Greasing Entire Drive Shaft U-Joints (5 Zerks Total)
Discussion in 'Technical Chat' started by The Parts Whore, Oct 18, 2009.
  1. Oct 18, 2009 at 11:12 AM
    The Parts Whore
    The Parts Whore [OP] Slinging parts since '03
    I saw this thread posted on TTORA and thought it'd be a good time to check up on the drive shaft u-joints. On a nice Sunday morning...with the football games on, cold beers, wrenching with your better half = priceless. I also received an early xmas gifts with new suspension (leafs, shocks, and coils...buh bye King) setup to install so today is a good day. :D
    *Write up on that will be posted later when I'm not lazy.
    I tried to take clear pics of where the zerks are so hopefully it'll make it easier for you to find/identify.
    You'll need:
    1.) grease gun
    2.) your favorite grease
    3.) rags
    4.) brake cleaner
    5.) flashlight (maybe)
    Grease gun:
    Front of drive shaft (near tranny)
    Mid joints...there are 3 zerks, the third one is a bit hidden.
    And last two (near the axle)
    Once again, be sure to clean the zerks before apply the grease. You should be able to see the old grease coming out in dark color. It should be the same for all 95-04 Tacoma Xtra-Cab & DC but don't quote me on it. Take this write-up with a grain of salt, trash it or use it for all I care. :p
  2. Oct 18, 2009 at 4:01 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    HELP! I cant find zerks 2,3,&4 , i think the factory screwed up !!
    Just kidding , i got a reg cab. :laugh:
    Thanks for the reminder though, i have the grease and need to check it b4 my elk hunt.
  3. Oct 19, 2009 at 7:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nice writeup....but I think you forgot one of them.
    It's in the last picture..... and to the right on the 'ear' near the base of the shaft - that's probably for the slip yoke. Always wondered where that one was. Never went and looked for it on my own truck. :rolleyes:
    :D
  4. Nov 9, 2009 at 10:54 AM
    scrapedface
    scrapedface Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    grease didn't seem like it was going in on the forward part of both the front and rear propeller shafts. the grease was spewing out of the connection between the gun and the zerk. it was going in fine on both rear parts of the propeller shafts. is that normal?
  5. Nov 9, 2009 at 11:13 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    It probably wasn't completely attached to the zerk.
    Anyone else have pics/descriptions of any other grease zerks (like stock UCAs)?
  6. Nov 15, 2009 at 3:39 PM
    Igor
    Igor New Member
    Igor
    Atlanta
    08 Tacoma
    Long bed TRD Racing 4x4
    I have a 2008 tacoma double cab long bed with 4x4. According to the maintenance recommendation it is time for me to grease the "propeller" shaft (drive shaft). My manual reads the following:
    Front drive shaft thrust bushings
    Synthetic oil and lithium soap base chassis grease, NLGI No. 1
    Propeller Shafts
    Spiders
    Lithium base chassis grease, NLGI No. 2
    Slide yokes
    Lithium base chassis grease, NLGI No. 2 or Molybdenum-disulfide lithium base chassis grease, NLGI No.2
    How to the zerks I have found on the drive shaft correspond to the descriptions above? I found a total of 5 zerks along the drive shaft in the following locations (please see the attached PDF for pictures). Starting at the front there is a small shaft which corresponds to the front wheel drive case for 4x4. On each end there is 1 zerk so 2 total, these zerks are hidden and hard to see but there is 1 good picture in the PDF. Do these correspond to the " Front drive shaft thrust bushings" description in the manual?
    Next there is the rear drive shaft ("propeller shaft") which has 3 zerks on it, 2 on each far end and 1 in the middle. Do the zerks on each far end of the entire drive line shaft correspond to the Spiders and the one in the middle to the slide yoke?
    I just want to make sure I use the correct grease for each location and that there is nothing I am missing in this procedure (hidden zerks or something else I need to lube).
    Thank you in advance to anyone that can verify my assumptions above!
    Biscuits likes this.
  7. Nov 15, 2009 at 6:53 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Igor, I am not sure, but in the photos above, I think they are all "spiders". I am certain someone else will chime in with a more certain response to your questions.
  8. Nov 16, 2009 at 4:04 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Igor, According to Drew02a, the two zerks on the font drive shaft are indeed the "front drive shaft thrust bushings." Strange huh?
