born to Ride
TheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shedTheMaster is one of the sharper tools in the shed
TheMaster's Avatar
Gender: Girl
TheMaster's Tacoma Gallery
Isn't it easier to pour it down the storm drain .
Old 08-13-2009, 11:55 AM   #5
chris4x4's Avatar
Yes it is! However, My storm drain was full from the rain, so I had to improvise.
Old 08-13-2009, 12:46 PM   #6
Lest We Forget
Thanks! My cousin said he will have some leaf springs that if I want I can have. He has a 2005 Ford Ranger. Not sure if it's anything worth while for my Taco but I just thought I'd let you know.
Old 08-13-2009, 12:47 PM   #7
chris4x4's Avatar
They wont work.
Old 08-13-2009, 12:49 PM   #9
Lest We Forget
They wont work.
Ah ok. He wasn't sure if they would either.
Old 08-13-2009, 12:49 PM   #10
chris4x4's Avatar
Originally Posted by Colton View Post
Nice write up Chris.
Old 08-13-2009, 12:53 PM   #11
Gone But Not Forgotten
ImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shedImpulseRed008 is one of the sharper tools in the shed
ImpulseRed008's Avatar
Air Force:
Gender: Girl
ImpulseRed008's Tacoma Gallery
I thought you were only going to supervise this operation... I see you doing all the work in the pics
Old 08-13-2009, 12:54 PM   #12
chris4x4's Avatar
Yeah....well....Conner DID change the air filter.
Old 08-13-2009, 12:55 PM   #13
Lest We Forget
That was hard work man!
Old 08-13-2009, 12:56 PM   #14
chris4x4's Avatar
And you did good.
Old 08-13-2009, 12:58 PM   #15
Lest We Forget
And you did good.
And I made sure you weren't going to blow us up.
Old 08-13-2009, 01:00 PM   #16
chris4x4's Avatar
Tats only a concern if Im working on an "Experiment"....Im pretty good around these truck...vehicle...thingys... And I usually find the right drain plug after 2 or 3 attempts.
Old 08-13-2009, 01:09 PM   #17
Lest We Forget
Well I'll keep that in mind about the "Experiments".
Old 08-23-2009, 09:30 PM   #18
Lest We Forget
Just a commercial I thought I'd post here...
http://www.youtube.com/watch?v=Mj5ms9PJDNY
Old 11-05-2009, 08:19 PM   #19
slickyd is just really niceslickyd is just really niceslickyd is just really niceslickyd is just really niceslickyd is just really nice
slickyd's Avatar
slickyd's Tacoma Gallery
Never knew that about the fender weld to get to the oil filter. I have been reaching up from the bottom. This looks much easier.
Old 11-06-2009, 12:58 PM   #20
tacotopher is on a distinguished road
tacotopher's Avatar
tacotopher's Tacoma Gallery
Great write up! I have been wondering how the crap im gonna get to the filter without makin a total mess.
1st Gen 2.4L Repair Musings: Oil pan & A43D Trans ToxicGumbo Technical Chat 45 01-17-2014 07:13 AM
Put Syn on my 1st Oil change, now want to change back to regular Oil ! ?!? moulin6801 2nd Gen. Tacomas 29 11-17-2013 06:10 PM
2010-2011 Oil Viscosity Applicability and Change Interval Guide BeefTaco 2nd Gen. Tacomas 9 04-27-2013 05:05 AM
1st Oil change, free but $38 more to change to Syn oil!! Is it worth it?? moulin6801 2nd Gen. Tacomas 76 02-27-2012 09:53 PM
How To - Change Spark Plug 1st Gen 95.5-04 2RZ-FE(2.4L)/3RZ-FE(2.7L) The Parts Whore Technical Chat 7 01-28-2012 01:58 PM