    Please allow me to digress on the subject of grease.
    I don't think it matters that much if you use NLGI Grade #1 on the front. I would use NLGI Grade #2 all the way around.
    Today I looked at synthetic grease products from Mobile One and Valvoline. Both of their product offerings are NLGI Grade 2. Both appear to be very high quality. I was unsuccessful in finding NLGI Grade 1 grease on either of their websites.
    I did manage to find some NLGI #1 from AMSOIL
    I also managed to give myself an education in Grease. There is a wonderful article on Grease titled: Grease: don't let the details slip through your fingers By Bruce McCallum (1998)
    Here is a great quote from the article:
  9. Nov 17, 2009 at 4:55 PM
    Igor
    Igor New Member
    Igor
    Atlanta
    08 Tacoma
    Thank you, that is what I needed to know!
    I have been reading up on grease as well before posting, it is a much more complex topic than I had ever imagined. Also I have found some contradicting statements about using moly fortified grease and I think I will stay away from that for now unless someone convinces me otherwise.
    This weekend I ordered 2 tubes of grease from AMSOil. One tube of Synthetic Multi-Purpose Grease NLGI #2 and a tube of Synthetic Multi-Purpose Grease NLGI #1. They should both be here by tomorrow afternoon.
    Thank you both for replying.
  10. Nov 22, 2009 at 5:45 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I dont know if I should grease the shaft myself or not... is not easy to get to it... boy I sure wish I had a vehicle lifting device thingy... :(... if I do... Should the MOBIL 1 Synethic grease will do just find right?
  11. Nov 22, 2009 at 5:48 PM
    rscecil007
    rscecil007 Well-Known Member
    Seattle
    06 4x4 TRD Sport Access Cab
    Goodyear Duratracs 265/70R17's, Bed mat & extra d-rings, Weathertech floor liners, Husky Liner for rear seat area, Biceman Illuminated 4x4 Switch, Pioneer 800 PRS, Hybrid Audio L6 and L1V2, JL 13TW5 in a Mr. Marv box, JL HD900/5
    I did mine yesterday for the first time using M1 grease and a grease gun I bought at Lowe's. Super easy to do. Go for it!
  12. Nov 23, 2009 at 3:11 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I guess u got the Mobil 1 grease? what color are they? so I put the hose thing onto the zerks and that's all I have to do?? Pump the grease in until it comes out? where's the old grease will be coming out from? I guess I have to see it in person to see how it goes so I wont have these many questions...:)
  13. Nov 23, 2009 at 5:05 AM
    rscecil007
    Seattle
    The grease or the can? Grease is pinkish, can is silver I think. Yup, just put the coupler on the end of the hose on the zerk, and give it 4 or 5 good pumps. The old grease will be forced out of the seals.
    and yes, it will make more sense when you do it. ;)
  14. Nov 23, 2009 at 5:13 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    did mine this weekend also, not sure what was in the gun, but it was grease :p.
    also changed all the oils, some looked good, others like the front diff.... not so pretty
  15. Nov 23, 2009 at 3:37 PM
    Bobcat
    Bobcat Well-Known Member
    Montana
    hmmm so many jokes... :D
    04Burk, Benzdriver81 and ROlla-Xrs like this.
  16. Nov 23, 2009 at 3:47 PM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Must refrain...........walk away.........don't say it...........
    BluLED and 04Burk like this.
  17. Nov 23, 2009 at 4:58 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    so I guess the new grease will replace it...
    man I wish i can see it in person, I'm a hands on training kinda guy.. :)
  18. Nov 23, 2009 at 5:09 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    is the mobil 1 grease is made of silicone? can i use it as brake grease also?
    thanks!
  19. Nov 30, 2009 at 7:34 AM
    Janster
    Jandy
    Lancaster, PA
    Can someone update the first post to reflect the zerk #6 bubble?
    If you do a quote & preview, there's another bubble showing Zerk #6, but for some reason - it's not updating on the page.
    This is weird....cuz one minute I can see it, and the next time I look at it, I can't. Or is it just me?
  20. Nov 30, 2009 at 7:53 AM
    The Parts Whore
    I did update it and it shows #6 for me. :notsure:
    Maybe try Ctrl + F5 to force a refresh.
